3 bolt post mount to a 2 bolt?
How would i go about doing this? Is there a reason i shouldn't do it? The reason why i ask is because i found a good deal on a set of after market mounts that are for a 2 bolt post mount and my 01 ls is a 3 bolt.
thank you in advance
Re: 3 bolt post mount to a 2 bolt? (rdssk8rcs1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 »</TD></TR><TR><TD CLASS="quote">any particular car that came with these that i can look for?</TD></TR></TABLE>
CRV's and 99-00 SI.
CRV's and 99-00 SI.
Re: 3 bolt post mount to a 2 bolt? (paulzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy »</TD></TR><TR><TD CLASS="quote">
CRV's and 99-00 SI.</TD></TR></TABLE>
And this would bolt up to my ls block and work with innovative 2 bolt post mount motor mounts?
Thanks again for the help
where did you buy the mount kit ?? you should just change it out to a 3 bolt.. if not you can use a JDM b16 or a 99-00 Si driver side post mount... CRV will not work its too tall.!! if you need a 2 bolt post mount i think we got one at the shop...
There is a difference between the 99-00 Civic Si timing belt cover mount from the Acura Integra's. The spacing between the two bolts are different. The Acura Integra 94-01 LS/RS is the one your looking for. I'm suprised that you have a 3 post set-up on an LS. Someone must of swapped it out. Any hope this helps.
Re: 3 bolt post mount to a 2 bolt? (YZFR6AVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YZFR6AVID »</TD></TR><TR><TD CLASS="quote">There is a difference between the 99-00 Civic Si timing belt cover mount from the Acura Integra's. The spacing between the two bolts are different. The Acura Integra 94-01 LS/RS is the one your looking for. I'm suprised that you have a 3 post set-up on an LS. Someone must of swapped it out. Any hope this helps. </TD></TR></TABLE>
wait a minute... 94-01 integra all models ls rs gsr type R all came 3 bolt.. i thought you guys were a mount company you should know that.. no LS came 2 bolt 94-01 DC chassis
Re: 3 bolt post mount to a 2 bolt? (Camp1320motorsports)
I think mine is a 3 bolt. It has 2 big bolts coming up through the motor mount and it6 appears to be a smaller bolt going down. Is that considered a 3 bolt? And yeah all of this is helping a lot. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Camp1320motorsports »</TD></TR><TR><TD CLASS="quote">where did you buy the mount kit ?? you should just change it out to a 3 bolt.. if not you can use a JDM b16 or a 99-00 Si driver side post mount... CRV will not work its too tall.!! if you need a 2 bolt post mount i think we got one at the shop... </TD></TR></TABLE>
yeah i could definitly use one , if you have the one he is talking about. Is it the civic one or the ls/rs one? Let me know. I would appreciete it a lot
Re: (paulzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy »</TD></TR><TR><TD CLASS="quote">I've used teh CRV one with a stock civic steel mount with success before. Unless somebody had switched it before hand to a 99-00 Si bracket.</TD></TR></TABLE>
What do you mean?
What do you mean?
Re: (paulzy)
http://www.innovativemounts.co...19550
So if these are the mounts i buy i can just purchase a 95 civic si 2 bolt post mount?
Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">Like tony always tells me, Honda put it there for a reason..</TD></TR></TABLE>
So is that a yes? Haa sorry for being a pain i just want to make sure im purchasing the right thing
Re: (rdssk8rcs1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 »</TD></TR><TR><TD CLASS="quote">http://www.innovativemounts.co...19550
So if these are the mounts i buy i can just purchase a 95 civic si 2 bolt post mount?</TD></TR></TABLE>
no, the SOHC and DOHC bracket(the piece with the studs and no rubber bushing. Bolts up the the actual engine block) are a different size.
