Old 04-01-2008, 08:04 PM   #1
ShinotakuX
ShinotakuX's Avatar
Default what is the difference between USDM headlights and JDM headlights in terms of beam pattern?
i would like to change headlights, but im having difficulty in deciding which one to get, I dont want to regret buying the wrong ones, so help me out. Also does HIDs run better in JDM headlights? thank u.
ShinotakuX is offline   Reply With Quote
Old 04-01-2008, 08:23 PM   #2
BlueIntegraBoy
1998 Acura Integra
BlueIntegraBoy's Avatar
iTrader Rating: (3)
Default Re: what is the difference between USDM headlights and JDM headlights in terms of beam pattern? (Shi
If you are getting 96-00 JDM Civic headlights, they don't have the bulb shield. So if you are running HID's, you'll be blinding everyone.
インテグラ タイプR 98-0425
07 Pilot EX-L w/Navi & 4WD, 07 Fit Sport
BlueIntegraBoy is offline   Reply With Quote
Old 04-01-2008, 08:26 PM   #3
ejoner
ejoner's Avatar
Send a message via AIM to ejoner
Also the jdm headlights beam is aimed opposite of the usdm one
ejoner is offline   Reply With Quote
Old 04-01-2008, 11:24 PM   #4
NOFX
H-T White Ops
NOFX's Avatar
From another thread where I answered a similar question.
Originally Posted by 5lugSlug
whats the difference between 96-98 SiR headlights and just
regular 96-98 headlights?
Originally Posted by NOFX
SiR is a trim that denotes several different vehicles in several different countries. This means they have several different headlights due to local laws.
The USDM headlights have amber bar reflectors along the bottom of the turn signal housing and an amber cap on top of the turn signal bulb socket. They also have kind of a t-shaped diffuser (the little silver cap that sits in front of the headlight bulb), with the top of the "t" curving down on either side. USDM headlights are made so that the passenger (right, sitting inside car) headlight kind of aims a little bit higher and outwards so the driver can view people and objects along the side of the road. USDM '96-'98 Civic headlights were made by Stanley and have a stamp on the front denoting this.
JDM headlights ('96-'98 non-Type R) have no reflector along the bottom of the turn signal and no amber cap on top of the turn signal bulb socket. They have no diffuser. They do have a city light socket. Since Japanese vehicles are RHD, the passenger (left, sitting inside car) headlight does the same thing the right headlight does in the US. JDM '96-'98 Civic headlights were also made by Stanley and have a stamp on the front denoting this.
European headlights ('96-'98) (besides ones from the UK and Ireland) also have no reflector along the bottom of the turn signal and no amber cap on top of the turn signal bulb socket. They have a full diffuser that's shaped like a circle. They do have a city light socket. These cars came with the LHD pattern. EDM '96-'98 Civic headlights were made by Valeo (unless they're they're from the UK or Ireland) and have a stamp on the front denoting this.***
Headlights from the UK (and Ireland too, I suspect) ('96-'98) also have no reflector along the bottom of the turn signal and no amber cap on top of the turn signal bulb socket. They also have kind of a t-shaped diffuser (the little silver cap that sits in front of the headlight bulb), with the top of the "t" curving down on either side. They do have a city light socket. Headlights from Ireland and the UK have the RHD headlight beam pattern. The UK headlights were made by Stanley and have a stamp on the front denoting this. I'm not yet sure of who made the Irish headlights.
I think I got most of it.
More research has found the following:
UK, Ireland
RHD
Valeo
Germany, Holland
LHD
Valeo
??, Arabian countries
LHD
Stanley
North Europe (Finland, Norway, Sweden, Switzerland)
LHD
Stanley
Australia, New Zealand, Thailand, Mozambique, Surinam, Korea, Indonesia, Malaysia, Hong Kong, Sarawak, Sabah, Norfolk, Cyprus, Malta, Sudan, South Africa, Guana, Papua, Barbados, Pakistan, Seychelles, British Guiana, Malawi, Itthihad, Honiara,
RHD
Stanley
Modified by NOFX at 1:13 AM 4/2/2008
I AM NOT YOUR FRIEND (unless I am). DO NOT PM ME. _
If you make a thread then (1) more people will be able to answer and (2) the information can help others!
NOFX is offline   Reply With Quote
Old 04-01-2008, 11:36 PM   #5
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
Default Re: (NOFX)
That's odd that Stanley makes all of the markets except Europe (Valeo). I would think the UK and Australia share the same headlights.
インテグラ タイプR 98-0425
Old 04-01-2008, 11:49 PM   #6
NOFX
H-T White Ops
NOFX's Avatar
Default Re: (BlueIntegraBoy)
I'd have to check the part numbers in each category. The "EDM" Epc does not support searches as easily as the US one does. Perhaps I will sit down and do this tomorrow, but Eran is calling me to bed.
Old 04-02-2008, 12:14 AM   #7
NOFX
H-T White Ops
NOFX's Avatar
Found more. It looks like UK, Ireland, Germany and Holland all use lights made by Valeo, but the British and Irish ones are RHD while the German and Dutch are LHD. Other EDM lights should be made by Stanley.
Old 04-02-2008, 12:24 AM   #8
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
Default Re: (NOFX)
From these pics, the AUDM Civic headlights look like UKDM.
An AUDM Civic VTI-R EM1 (I wish NA got a Taffeta White EM1)
More AUDM headlight pics
Modified by BlueIntegraBoy at 10:36 PM 4/1/2008
インテグラ タイプR 98-0425
Old 04-02-2008, 07:12 AM   #9
NOFX
H-T White Ops
NOFX's Avatar
Valeo and Stanley lights can look the same, but I haven't seen the same diffusers on them yet. I'm thinking this could either be a manufacturer difference or a market difference.
Old 09-08-2009, 02:19 AM   #10
richyef9
2 questions doees anyone know what marke central america is in for exampe guatemala el salvador and honduras cuz they get some nice jap cars we dont see here so obviusly its not usdm
2nd question is there a size diference on the headlights from a 1988 to 1991 civic hatch usdm to jdm ????
richyef9 is offline   Reply With Quote
bulb, cars, civic, difference, england, europe, germany, headlight, headlights, jdm, reflector, sir, sockets, type, uk, valeo
