Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 02-15-2008, 05:45 AM   #1
civiconfire
civiconfire's Avatar
Default LS cams vs. B20 cams?
from what i understand Ls cams are a little better than the stock b20.
i have a b20... and some cams from a 90, or 91 DA. i know it cant be much of a difference, but it wont cost me anything but cam seals, a valve cover gasket, and my time. so anyone have any input on this? cam specs?
http://srcracing.com/
12.1 @ 118 mph EG hatch street car.built 1.8L gsr + nitrous on E85
225/50/15 MT ET street tires
civiconfire is offline   Reply With Quote
Old 02-15-2008, 12:57 PM   #2
Natural Aspirations
Natural Aspirations's Avatar
Send a message via AIM to Natural Aspirations
The obd-2 LS cams are "said" to be a little bigger than the B20's. VERY VERY small difference. Once again it only applys to the newer cams.
"One test result is worth one thousand expert opinions."
Natural Aspirations is offline   Reply With Quote
Old 02-15-2008, 01:05 PM   #3
Rocket
Default Re: (Natural Aspirations)
Not worth it. Lash to 0.006/0.007 and advance the intake a lil FTMW.
Pho-ShizaaaY. PopoZ-YOW!!!
Rocket is offline   Reply With Quote
Old 02-15-2008, 04:20 PM   #4
JCushing
JCushing's Avatar
Send a message via AIM to JCushing
Default Re: (Master of the Universe)
a set of regrinds would be worth your time, messing around with stock cams isnt. however if you insist put in either obd2 LS cams or B20Z cams... b20b cams are the smallest non vtec cams there are Click the image to open in full size.
84.5mm b20, 11.5:1 cr, non-vtec P8R head with crower 404's for sale!
http://www.hondamarketplace.com/show...1#post42073696
JCushing is offline   Reply With Quote
Old 02-15-2008, 08:43 PM   #5
civiconfire
alright. thanks guys im just going to leave it as is. i do not have the obd2 cams they are obd0.
Old 02-16-2008, 02:27 PM   #6
4door93civic
4door93civic's Avatar
Send a message via AIM to 4door93civic
Default Re: (civiconfire)
doesnt make sense. my buddy has a ls out of a 90 integra we ran stock cams then 94-up cams then b20 cams the car made the most power with the b20 cams.
R.I.P 2000 ebp em1 with built ls/vtec
myspace http://www.myspace.com/jtellyfin
4door93civic is offline   Reply With Quote
Old 02-16-2008, 02:50 PM   #7
Combustion Contraption
Combustion Contraption's Avatar
Send a message via AIM to Combustion Contraption
Default Re: (4door93civic)
Just knowing one set of cams is "bigger" than the other really doesnt tell you everything you need to know. I dont know if the LSA of all those cams is the same or not. Tighter LSA's usually make more peak power while sacrificing low and mid. Bigger engines can get away with tighter LSA's because they have more cylinder to feed. Maybe the b20 cams have a tighter LSA and thats why they made more peak power on your friends LS despite being "smaller".
EARL LASKEY, YOU WILL BE MISSED
CCCylinderheads.com
Combustion Contraption is offline   Reply With Quote
Old 02-16-2008, 04:08 PM   #8
JCushing
JCushing's Avatar
Default Re: (Combustion Contraption)
maybe its because he didnt say wich b20 cams he was using
b20b cams and b20z cams are totally different. b20b cams have only like 9mm lift... b20z have 10mm
Old 02-16-2008, 05:16 PM   #9
4door93civic
Default Re: (JCushing)
sorry we were running b20z cams...i was tyold they were jdm b20 cams but im not sure.
Old 04-26-2008, 06:43 PM   #10
fin781
fin781's Avatar
jdm b20 cams have a 15mm lift, only in japan. Click the image to open in full size. use em. j/k im running a b20b4 in my crx and i swapped to some ls cams just because they were free, never even ran the b20 ones. but 1mm your really just noit going to be able to tell, notlike vetech Click the image to open in full size. . damn ill drink another Click the image to open in full size. Click the image to open in full size.
Want to buy : http://www.hondamarketplace.com/show...4#post43917254
1990 CR-X Semi-built LS. Panty dropper
fin781 is offline   Reply With Quote
Old 04-27-2008, 05:58 AM   #11
JCushing
JCushing's Avatar
Default Re: (fin781)
really? cause the difference between GSR cams and type R cams is less than 1 mm, and theres less than 1mm difference from type R cams to skunk2 stage 2
theres also less than 1mm difference between stock LS b18b cams and crower 403's
i think i made my point
Old 04-27-2008, 07:43 PM   #12
gh3tt0_boi
gh3tt0_boi's Avatar
Default Re: LS cams vs. B20 cams? (civiconfire)
should i go b20 or ls...?
gh3tt0_boi is offline   Reply With Quote
Old 04-28-2008, 12:21 PM   #13
JCushing
JCushing's Avatar
Default Re: LS cams vs. B20 cams? (gh3tt0_boi)
read the post
Old 04-28-2008, 01:21 PM   #14
JakeSpec
JakeSpec's Avatar
jakespecracing
Send a message via AIM to JakeSpec
[quote=Master of the Universe]Not worth it. Lash to 0.006/0.007 Click the image to open in full size.
good setting!
JakeSpec is offline   Reply With Quote
Old 09-30-2010, 10:40 AM   #15
AZGS00
AZGS00's Avatar
OMG ALL YOU PPL ARE ****ING RETARDED
NOT ONE MENTION OF DURATION OR OVERLAP IN THIS ENTIRE THREAD!
-tighter valve lash creates more actual duration which is why it gains power
-advancing the intake cam increases overlap which is why it makes power
1mm of lift separates ITR vs the Sk2 cams? how about duration, overlap, ramp rates....
you ppl fail. ive been looking for cam specs and i get this ****
AZGS00 is offline   Reply With Quote
acura, b20, b20b, b20z, bigger, cams, difference, head, hondatech, jdm, lash, lift, ls, p8r, valve
