Old 02-26-2008, 04:14 PM   #1
davey5300
1994 Honda Accord
davey5300's Avatar
Send a message via AIM to davey5300
Default hazard light problems
My 94 Accord Ex has a problem with the hazard lights.
when I turn them on, they will flash for a little while, then they will freeze. the lights will be on, but it's not flashing. It will flash again for a few seconds then it will stop again. then they will flash like once every so often, then they flash off, and won't flash anymore. if I turn them off and turn them back on, they just flash on. and when it's doing that, the directionals are the same. onece I've had the hazards off for a while, the directinals will work fine. Please help me for I need the hazards for work ( i deliver news papers, so I'm driving on the wrong side of the road.)
1994 CD5 F22B1 4 doors, 4 Cylinders, 4 rims, 5 speeds
Remember folks SPEED KILLS!! so drive a Ford and live forever
davey5300 is offline   Reply With Quote
Old 02-26-2008, 05:29 PM   #2
hondadude
hondadude's Avatar
Default Re: hazard light problems (davey5300)
Hmmmm, strange days indeed Click the image to open in full size.
the hazards and the turn signal use the same flasher unit, so if the turn signals work normally and the hazards are the problem, I would be suspect that the hazard switch has a problem.
Year and model Helps get better info
My crystal ball is out of service,and
I failed Clairvoyance 101 class
hondadude is offline   Reply With Quote
Old 02-27-2008, 06:56 AM   #3
professorman
Default Re: hazard light problems (hondadude)
Humm... I think it might be your flasher is getting weak. Try changing it with one from a junk yard and see what that does.
I had a flasher problem with my 93 Prelude. It might be different, but the more you read, the more you learn.
http://www.honda-tech.com/zerothread?id=1618020
94 5spd Accord -270k | 99 Accord Auto -120k | 00 BMW 528i | 03 Suzuki GSX-R1000 | 04 Honda Aquatrax Jet Ski
RoopsPhoto.com | facebook.com/RoopsPhotography
professorman is offline   Reply With Quote
Old 02-27-2008, 09:17 AM   #4
davey5300
1994 Honda Accord
davey5300's Avatar
Default Re: hazard light problems (professorman)
o.k I'll try that but 1 question: Where is the flasher module? I think I know where it is, but i'm not sure.
Old 02-27-2008, 09:25 AM   #5
billyrusa
billyrusa's Avatar
It is attached to the underdash fuse/relay box. Remove the driver's side kick panel, you will be able to find the fuse box. The flasher is integrated with other control circuits in an Integrated Control Unit. This ICU box is just above the fuses in the fuse box. Disconnect the wire connector to it and then you can unplug it from the fuse box.
billyrusa is offline   Reply With Quote
1994, 90, accord, control, flashers, hazard, hazards, honda, integrated, light, ligth, problem, problems, switch, unit
