Old 03-02-2008, 10:27 AM   #1
thiscivicuser
thiscivicuser's Avatar
Send a message via AIM to thiscivicuser
Default what kind of gear oil on a manual transmission
what kind of gear oil do i use on a manual tranmission civic 97 at 120,000.
thiscivicuser is offline   Reply With Quote
Old 03-02-2008, 10:44 AM   #2
jax97hx
jax97hx's Avatar
Send a message via AIM to jax97hx
Default Re: what kind of gear oil on a manual transmission (thiscivicuser)
go to a honda dealer and buy 2 quarts of mtf = manual tanny fluid Click the image to open in full size.
97 civic hx daily, boosted n built vitara z6
1975 lt/z28 camaro
jax97hx is offline   Reply With Quote
Old 03-02-2008, 10:58 AM   #3
thiscivicuser
Default Re: what kind of gear oil on a manual transmission (jax97hx)
can't i just use the ones at pep boys or auto zone they have like 75-90w or 95 to 140w i just want to know wut kind of wegiht can i use.
Old 03-02-2008, 11:12 AM   #4
kieran84
kieran84's Avatar
ive heard 10w40 engine oil is great for honda trans
kieran84 is offline   Reply With Quote
Old 03-02-2008, 11:25 AM   #5
sicones
sicones's Avatar
Default Re: what kind of gear oil on a manual transmission (kieran84)
regular 10w30 motor oil or honda MTF, use gear oil if you want to replace the transmission
sicones is offline   Reply With Quote
Old 03-02-2008, 11:32 AM   #6
dannycraq
dannycraq's Avatar
i use 10w30 motor oil, works great
dannycraq is offline   Reply With Quote
Old 03-02-2008, 12:02 PM   #7
NOFX
H-T White Ops
NOFX's Avatar
just stick to the manufacturer's recommendation (Honda MTF). It's not expensive and it's not like you're going to be buying it often.
I AM NOT YOUR FRIEND (unless I am). DO NOT PM ME. _
If you make a thread then (1) more people will be able to answer and (2) the information can help others!
NOFX is offline   Reply With Quote
Old 03-02-2008, 12:03 PM   #8
n1_egsex
* B A N N E D *
Send a message via AIM to n1_egsex
Default Re: (NOFX)
Honda MTF is like 4 bucks a quart, 70w90 or wahtever at autozone is too thick
n1_egsex is offline   Reply With Quote
Old 03-02-2008, 12:04 PM   #9
Blzdeep
1994 Honda Civic
My Garage
Blzdeep's Avatar
94 Civic ex 2 door,
So Cal.
<!-- Copied from MySpace.com -->
Find me on MySpace and be my friend!
Blzdeep is offline   Reply With Quote
Old 03-02-2008, 12:23 PM   #10
thedanny88
thedanny88's Avatar
Send a message via AIM to thedanny88
Default Re: what kind of gear oil on a manual transmission (Blzdeep)
10w30 Click the image to open in full size.
85 rx7 12a sold, 85 gti 8v sold, 89 yota 4wd sold, 97 hatch mini me ballin, 90 miata
thedanny88 is offline   Reply With Quote
Old 03-02-2008, 12:51 PM   #11
Crx Jimmy
Crx Jimmy's Avatar
Default Re: what kind of gear oil on a manual transmission (sicones)
??^^ why would gear oil make the transmission break or go bad? I dont think you know what you are talking about. Almost every aftermarket LSD(ATS, Kaaz, Cusco, ect) requires you to use their own friction modified 80-90 gear oil. Most people that have these diffs run them hard on the race tracks and you dont see them blowing up trannys from using gear oil. WTF?
Crx Jimmy is offline   Reply With Quote
Old 03-02-2008, 01:08 PM   #12
thursday
thursday's Avatar
Send a message via AIM to thursday
Default Re: what kind of gear oil on a manual transmission (Crx Jimmy)
taken DIRECTLY from a crx fsm
"Use only SAE 10w-30 or 10w-40 oil rated SE or SF grade"
i did read on a kaaz installation that you are supposed to use 80/90w gl-5 lsd oil, i think they are generalizing towards the rwd transmission applications that use this weight oil stock.
http://honda-tech.com/zerothread?id=1875353
dont use heavy weight oil in a honda transaxle (.)
highwaystar
93 eg
96 ek
69 510
84 4runner
visit my brother deviouska and the pgmfi.org of nissans at hybridka
thursday is offline   Reply With Quote
Old 03-02-2008, 01:43 PM   #13
sicones
sicones's Avatar
I don't think YOU know what your talking about Click the image to open in full size.
READ!!
http://www.honda-tech.com/zerothread?id=1763113
Old 03-02-2008, 07:16 PM   #14
Crx Jimmy
Crx Jimmy's Avatar
READ!!
Yeah I did! they said they DO run gear oil in lsd tranny's Click the image to open in full size. mista bone even dsaid to run syncormesh which is a gear oil Click the image to open in full size.
Old 03-02-2008, 07:28 PM   #15
jax97hx
jax97hx's Avatar
THE FACT IS honda mtf is not that expensive and it is the BEST choice for a stock non lsd tranny so quit being difficult and go buy some.
1975 lt/z28 camaro
Old 03-03-2008, 04:10 AM   #16
StorminMatt
Synchromesh may be gear oil in the sense that it is used in transmissions. But it is NOT the same thing as the GL-4/GL-5 high viscosity gear oils (ie 85W90, 85W140, etc) that are used on old-school transmissions. These oils are WAYYYY too thick for Honda transmissions (and MANY other newer manual transmissions), and will not be able to penetrate into tight spaces to lubricate MANY of the bearings. SO stay away from the thick stuff. Remember that Honda's original recommendation for these cars is 10W30 or 10W40 motor oil. There was no Honda MTF at the time. Of course, Honda MTF is a GREAT lubricant, as is synchromesh. Both of these oils are low viscosity gear oils. As for using 80W90 oil with an LSD, from what I have seen MANY of these higher end oils are actually quite a bit lighter than your typical GL-4/GL-5 85W90.
VTEC or non-VTEC? BOTH!
1988 B20Z Civic DX 4DR Sedan
1988 B18C5 CRX DX
1995 Allmotor GSR (All motor, no car!)
Coming soon: 1989 D15Z1 Civic STD HB - The Gas Saver!
StorminMatt is offline   Reply With Quote
Old 03-03-2008, 04:17 AM   #17
cehcivic15
cehcivic15's Avatar
Default Re: what kind of gear oil on a manual transmission (StorminMatt)
i like to run 10w40 with some lucas
Rev hard or go home
My Ej2 Build
http://honda-tech.com/showthread.php?t=2602217
cehcivic15 is offline   Reply With Quote
Old 03-03-2008, 08:45 PM   #18
thursday
thursday's Avatar
i've actually ruined a vx tranny from running gear oil in it.
highwaystar
93 eg
96 ek
69 510
84 4runner
1998, 94, 96, civic, crx, dxgear, gear, honda, lsd, lucas, manual, oil, prelude, transmission, viscosity
