humming sound coming out from cam gear
Old 04-07-2008, 10:24 AM
civic_tuned's Avatar
Default humming sound coming out from cam gear
Recently the head was repaired i had a blown head gasket. Car not heating up or anything. I still feel hoses hard until thermostat opens..which is usually when fans turn on.
After work was done i noticed humming sound coming from timing belt area. I took of the t. cover to hear better where sound was coming from. I noticed the noise was coming from the cam gear. I checked my timing belt and feels kinda tight. Kept on checking and im hearing wierd thunt noise also but dont know if its the water pump or tensioner.
Water pump is a year old as well as the tensioner.
Old 04-07-2008, 10:44 AM
Jim Truett's Avatar
Default Re: humming sound coming out from cam gear (civic_tuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_tuned &raquo;</TD></TR><TR><TD CLASS="quote"> I checked my timing belt and feels kinda tight. </TD></TR></TABLE>
Fix that first....
Old 04-07-2008, 11:06 AM
blk92_d16's Avatar
Define tight? Like you can't flex the belt at all? It can have up to 3/4ths an inch of deflection. If it's too tight, it can cause premature bearing failure in the water pump and such...
Old 04-08-2008, 06:14 AM
Default Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 &raquo;</TD></TR><TR><TD CLASS="quote">Define tight? Like you can't flex the belt at all? It can have up to 3/4ths an inch of deflection. If it's too tight, it can cause premature bearing failure in the water pump and such...</TD></TR></TABLE>
maybe your right...**** i didnt know water pumps had bearings.
Good to know!
how about the cam?
Old 04-08-2008, 05:03 PM
Default Re: (civic_tuned)
how about the cam gear?
or is it too tight whats causing hte problem?
NathanDC4
03-27-2016 11:43 PM
ezza
02-07-2010 11:58 AM
magicmyst98
03-22-2008 04:41 PM
riceburners1
13
06-02-2004 10:57 AM
-slow ej-
02-26-2004 09:38 AM
Quick Reply: humming sound coming out from cam gear
