| Welcome to Honda-Tech! | ||
#1 |
what other years will fit my 1998 Ex V6 coupe?
http://images.honda-tech.com/set1/smile/emsmile.gif |
#2 |
97-99 3.0CL
98-02 accord V6 |
#3 |
Location: Free bullets if you find me sucka, Washington
reccomenf aso adding a tranny cooler and magnetic drain plug...word is they help extend the life of em
[B]"I ♥ my CD5." [/B] [quote=pos_cd5]i disapprove of wheels. and "wheel in inches" > "girls age"? [img]http://images.honda-tech.com/set1//smile/emcrook.gif[/img] i also disapprove of your vtak sticker too...but who cares, im a pompous ricer! [img]http://images.honda-tech.com/set1/smile/embeer.gif[/img] [/quote] |
#4 |
thanks! now does anyone have a extra one laying around?
#5 |
I had mine re-built by thunderbolt, cost $2500. they told me that I should change out the tranny fluid everyother oil change. it's been a year and so far so good.
1998 Accord EX Coupe 3.0 Auto 2002 GMC Sierra 5.3 2004 GMC Yukon 4.8 1971 C-10 350 manual |
#6 | |
#7 |
lol I hope your changing oil like very 7.5K
trans fluid change 1 a year is sufficient unless you drive 30K or more. then I would do it every 30K |
#8 | |
I could have gotten a rebuilt one for about $1800 but then comes the job of installing it or paying someone a grand to install it for you, I really didn't want to fool with it so I just paid up and had them fix it.
I change the tranny fluid every 6000 miles, the tranny mechaninc said that these trannys go bad due to bad lubrication when the fluid starts to break down and he said that the best thing to do was to change the tranny fluid every other oil change. I don't know if he is right or not but spending $20 for tranny fluid every 6000 miles is worth a shot to be on the safe side. I do my own oil and tranny fluid changes so all I have to do is pay for the fluids. Quote:
#9 |
nooooooo.........
these transmissions go bad because 1. the main filter (a screen) gets clogged with debris 2. #1 is caused by (in most cases) the tapered roller bearings used in the differential beucase they were sub par in their quality 3. #2 causes a drop in system pressure. This in turn causes the 2nd gar clutch pack to fry becuase it was already on the low side for lubrication. Changing the fluid every 6K miles is pointless as you cannot remove what has already been trapped by the filter. Honda solved the problem by removing the INTERNAL filter and placing the filter inline with the trans cooler line (see new reman honda units). If your trans guy had any clue, he would have known this and installed an inline filter in place of the internal one and told you to cjhange it every 30K or so. |
#10 |
where can i get a tranny? i went on a few online quote sites but nobody emailed me with a quote.
maybe ill have mine rebuilt also.
#11 |
get a reman from Honda dealer, it already has the updates made to it and the ones since about Feb 05 have been reliable
#12 |
| Garage is empty, add now |
Bringing this back from the coma, could I have that service done on a transmission that's not broken yet? Remove the screen and install an inline filter? How much would you think that would cost to do?
I'm seriously considering purchasing a V6 Accord for my next car as a daily driver, and this would make it reliable. Please let me know what you think. Thanks. Chris. |
#13 |
is there a standard tranny that will fit these 98 accords 3.0 v6. the engine is a J30 i beleive.
Team Cartune©... Kingston, Jamaica |
#14 |
03 Acura CL/TL type S trans will fit right in
it's a lot of work though as you need a lot of CL/TL type S parts |
#15 |
ok...the thing is my father has one and the tranny has been repaired a couple times already and i was planning on taking the car from him and i would just get a gearbox and put in. i figured that thoses where the only ones that could be used as its the same family line the engines roll off from, J-Series.
#16 |
but next question is has any one on here done this b4. and could yall help me with the procedures
#17 | |
#18 |
How to remove a 2000 honda accord v6 transmission ???? What should I remove to take out the transmission
| Tags |
| 1998, 2000, 30, 98, accord, accords, adding, cooler, filter, fit, honda, problems, safe, tranny, transmission, transmissions, v6 |
