Clock backlight out
Old 02-01-2008, 09:49 AM
projectx2005's Avatar
Default Clock backlight out
The clock backlight is out in my 2000 Accord. I can't see the time at night. Any idea what it cost to replace this? I don't want to spend more than $50. Thanks.
Old 02-01-2008, 10:06 AM
Heat's Avatar
Default Re: Clock backlight out (projectx2005)
Buy a new bulb from the dealer, will be a buck or two.
Remove the clock. To do this, put a little masking tape under the clock (to protect the dash), then put a flathead screwdriver under the clock and gently pry it up and then it just slides out.
Remove the clock bulb, I believe that it’s just a quarter turn and it’s out.
Old 02-01-2008, 04:16 PM
wkdclwnz's Avatar
I had the same thing happen about a year ago. When I took the clock apart, I f'd it up. I bought a used one in great shape on ebay for $10 that worked and still works perfectly.
Old 02-04-2008, 06:00 AM
Thanks for the help. It's annoying for not able to see the time at night. I heard many people have this problem. Plus the dealer charges $100 to fix it.
jdmspoonitr
03-20-2011 02:04 PM
B16Civic93
12-05-2009 10:31 AM
billyman
08-29-2004 02:17 PM
tarheelborn
09-15-2003 05:00 PM
B2FiNiTY
05-13-2003 07:44 PM
Quick Reply: Clock backlight out
