92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Say.
Old 04-09-2008, 04:45 AM
Former Moderator
B18C5-EH2's Avatar
Default 92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Say.
Like the question asks - shocks or struts?
I'm curious as to what everyone thinks. There was a topic not too long ago that had a few people trying to correct other people on the correct terminology, and it got me thinking as to what everyone thinks they're called, and WHY.
I've got my own opinion, but I want to see what others say.
I'll post mine after I see some responses as I think mine might skew the results.
Old 04-09-2008, 05:18 AM
D50boy's Avatar
Default Re: 92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Say. (B18C5-EH2)
Struts. Struts are made of 2 components- a shock and a coil spring mounted over it.
On a Civic/Integra (80s to 2000 models) it is kind of odd. Struts on a lot of cars also serve as a structural part of the suspension. Civics and Integras have a structural support on the steering knuckle.
Old 04-09-2008, 05:59 AM
EK_kidd's Avatar
Shocks
Old 04-09-2008, 06:07 AM
Former Moderator
B18C5-EH2's Avatar
Default Re: 92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Say. (D50boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy &raquo;</TD></TR><TR><TD CLASS="quote">Struts. Struts are made of 2 components- a shock and a coil spring mounted over it.
On a Civic/Integra (80s to 2000 models) it is kind of odd. Struts on a lot of cars also serve as a structural part of the suspension. Civics and Integras have a structural support on the steering knuckle.</TD></TR></TABLE>
Are you absolutely SURE?
Old 04-09-2008, 06:14 AM
Tzarinque's Avatar
definitely shocks
Old 04-09-2008, 06:25 AM
Luserkid's Avatar
Default Re: 92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Say. (Tzarinque)
Shocks on small passenger (unibody) cars and struts on non unibody cars (like trucks and such).
If there switch bite me i just woke up
Either way it doesnt matter for me when someone says they want to replace struts or shocks, i know what there talking about even though there wrong. But for Honda Civic/Integras its Shocks. Final Answer.
Old 04-09-2008, 06:37 AM
Former Moderator
B18C5-EH2's Avatar
I get it when someone says either as well, but it's when someone tries to "correct" others with incorrect info - that's why I'm asking. I just want to see how the peopole here see it.
Old 04-09-2008, 06:39 AM
Luserkid's Avatar
Yea i figured the great Tom would know whats what..... if not....
Old 04-09-2008, 08:03 AM
D50boy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm pretty sure Shock and spring are separate parts- put them together and it is now one component called a strut.
Sometimes a suspension will have the spring and shock separate- more common on trucks
Sometimes the spring and shock are put together as a strut and used as a structural part. Newer civics are like this. The shock twists with the turning of the wheel. McPherson strut is what it's called:
Most of the people on this board with older Civics and Integras have a strut assembly, but the knuckle has structural support and a connection to the A arms. It's a different system. The shock is mounted to the lower arm and does not twist when the wheel is turned.
That's my view anyway.
Modified by D50boy at 11:15 AM 4/9/2008
Old 04-09-2008, 08:11 AM
pdiggitydogg's Avatar
Im going shock....for the simple fact that theyre "macpherson struts" and different in how they connect directly to the knuckle
Old 04-09-2008, 08:14 AM
themikewoo's Avatar
Shocks.
Old 04-09-2008, 08:15 AM
EL Vap133's Avatar
Default Re: (pdiggitydogg)
What, no poll?
Old 04-09-2008, 08:55 AM
blk92_d16's Avatar
Ask Bilstien or someone that has been in the game for a while.
Old 04-10-2008, 06:39 AM
Former Moderator
B18C5-EH2's Avatar
Default Re: (blk92_d16)
One more bump before I reply today.
Old 04-10-2008, 07:07 AM
* B A N N E D *
spivt11's Avatar
Default Re: (B18C5-EH2)
Yeah I remember this discussion awhile ago. In my opinion 92-95 Civics (what I have knowledge on) have struts in the front and shocks in the rear. The whole spring and shock combined makes a strut is an interesting point, but falls short when you look at a Honda parts list. I don't know... I definetely want to hear a definitive answer.
Old 04-10-2008, 07:30 AM
Former Moderator
B18C5-EH2's Avatar
Default Re: (spivt11)
Okay I am posting this as the be all, end all reply to this question. the basis of my post relies on one key fact:
<FONT SIZE="7">Honda knows what to call their own parts</FONT>
Having laid that out I present to you, straight from Honda's own parts micrfiche/online parts catalogs, an exploded diagram of the suspension for a 1992 Civic DX 3dr just as an example:
They label part number 4/5 as a SHOCK ABSORBER UNIT
Who cares to argue against that?
I looked it up HERE - click the word "HERE"
Also for the rear let's check it out too:
Okay so again Honda calls it SHOCK ABSORBER UNIT, R
I found that HERE also - click the word "HERE"
Do you guys think they're wrong? Maybe they are, but if Honda calls it a "shock absorber" I think I will too.
Old 04-10-2008, 07:53 AM
...Thats your answer? Honda says so?
Im kinda disappointed. I was hoping for something a little more in-depth.
Old 04-10-2008, 08:02 AM
Former Moderator
B18C5-EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">...Thats your answer? Honda says so?
Ummm...okay?
I guess exploded diagrams and links to a Honda parts catalog aren't good enough?
What else can/should I say?
Old 04-10-2008, 08:12 AM
I was expecting a reason as to why theyre one over the other, not just diagrams and copied parts names.
Not that anyone ever did, but anyone can log on to Honda parts site and see theyre "shocks"
No offense...
Old 04-10-2008, 08:14 AM
* B A N N E D *
spivt11's Avatar
Nah I think they have struts in the front because the main difference between a shock and a strut is that struts provide provide structural support for the vehicle suspension, support the spring, and hold the tire in an aligned position. Additionally, they bear much of the side load placed on the vehicle's suspension. Shocks are mostly for their damping function which is also found in struts.
Old 04-10-2008, 08:20 AM
abs0Lut's Avatar
I've always called em struts, never knew there was a difference between the 2!
Old 04-10-2008, 08:22 AM
Ice78transam's Avatar
MacPherson struts. Plain and simple. We have a coil spring, and DAMPENERS. DAMPENERS are valved differently than SHOCKS because they perform slightly different tasks. SPRING+DAMPENER=MacPherson STRUT
Old 04-10-2008, 08:39 AM
blaze the chemi's Avatar
Default Re: (Ice78transam)
anti-climatic
Old 04-10-2008, 08:40 AM
bpr0422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ice78transam &raquo;</TD></TR><TR><TD CLASS="quote">MacPherson struts. Plain and simple. We have a coil spring, and DAMPENERS. DAMPENERS are valved differently than SHOCKS because they perform slightly different tasks. SPRING+DAMPENER=MacPherson STRUT </TD></TR></TABLE>
Shock Absorbers (damper): http://en.wikipedia.org/wiki/Shock_absorber
Strut: http://en.wikipedia.org/wiki/Strut
Dampers and Shocks are the same thing, can be interchanged... there no difference in the way they work... or any kind of performance...
Old 04-06-2009, 07:40 PM
redline870's Avatar
a strut is a specific style of a shock absorber. a "strut" is a shock absorber with a coil spring mounted on and around it. a "shock" is mounted by itself seperate from the spring. although it is a shock the correct terminology is a "STRUT."
Quick Reply: 92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Say.
