quick question ... maintenance light blinking but goes away
Old 02-20-2008, 05:12 PM
_uh_oh_'s Avatar
Default quick question ... maintenance light blinking but goes away
when i start my car the maintenance light goes on and blinks for a couple of seconds and then goes away but it only happened after i installed my springs would that have something to do with it ?
Old 02-20-2008, 05:22 PM
hondalove323's Avatar
Default Re: quick question ... maintenance light blinking but goes away (_uh_oh_)
no the maintenance light only comes on when you need an oil change, air filter replacement, brake fluid, etc.. but if it doesnt stay on than theres no problem
Old 02-20-2008, 05:49 PM
_uh_oh_'s Avatar
Default Re: quick question ... maintenance light blinking but goes away (hondalove323)
i checked my brake fluid its still decently full and i just had an oil change i'm guessing it could be my air filter ? cause i hardly doubt that the check engine light would go on for a spring change ...
Old 02-20-2008, 05:52 PM
yeah but this could also be any fluids.. power steering, clutch fluid
and yeah you should also check your air filter
but i dont think anything is wrong with it since the light doesnt stay on..
Old 02-20-2008, 06:12 PM
1llmatic's Avatar
FYI: the maintenance required light has nothing to do with anything with your engine. It is preprogrammed by Honda to remind you to service the car after a certain mileage.
The CEL (Check Engine Light) is the light that you should worry about. If this light is on or flashing it means that something is wrong with your car.
The CEL looks like this:
Old 02-20-2008, 06:20 PM
i-VTEC_DOHC's Avatar
Default Re: quick question ... maintenance light blinking but goes away (1llmatic)
Old 02-20-2008, 07:12 PM
koketsuEM2's Avatar
30,000
and I think the 65,000 marks the light flashes
not 100% sure but mine started flashing recently at near 65,000miles
Old 02-21-2008, 06:31 AM
InanimateCarbonRod's Avatar
Default Re: (koketsuEM2)
If you don't reset the Maint' Req'd light, it will stay solid. There is a reset procedure in the FAQ.
Old 02-21-2008, 07:45 AM
_uh_oh_'s Avatar
Default Re: (InanimateCarbonRod)
awesome thanks guys very use full ... yea i checked on the faqs thread its just a reminder but i don't think i should worry i did my complete maintenance earlier than its supposed to be thanks !
Old 02-21-2008, 05:24 PM
dmorris05's Avatar
Default Re: (_uh_oh_)
it comes on every 5000 for regular maint and needs to be reset it is easy to do.
EFz6er
01-21-2009 10:41 AM
jizzer671
11-30-2005 09:31 AM
nc_mx_kid
05-03-2005 03:24 PM
darkd1gt
03-09-2005 05:15 AM
Quick Reply: quick question ... maintenance light blinking but goes away
