Intake manifold torque specs?
Old 01-17-2008, 04:50 PM
dballard's Avatar
Default Intake manifold torque specs?
I'm about to finish up installing the IMG. I've searched for quite some time now and cannot find the torque specs for the bolts that hold the manifold to the head. I have found where one person didn't torque it down enough and ended up ruining their motor. Coolant would get between the gasket and enter the combustion chamber. Also to anyone else who has done this. Did you use any kind of sealant on the gasket? I noticed the flimsy OEM one had no trace of sealant.
Modified by dballard at 6:11 PM 1/17/2008
Old 01-17-2008, 06:04 PM
reaper702's Avatar
Default Re: Intake manifold torque specs? (dballard)
good question and i also would like to know as i just recently got my IMG in the mail today. btw, how long did it take to install?
Old 01-17-2008, 06:18 PM
dballard's Avatar
Default Re: Intake manifold torque specs? (reaper702)
I was taking my time so I used the DIY from 8thcivic. I removed the front brace which gave me MUCH more room to work. Taking my time it took about 2.5 hours. Biggest pain was actually removing the manifold after all the bolts were out. I didn't remove the two studs so the side of the manifold closest to the accessory belt would catch on a bracket. Just a little patience got it off. I'm still paranoid about coolant entering the manifold that I won't be able to see. I haven't seen where anyone uses sealant as of yet.
Old 01-17-2008, 07:26 PM
fg2si!kid's Avatar
16 ft-lbs for the top nuts and the bottom bolts iam 100% sure i looked it up in my service manual
Old 01-17-2008, 07:31 PM
dballard's Avatar
Default Re: Intake manifold torque specs? (fg2si!kid)
You wouldn't happen to know the tightening sequence would you? Also, is it suggested to use any kind of gasket sealer in this installation?
Old 01-17-2008, 07:37 PM
fg2si!kid's Avatar
"tighten the bolts and nuts in a crisscross pattern in three steps,beginning with the inner bolt" hahah is that good enough for you
Old 01-17-2008, 07:40 PM
fg2si!kid's Avatar
oh and it does not say any thing about useing any kind of "honda bond" or sealer
Old 01-18-2008, 07:32 AM
hondamanforlife's Avatar
no sealant! no problem! I removed the top stud and replaced it with a bolt for future brake down so I would not need to mess with the idle pulley.
selbher
10-06-2010 02:49 PM
gt3civic
06-04-2007 10:34 AM
honda06si
08-06-2006 08:37 AM
iperez
10-01-2003 05:03 PM
ChrisDaun
05-27-2003 06:42 PM
Quick Reply: Intake manifold torque specs?
