Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 02-17-2008, 07:10 PM   #1
philliedawg
philliedawg's Avatar
Default LS vtec tap head??
Before anyone say "search it first before putting it up for discussion"; I did do the search but came up negative. My questions is when tapping and plugging the vtec head; what EXACYLY mean by what it says. Well, I mean can anyone direct me to or show with pictures how to start drilling to end?????
and...
My GE LS/vtec kit came with two allen wrench plugs..Is both plugs going to be use in the build or is the other one was sent for an "in case I lose the original one??"
I sure am confused, and I think i'm making it a lot more harder than is originally is. Can a expert builder help me please.. It's my first build so I sure dont wanna mess up..kinda on a tight budget..THANKS!!!!
Dawggy Styleeee every once in a while!!!
philliedawg is offline   Reply With Quote
Old 02-17-2008, 09:52 PM   #2
poppypizza
poppypizza's Avatar
Default Re: LS vtec tap head?? (philliedawg)
pretty sure this will clear it up,,,,
http://honda-tech.com/zerothread/1676914
A sticky'd thread.. Click the image to open in full size.
92 Hatch Ls-vtec
Vouche thread http://hondamarketplace.com/showthre...5#post38325155
poppypizza is offline   Reply With Quote
Old 02-18-2008, 04:15 AM   #3
philliedawg
Default Re: LS vtec tap head?? (poppypizza)
I've seen this and i printed it out and it seemed to be like my "bible" by all means. But reading to that part, Bambam just said tap and plug. Nothing really detailing and a DUmmie like me could pretty much do start to finish. thanks tho, but i've read that thread almost 40-50 times on the popper. Any more help guys??!?!?!!?!!
Old 02-18-2008, 07:24 AM   #4
CerealKiller
CerealKiller's Avatar
didn't the GE kit come with instructions?
If not, all you have to do is put the pipe tap into the small hole on the intake side to the far right corner. Also one plug is for the head and the other is for the sandwich plate. You can also try contacting GE and have them email or send you a instruction sheet.
CerealKiller is offline   Reply With Quote
Old 02-18-2008, 01:28 PM   #5
philliedawg
Default Re: LS vtec tap head?? (CerealKiller)
so i don't have to pre-drill the hole first??...Just go and use the tap and start drilling??...
Old 02-18-2008, 01:51 PM   #6
CerealKiller
no, don't need to drill, that's the whole point on GE's kit. NO drilling required. torque pipe tap in, then screw on flush plug.
Old 02-18-2008, 02:07 PM   #7
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
hmmm if i didnt use the full-race kit Click the image to open in full size. i would be able to help you...
Neptune RTP - HrTuning.com
www.Xenocron.com
95 GSR Partout http://hondamarketplace.com/showthread.php?t=3028136
mouab18c1 is offline   Reply With Quote
Old 02-18-2008, 02:13 PM   #8
philliedawg
Thanks man. I'll give a try and i'll let ya know..Thanks again!
Old 02-18-2008, 02:29 PM   #9
0Golden Eagle
Golden Eagle Manufacturing
Send a message via AIM to Golden Eagle
the extra plug is for the sandwich plate there are 2 ports in it if you don't use them both we give you a plug to block one of them off if you get stuck fill free to pm me or give me a call 909-592-43111 ext 102 we always more then happy to help out
Golden Eagle is offline   Reply With Quote
Old 02-22-2008, 04:23 PM   #10
philliedawg
Default Re: LS vtec tap head?? (Golden Eagle)
you know....i tried just start tapping the head. and as i was doing that...wondering...how is the tap being flat going into the flat hole in the head.???...flat surface against flat surface..??..??....my tap is suppose to be flat at the tip right?? and there is a way of doing a tapping being hand????...???...i'm confused man....help dudesss..
Old 02-22-2008, 06:55 PM   #11
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
make sure you have the right hole...get a 1/8 tap at..and make sure the thread is the same as ur plug...just tap it by hand....should work..thats how i tapped my gsr head....
www.Xenocron.com
Old 02-22-2008, 08:56 PM   #12
philliedawg
Default Re: LS vtec tap head?? (mouab18c1)
Dude i checked, double checked, and tripled and quad-triple checked if its the right hole, and it IS!!!....Is the tap that GE sent you flat at the point that goes into the head flat???...
Old 02-25-2008, 08:34 AM   #13
0Golden Eagle
all taps are flat at the head. give me a call so we can go over this again
Old 02-25-2008, 09:02 PM   #14
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
Picture talks Click the image to open in full size.
www.Xenocron.com
drilling, engine, gsr, head, hole, kit, location, ls, lsvtec, tap, taphead, tapped, tapping, vtec, whats
