whats SAI on alignment sheet?
Old 04-05-2008, 04:22 AM
static-x's Avatar
Default whats SAI on alignment sheet?
hey guys i was just checkin out my alignment sheet and noticed that the SAI was out of spec. left is 10.5 right 10.4 (specified range is 6.6 8.6) what is SAI? and could it effect handling?
Old 04-05-2008, 06:58 AM
PIC Performance's Avatar
Default Re: whats SAI on alignment sheet? (static-x)
SAI is steering axis inclination. Courtesy of http://www.mgf.ultimatemg.com/...f.htm:
Do you have a camber kit? That may cause your SAI to be out of spec.
Old 04-05-2008, 02:26 PM
static-x's Avatar
Default Re: whats SAI on alignment sheet? (PIC Performance)
no camber kit. -3.0 on left and 2.9 on right. toe at 0.00 and 0.01 on right. caster 3.4 and 4.0 right
Old 04-05-2008, 06:00 PM
What is your included angle? why is caster off? Has the car ever been in an accident?
Old 04-05-2008, 08:45 PM
static-x's Avatar
included angle is 7.5 (RANGE 5.6 9.6) Car has never been in a accident since ive owned it and thats been 10yrs. dont kno why caster is differ on each side. its within spec tho. maybe one of the radius rods isnt tightned as far as the other?
Old 04-06-2008, 04:13 AM
b16a4's Avatar
my car has been in an accident, and castor is not the same.
is that a bad thing?
Old 04-06-2008, 09:14 PM
Spracer03's Avatar
usually caster is around .5 degree higher on the right to help against pulling due to the crown on the road... if it is equal on both sides that usually leads to a pull
kodythejdmkid
Suspension & Brakes
24
07-08-2012 11:38 PM
rodvang
11
01-18-2006 08:10 PM
nathanie1
10
02-26-2005 09:39 PM
spencedogg
12-05-2003 05:25 PM
Quick Reply: whats SAI on alignment sheet?
