Heat not working
Old 02-14-2008, 12:34 PM
G0crxG0's Avatar
Default Heat not working
First off, yes, I searched
-Blower works fine
-heater fuse not blown
My controls are broke so I have to manually moved the Valve switch, but either way it doesnt affect the heat of the air being blown out.
Anybody got any bright ideas?
Old 02-14-2008, 12:49 PM
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Default Re: Heat not working (G0crxG0)
There are two valves the controller moves:
This valve has to be opened: (pushed toward the firewall)
And this valve under the passenger side dash also:
As long as those are positioned correctly..
You need proper coolant flow through the heater core
and then air flow across the exterior of the core..
After the engine is warmed up,feel of the inlet and outlet
coming from the firewall..Both should be warm and about the same temperature.
If not,the heater control valve could be stuck closed or the heater core
could be clogged up..
You can try blowing through it with compressed air with the hoses removed
and the valve open..
Old 02-14-2008, 09:04 PM
Tyson's Avatar
Default Re: Heat not working (88DXCRX)
my bet is on the second picture.
stick your head behind the center console from the passenger side and look up. the cable probably popped off. it controls the air mixture flap and is the reason its not blowing hot air thru the heater core.
Old 02-14-2008, 10:49 PM
Suit up
Spoon Sports's Avatar
Default Re: Heat not working (Tyson)
Good info. Will try this tomorrow.
Old 02-17-2008, 07:55 AM
G0crxG0's Avatar
88DX your the man
vlave under the dash = problem solved and warm feet for me, thanks alot!
Old 02-17-2008, 05:53 PM
Tyson's Avatar
Default Re: (G0crxG0)
ive added this to the FAQ. its so common im surprised its not already on the list.
Old 10-29-2008, 08:18 AM
crx(gator)'s Avatar
Default Re: (Tyson)
bump so i can try this later today...
Old 10-30-2008, 05:20 PM
blaak-crx's Avatar
Default Re: (crx(gator))
Also check inside the climate control if it's not broken like that:
But, I would also go for the second picture. .
Oops, just re-read the thread and it was sloved.
Old 01-16-2009, 07:40 AM
B20vEf9's Avatar
this worked for me today
good info
Old 01-16-2009, 08:26 AM
MeanstreakCivic's Avatar
If none of that works, make sure that your thermostat is still good. If its not opening then you wont get heat. Depending on how cold it is outside, your car may or may not over heat.
But thats another possibility.
Old 01-18-2009, 08:41 AM
KYLE.ECKERT's Avatar
im not sure if this thread is dead but its worth a shot.
i replace my thermostat a few months ago when it was still warm out. not its cold -10 and my temperature guage doesnt work right. it will start to get warm then fall back down. and if my car is just sitting there running it blows cold air. but if you give it some gas it will start to blow warm.
any ideas? bad heater core?
Old 12-08-2010, 12:56 AM
InTheLBC20's Avatar
lol at this thread, it makes me laugh!
Old 01-05-2011, 09:34 PM
CrxMusix13's Avatar
Going to try this stuff today, thanks.
Old 11-17-2012, 07:29 AM
myparkerbros's Avatar
ok I wanted to add something here... I am having this "no-heat" issue in my CRX, the blower and controls work just fine.
I checked the valve under the hood... good... I checked the valve on the side of the heater box under the dash, still good. I opened both valves and still no heat. The inlet and Outlet hoses are both warm (pretty much same temp).
I am going to remove the dash and completely inspect everything.
The Honda workshop manual says if your blower works and your not getting heat, that it could be a possibility of a few things
- Cloggged heater duct
- Clogged blower outlet
- Clogged heater valve
- Faulty air mix door
- Air Mix cable adjustment
- Faulty thermostat
Old 11-18-2012, 09:29 AM
OK, now I feel silly... said I checked the valves, but I only checked them from the cable, both seemed to open and close properly. I removed the header duct that connects the blower to the heater, to find a small Blue Point wrench that was blocking the door from fully opening to the hot air. I removed the wrench and re-adjusted the cable. Heat works perfect now.
Now this is something that I'm sure is very rare to happen... However, if you have already checked everything external and you still are stumped, be sure to have a look here, you never know how the work was done on your car before you had it... after all it was a 5/16 wrench
To remove the duct was very easy.
-Simply remove the glovebox (2 screws underneath - 8mm)
-remove support bracket behind glovebox (4 screws; 3 - 8mm, 1 - 10mm)
-remove blower duct (2 screws -10mm )
You can reach in and feel the flap door right there, when the Air Mix door is all the way towards the firewall, it should blow cold. When the mix door is all the way towards the center console it should be fully closed, which will send all of the air through the heater core.
The air mix door needs to be fully shut!, a tiny wrench allowed it to be open about half an inch and that was enough where I wasn't getting heat.
Hope this can help somebody else
Old 12-30-2012, 09:43 PM
vladdimir's Avatar
My problem seems to be more electrical than anything else but I seem to only have my heat actually work when the key is in between the 1-2 position of the ignition switch..... When i start my car i have absolutely nothing working heat wise but when i put the key between the 1-2 position my heat starts blowing.... Any ideas as to why it wont work with the car in the run position but works while in between 1-2!!!!!!
Old 12-01-2018, 11:33 AM
Rome97's Avatar
Originally Posted by G0crxG0
88DX your the man
you got a pic of the valve and or is this part of the cable retention
thewrai6th
03-10-2016 04:24 PM
integradc4_rg87
10-29-2010 11:51 PM
gixxerboy750
01-17-2010 07:43 AM
mayfly
12-10-2009 08:01 PM
drm109
08-10-2008 04:30 PM
Quick Reply: Heat not working
