Old 03-24-2008, 11:40 AM   #1
richard9
richard9's Avatar
Default How to replace postive battery cable for 1999 Accord V6
Hello,
Does anyone know what is the steps to replace the positve battery cable for a
1999 honda accord V6. Is there any precautionaries that I need to take.
I know about writing down the radio code.
Thanks for any suggestions. Click the image to open in full size.
richard9 is offline   Reply With Quote
Old 03-24-2008, 02:05 PM   #2
Perfectionist
Default Re: How to replace postive battery cable for 1999 Accord V6 (richard9)
Remove the negative cable first. This will eliminate any possibility of accidently causing a short to ground while working on the postive cable connections.
After you're all done, fire up the engine, and with ALL electrical loads turned off (lights, radio, fan,etc) let it idle without touching the gas pedal until it warms up. This is refered to as the "idle learn" proceedure. I made the mistake of replacing the battery in an auto parts parking lot and jumping right on the freeway to go home afterwards. The engine died the off ramp and for a few stops afterwards until it straightened out.
2003 PWP RSX-type S
"Need Help" or "Quick Question" = NO CLICK
"I may not always be right, BUT I'm never wrong."
Perfectionist is offline   Reply With Quote
Old 03-25-2008, 10:55 AM   #3
richard9
richard9's Avatar
I believe one end goes to the starter solenoid. The other line end is for the fuse box ?? Are there any precuations or resets, or other items I need to do. I am familier with resetting the radio code.
Old 03-25-2008, 11:35 AM   #4
richard9
richard9's Avatar
http://www.hondaautomotivepart...=null
1999, 2002, 92, accord, battery, cable, cables, ground, honda, positive, removing, replace, replacement, replacing, v6
