Old 01-22-2008, 05:13 PM   #1
hondamonda
hondamonda's Avatar
Default o2 sensor wires on 92 civic dx
here is the problem. i did a ls 98 ls swap on my 92 civic dx. i'm using a dx engine harness and the car is running fine. the one problem is that i do not see where i have to connect the o2 sensor. i only see a couple of extra plugs and i dont believe they are the ones. any one have a description or the wire colors for the o2 sensor wires coming off the harness?
hondamonda is offline   Reply With Quote
Old 01-22-2008, 05:22 PM   #2
z6hatchboy
z6hatchboy's Avatar
Default Re: o2 sensor wires on 92 civic dx (hondamonda)
The o2 sensor on the dx harness is paired with the vss, ect, and whatever the other one beside that is at the front of the motor. As for the color i cant say.
flickr Nikon D700, 92 hatch (traded), 95 coupe (traded)
z6hatchboy is offline   Reply With Quote
Old 01-22-2008, 07:28 PM   #3
hondamonda
hondamonda's Avatar
Default Re: o2 sensor wires on 92 civic dx (z6hatchboy)
bump....any one know the wire colors on the harness for the o2 sensor?
Old 01-22-2008, 09:13 PM   #4
wangkata
1993 Honda Civic
wangkata's Avatar
should be 4 wires WHT/YEL,BLK/GRN,WHT/ORN,BLK...... Click the image to open in full size.
|.....Overnight.........................| ||
|........Parts From Japan.............||'|";,__
|_..._...____________======||_|_|...,]
wangkata is offline   Reply With Quote
Old 01-23-2008, 06:53 AM   #5
hondamonda
hondamonda's Avatar
Default Re: o2 sensor wires on 92 civic dx (wangkata)
ok i see a white, yellow/ black, orange black, and a green white wires not plugged into any thing and its near the front of the motor . and the o2 sensor is down under on the headers, the wires on the 02 sensor are green, whire and there are 2 black wires. can any one match them up for me?
Old 01-24-2008, 05:18 PM   #6
hondamonda
hondamonda's Avatar
ok i got it hooked up. at first i was going to cut the wires and make them longer but then i just figured to open up the harness and pull the harness for the o2 sensor out until it is long enough Click the image to open in full size. . its good now but it is still showing the code for the o2 sensor and i think i need the tps also because of teh rough idle. another issue, this never ends. Click the image to open in full size.
02, 1992, 2000, 92, civic, color, dx, green, harness, hohda, honda, integra, location, o2, sensor, white, wire, wires, wiring
