Possible reasons for steering wheel vibration?
Old 07-02-2002, 05:00 AM
Nuts's Avatar
Default Possible reasons for steering wheel vibration?
I've noticed the steering wheel vibrates when the car reach to 120km/h (75mph) and the vibration stops when it reach around 140km/h (87.5mph). What could be the possible reason?
I've been told that it might be my tires are off balance. I will bring the car in the shop soon but just want to know what to expect.
btw, my stock tires has 25K km (15K miles) , been on the track 2 times and the left side of each tires are bladed (pretty much) since there are lots of right hand turns on the track that I ran on.
TIA,
CS
Old 07-02-2002, 05:21 AM
JPP
JPP's Avatar
Default Re: Possible reasons for steering wheel vibration? (CS)
Highest probabilty is an unbalance wheel. Either the tire as uneven wear or you lost a balancing weight.
Old 07-02-2002, 06:08 AM
TypeR 599's Avatar
Default Re: Possible reasons for steering wheel vibration? (JPP)
i think he lost a weight
Old 07-02-2002, 06:16 AM
Nuts's Avatar
Default Re: Possible reasons for steering wheel vibration? (TypeR 599)
you mean I lost one of those metal piece on the wheel?
time to do re-balancing I guess.
btw, why would it only vibrates at 120km/h but not at a higher speed?
thanks,
CS
[Modified by CS, 3:20 PM 7/2/2002]
Old 07-02-2002, 06:36 AM
Cosworth's Avatar
your alingment could be off, if you hit something on the road recently.
Old 07-02-2002, 06:40 AM
Wiseguy's Avatar
Default Re: Possible reasons for steering wheel vibration? (Cosworth)
you need "wheel alingment " on your car
Old 07-02-2002, 06:47 AM
VTHokie's Avatar
Default Re: Possible reasons for steering wheel vibration? (Wiseguy)
Could be a broken radial belt, that is what honda found on my new potenza's I guess that teaches me for having walmart mount my tires
walmart = tire mounting
walmart = fried chicken
Eric
Old 07-02-2002, 09:22 AM
Incognito's Avatar
Default Re: Possible reasons for steering wheel vibration? (VTHokie)
try to put your rear wheels on the front, fronts in the rear, and see if the car still vibrates. If it does, then it's your wheels (balancing, tires, or wheels). If not, then it's somehting in your suspension.
Old 07-02-2002, 09:29 AM
Big Phat R's Avatar
Default Re: Possible reasons for steering wheel vibration? (Incognito)
exactly - but it sound like a front wheel is out of balance or you bent the rim
Old 07-02-2002, 05:33 PM
TypeR 599's Avatar
thanks,
CS
okay...i know for sure the wheel is out of balance because it only vibrates at a certain speed. This is because the frequency of vibration the road and tires are exactly the same only at 120km/h. i bet at any other speed, from teh outside, you can see your tire wobble but you wont be feeling it because the frequencies are not matched.
btw, if you are socal, i can balance it for you free
yeh, you probably did lose one or it moved out of it's original position some how..
[Modified by TypeR 599, 6:35 PM 7/2/2002]
Old 07-02-2002, 05:50 PM
JDM nerbie's Avatar
it could be you have dirt or somthing stuck on the inside of the wheel throwing your wheel(s) off balance
just and idea
or what everyone else said
Old 07-02-2002, 08:24 PM
Incognito's Avatar
Default Re: Possible reasons for steering wheel vibration? (nerbieR)
if you have those sticky weights, you probably lost 1 or 2. They just fly off over time. look for like some sponge/glue **** on the inside of your rim, if U run sticky weights. That could be a sign of a sticky weight that have flown off.
SPOOLINmatt
05-29-2008 11:16 PM
People_Mover
09-24-2003 03:28 AM
Toda Party
10-27-2002 07:26 AM
i_krayzie_i
04-06-2002 08:04 AM
Seann
07-29-2001 02:22 PM
Quick Reply: Possible reasons for steering wheel vibration?
