OEM sway bar bolt size on '95 EX.
My car still has the original OEM sway bars installed, well sort of. I seem to have misplaced the outer link nuts that attach the swaybar to the LCA on the front swaybar, as well as the bolts that run through the bracket and into the subframe.
Would any of you happen to know these part numbers or the actual threading for these off hand?
If you must know I had the whole front end disassembled, so losing those in this mess is not bad. Unfortunately, I had someone else helping me, so I'm sure he is the one that misplaced them.
Re: OEM sway bar bolt size on '95 EX.
^^ Isn't everything under the car M*x1.25? I have to order a helicoil kits, and everything seems to be 1.25 under there.
Dude, I was covered in power steering fluid when I posted that. I was trying to avoid getting it all over my computer. I have a waterproof keyboard for the garage, but not sure how it will hold up to fluids. Also Majestic has proven to be not 100% reliable for me. I have a coupe bumper and some other parts in the garage that display this...
Thanks for the sizes, I ordered them along with the exhaust studs and whatnot.
bleedblue94
Suspension & Brakes
14
03-29-2009 07:57 PM
24hourflipness
14
05-02-2003 09:53 AM
