Old 03-25-2008, 06:49 AM   #1
battosai
battosai's Avatar
Default Blowing blue smoke from my exhaust
my 1995 gsr is blowing blue smoke
what do i need to do to fix this?
should i not run my car hard?
how much is it gunna cost?
battosai is offline   Reply With Quote
Old 03-25-2008, 06:52 AM   #2
dipsy
2008 BMW Z4
My Garage
dipsy's Avatar
bieberhole69 bieberhole69 bieberhole69 bieberhole69 bieberhole69
Send a message via ICQ to dipsy Send a message via AIM to dipsy Send a message via Yahoo to dipsy Send a message via Skype™ to dipsy
Default Re: Blowing blue smoke from my exhaust (battosai)
get a leak down and compression test. More than likely your not going to like the results and it will cost you a couple hundred bucks to fix. I wouldnt drive the car hard until you find out what needs to be fixed. Good luck Click the image to open in full size.
Originally Posted by GoodEyeSniper View Post
jailbait is best bait.
Originally Posted by Brice.Hayden View Post
I don't even barrel roll, bro.
dipsy is offline   Reply With Quote
Old 03-25-2008, 06:54 AM   #3
jhammond_82
Reject Papi
jhammond_82's Avatar
iTrader Rating: (1)
Send a message via AIM to jhammond_82
Default Re: Blowing blue smoke from my exhaust (dipsy)
how much blue smoke? tons or just every now and again? if its constant, you got oil burning issues. if its random, its like the dodge vans, it shouldn't hurt to drive it like that.
RSOG
HI! SOCIETY
BTS
jhammond_82 is offline   Reply With Quote
Old 03-25-2008, 07:13 AM   #4
battosai
battosai's Avatar
Default Re: Blowing blue smoke from my exhaust (jhammond_82)
i think its only when im driving my car hard, and it does smell like oil is burning
Old 03-25-2008, 07:39 AM   #5
4g63powered
4g63powered's Avatar
Send a message via AIM to 4g63powered
Do a compression test. Blue smoke indicates oil, and since it's only during hard driving it could be the rings. If it's only during warm up, possibly the valve seals.
-Brad
09 MazdaSpeed3
86 Porsche 944
4g63powered is offline   Reply With Quote
Old 03-25-2008, 03:46 PM   #6
vshavoc
vshavoc's Avatar
Default Re: Blowing blue smoke from my exhaust (4g63powered)
Yea but the oil rings going bad may not show on the compression test. I had the same issue and did a compression test and it was good across the board. It was indeed the oil rings though. High compression honda motors push oil through the pcv valve when they are running hard and it makes it smoke in the top end. That's why alot of guys put oil catch cans on their high compression or FI cars. If you go to the races alot you see alot of hondas smoking in the top end. And it's blue smoke not black so you know its oil burning. That reminds me I need to get an oil catch can asap.
Vouches: darkdementshun, mac_24_seven, Evs-One, HondaBoy954, ph3ar, SeVeNisOnE, wing.jai, Crxlsturbo, PYITR01, Project S.A.M, luv2boost, 94eg'n, Arct, crookie03, Janz99, Eydreeyun, boo5tedteg94, SoTexDC2, dc2_916, 93civicsleeper, typer76, and tons more!
vshavoc is offline   Reply With Quote
Old 03-25-2008, 04:02 PM   #7
Schister66
Man U FTW
Schister66's Avatar
Blue smoke on acceleration is oil burning due to blowby (piston rings). You should be able to see this with a compression and leakdown test. In order to fix it, you'd have to tear it down, more than likely overbore .020", and rebuild.
2006 SGM STi
Bullseye Powered 1999 GSR - Sold
Schister66 is offline   Reply With Quote
Old 03-25-2008, 05:55 PM   #8
gnccracer18
gnccracer18's Avatar
Send a message via AIM to gnccracer18
probably a sign of a worn out motor. new rings and some head work should fix it i guess maybe pistons too.
gnccracer18 is offline   Reply With Quote
Old 03-25-2008, 08:30 PM   #9
thanh4o8
thanh4o8's Avatar
you have burnt valves
Grand Sport Racing Sedan http://images.honda-tech.com/set1/smile/embeer.gif
- -**DB Squad Member #281**- -
thanh4o8 is offline   Reply With Quote
Old 03-25-2008, 09:19 PM   #10
Schister66
Man U FTW
Schister66's Avatar
Default Re: (thanh4o8)
Care to elaborate??
Burning oil on acceleration is bad rings
Burning oil in deceleration is a sign of bad valve seals
....i'm not seeing you came to that conclusion
2006 SGM STi
Old 03-25-2008, 09:45 PM   #11
thanh4o8
thanh4o8's Avatar
Default Re: (Schister66)
i was told from a shop that if you have blue smoke come out when ur at high rpm or when your in vtec, some of your valves seals are burnt. but im not 100% on that
Old 03-25-2008, 10:29 PM   #12
ex1z7
ex1z7's Avatar
If it's blue till it warms up, it's valves.
If it's always blue. It's rings.
That's my understanding..
'90 DA9 - sold
'92 DB2 - sold
'93 pre-Taco
ex1z7 is offline   Reply With Quote
Old 03-25-2008, 11:57 PM   #13
~steph~
~steph~'s Avatar
Default Re: (ex1z7)
sounds like ur valve seals are leaking do a leakdown Click the image to open in full size. Click the image to open in full size.
~steph~ is offline   Reply With Quote
Old 03-26-2008, 04:41 AM   #14
Schister66
Man U FTW
Schister66's Avatar
For everyone offering suggestions OTHER than piston rings, here's your first lesson for the day. Take clues from the OP...like the quote above
During hard acceleration, blue smoke is seen. This is caused by increased crank case pressure due to blow-by which means the piston rings are bad or the cylinders are somewhat scored.
If he would have noticed oil burn on startup and during instances of higher vacuum (closed throttle deceleration in high vac), then the suggestion of bad valve guides would have been appropriate.
Burnt exhaust valves would show an overall loss of compression due to them not sealing with the head anymore. A compression and leakdown would surely put this theory to rest once the results show a consistant overall compression test and a similar loss during the leakdown which would indicate rings.
**I dont mean to sound like an ***, but i've given the applicable suggestions only to be followed by the wrong suggestion. I've gone to school for this crap and know a little about it...listen and eventually you may learn something**
2006 SGM STi
Old 04-03-2008, 03:49 PM   #15
vshavoc
vshavoc's Avatar
Default Re: Blowing blue smoke from my exhaust (Schister66)
And all I'm saying is there is an oil ring and there are compression rings. My compression was fine but my oil ring on number two cylinder was shot. There was burnt oil all over that piston, but it still showed solid compression. I'm now running a daily drivable all motor build with 11.8-1 c/r and it burns oil if I drive it hard. It's only got 15,000 miles on it and it doesn't burn it unless I drive it hard. I've done alot of research to find out my problem because I was worried that the rings didn't seat right or something was wrong but then learned about the catch can concept and how it blows oil through the pcv because of higher crankcase pressure.
blowing, blue, compression, constant, crf70, crx, exhaust, high, honda, hondas, rpm, smoke, smokes, test, throws
