LS Cams...whats best for my setup
I have a b18a1 with b16 pistons and rods, i/h/e, and chipped ecu.
i am buying a built head that has been ported, the guy whos selling it made about 170whp on his ls with a stock bottom end and Weber cams, but its coming without cams. With the bump in compression im hoping to make around 180 to the wheels.
He also has a set of jg 301 cams that he is selling, i also saw bisi does regrinds for cheap, and there is the crowers.
Im basically looking for the cam thats going to make the most power. Will probably run a 68mm TB with a skunk 2 manifold.
Thanks guys.
Thanks guys.
Re: LS Cams...whats best for my setup
its really up to you. Iv seen alot of good numbers out of crower 404's, not to mention how cheap I can get them through my local shop
Same build with same goals, and you're from MD lol, I'm going to be running Brian Crower Stage 2's in mine. 68mm TB and a intake manifold as well.
i found a good deal on some JG 301's and some crower 403s
still undecided at this point
drifter19
04-06-2008 10:16 AM
