#1 |
#2 |
Great lil writeup with pics
How much did the seal cost?
94 5spd Accord (~165k miles as of Feb, 2008) 1992 Suzuki Katana 750 1996 SeaDoo XP 800cc Jet Ski |
#3 |
It was about $12 before shipping, just go to partstrain.com.
#4 |
Sorry for my ignorance. Did you replace internal seal and external o-ring? I just replaced my external o-ring and learned that the shaft has a lot of play. I wonder if there's bearing inside (if any) was worn out.
Thanks
Protect your investment http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif 91 silver Accord EX/5SPD 90 red Mustang GT/5SPD Conv. 25th Anniv. 97 silver BMW 540i/6SPD sport pkg 03 Lexus GX470 http://images.honda-tech.com/set1/smile/emwink.gif http://images.honda-tech.com/set1/smile/emcocktl.gif |
#5 |
I replaced both the o-ring and seal. You can see where the bearing is in pic 3 next to my finger. It is held in place by the three screws. You would most likely have to press it on and off to replace. My bearing was fine so I didn't replace it.
#6 |
ok i'm pissed! about a year ago mine started to leak so I just grabbed a new distributor from Honda. I looked for a week to find this seal. Guess I should of looked harder! Oh well, now I have a good distributor for sale. The old one with a new seal.
Thanks man, that's some good news that you can get the seal. |
#7 |
i'm pissed too jgaccorn, cause mine was leaking internally and i went 2 napa and got me a new dist. i'll keep this post in mind next time
#8 |
H-T Order of Merit
Added to the FAQ
#9 |
Sorry I missed this new thread and kept posting on the old one...
Anyway, I used the previous write up and replaced the O-ring. The pictures really helped! Thank you. However, I could not remove the distributor because the electrical connectors did not want to detach. I did press the tab and pulled hard on the casing... no luck. I stopped short of using vice-grip to pull them apart. Any suggestions?
1995 LX 2.2L I4 (F22B2), Teal, (Dec 10 2007, 123305) |
#10 |
WARNING! Be sure to reinstall the part that interfaces with the cam in the same postion it came off the distributor shaft. If you do not, you will have the distributor 180 degrees out. The tangs are offset, not centered, which is how you can only put it in one way to the cam. However, you can rotate it 180 when you put the pin back on the shaft. Your engine will not run if you do this. I found out today. Thanks again for the pics and info.
#11 |
Thanks for the warning and sorry to hear that your story. Hope it did not damage anything.
#12 | ||
Location: Free bullets if you find me sucka, Washington
use it to unhook the clips you might have3 to pull with a little force..those plugs probably havent been unhooked in years huh? and I dont know if this has been said but REMEBER TO MARK YOUR TIMING!!! with a permenat marker when you take teh dissy off the head..just draw a line...
"I ♥ my CD5." Quote:
#13 |
Well, actually I did use a flat head to keep the tab open and still it wouldn't slide out. Perhaps I was too gentle, but the marks on my fingers tell me I was not
Anyway, I'll give it a go again soon. May be I'll really tug hard this time, if it breaks, so be it Yes, I did mark the position of the rotor (wrt to distributor body) and drew several lines all over the distributor housing aligning with the body of the engine. Putting it back couldn't have been easier Now, waiting for the seal to arrive to dismantle again... sometime next weekend.
#14 |
No damage done. Wasted a couple of hours for me trying to figure it out. Anyway, I used a chisel to lightly mark across the distributor body and rocker assembly (top mounting bolt on the distributor) to give a reference point for the timing. I was afraid to use a marker since I knew I would be using carb cleaner to clean all the oil off. When I reinstalled the distributor, all I had to do was line the marks up.
#15 |
H-T Order of Merit
I never understood how people could do that. Hell, I didn't even think it could be done.
My friend had replaced a coolant hose and removed the distributor to get to the hose easier. When they put it back on the car didn't run and they couldn't figure it out. So they call me and I go over and take a look. Go to take the distributor off and that things was really wedged in there. It should be pretty easy. If you have to force it in then you know it's off. |
#16 |
If I just want to replace the external seal (where the distributor butts up against the head and the camshaft end bearing), do I just pull the dist, wedge the new little seal in there, and reverse? I noticed the outside seal looked pretty brittle when I took off my rocker arm assembly a few days ago, but I didn't think to preemptively buy one so I couldn't do it at the time.
#17 |
That's what I did. Should be 15min job max., if you have the right tools. Remember to clean out the area where old O-ring was.
Oh! the oil will leak down the transmission and create a little pool right below where the tranny-drain is. It worried me first time, until I bent down under the car and looked up to see the oil slick.
#18 |
My car doesn't leak anything, but my lower rocker arm oil seals literally snapped in half when I pulled them out to replace them, so that little thing can't be in much better shape
#19 |
Thanks
#20 |
sorry. I have this page up for days and just click refresh. Evidently, it re-submit my reply. Ignore this please.
BTW, good thread.
#21 |
I have a '99 Accord and the distributor is also leaking oil on the inside. I got stuck on removing the pin at the base. My distributor doesn't have a ring that holds the pin. It's just a pin that is force fitted. I've tried hammering it out, but to no avail.
![]() Do I need to hit it harder? I'm afraid to break something. Or maybe, once removed, it won't go back in as tight? Any help would be great. Thanks. Modified by 2BFI at 1:58 AM 2/7/2008 Modified by 2BFI at 2:00 AM 2/7/2008 Modified by 2BFI at 2:04 AM 2/7/2008
My Auto Blog |
#22 |
Kbud, you saved my day. I am glad I read your warning. I took mine out when I put it back in, the car didn't start. I turned it 180 degree, put it back, and started right up.
Two more WARNINGS , people. When I took mine out, one part of the cap seal was hanging outside. That explain why my rotor got stuck to the shaft since it rusted. I had to spray DW-40 on it for couple hours. so be careful when you put the cap back on. Make sure the seal is seating properly. I also learned that the shaft was too loose. the little black piece (see picture 3) was pushed too far up. I just moved it down by hitting it with hammer lightly. The car is running smoothly now. 2BFI, you may have an after market shitty part. I may be wrong though. I would go the auto part and ask to see one. Good Luck
#23 |
deklao, my distributor is an OEM part. I haven't changed it since the car was bought from Honda.
My Auto Blog |
#24 |
Make sure that when you are hitting the pin the base is taking the impact and not the shaft or housing. Then, swing away.
#25 |
2BFI, I would still go to auto part to see and compare the part. Maybe your model is different.
| Bookmarks |
| Tags |
| 1995, 1999, 92, accord, distributor, honda, housing, integra, leak, leakage, leaking, oil, replace, replacing, seal, shaft |
