ls gas mileage
Old 01-14-2008, 10:50 AM
mach0's Avatar
Default ls gas mileage
Curious. Some input would help. MY DD ls is getting about 25 mpg highway...is there a way i can get it better?? I am not throwing any codes or any lights on...but it does seem to waste more gas than I think it should.
Old 01-14-2008, 11:00 AM
omnirage's Avatar
Default Re: ls gas mileage (mach0)
I heard that replacing your primary o2 sensor works wonders, so two weeks ago I bought a new one and wired it up myself.
Freakin' worked like a charm! Honestly it makes a very noticeable difference, and when coupled with grandma driving you barely use any fuel at all. Definitely recommended. Check for a Denso o2 sensor off ebay.
Old 01-14-2008, 11:10 AM
mach0's Avatar
Default Re: ls gas mileage (omnirage)
ill check into it..thanks..any other suggestions?>
Old 01-14-2008, 12:25 PM
iheartdsees's Avatar
tire pressure? clean air filter?
Old 01-14-2008, 12:32 PM
TightEyez's Avatar
Default Re: (iheartdsees)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartdsees &raquo;</TD></TR><TR><TD CLASS="quote">tire pressure? clean air filter?</TD></TR></TABLE>
how do you clean it? lol
Old 01-14-2008, 01:53 PM
mach0's Avatar
tp is good...got to check the air filter
Old 01-14-2008, 02:05 PM
Resident Gearhead
BryanM.'s Avatar
Default Re: (mach0)
Not driving above 75 mph helps. Most cars score the best mpg from 55-65 mph.
Old 01-14-2008, 05:21 PM
BOTAN01's Avatar
how bout changing fuel filter?
Old 01-14-2008, 06:23 PM
Blahblah718293's Avatar
Default Re: (BOTAN01)
full tuneup: spark plugs, wires, cap, rotor, pcv, fuel/air filters
if you dont know how old your o2 sensor is, thatll probly give you the best improvment.
also, you can get injector cleaner, and intake/tb cleaners, BG makes them, and they work well.
Old 01-15-2008, 12:59 AM
VRD^sam's Avatar
Default Re: (Blahblah718293)
My Ls w/ b16 trans gets horrible gas mileage, i only range from 200miles to a tank and its doesn't even have an intake or exhaust just tranny/6puck/flywheel and its under 100k
Old 01-15-2008, 02:08 AM
gsrob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOTAN01 &raquo;</TD></TR><TR><TD CLASS="quote">how bout changing fuel filter?</TD></TR></TABLE>
Honda's rarely require fuel filter changes. In the 4 or 5 years I have been working on them, I've never seen the fuel filter be the culprit of anything come to think of it. My gsr (w/ gsr tranny at the time) was getting about 29-30 mpg if I took it pretty easy on her for the whole tank. Currently since the motor has been built with the ITR tranny has dropped me down to 20-25 mpg (bigger injectors, p/p, stage 2 cams). Now it basically depends on how I drive the car. If my foot isn't in it all the time I am getting in on the higher end of the spectrum. It's just much harder not to rip on it a little getting on the freeways here and there.
Old 01-15-2008, 04:59 AM
bmloven's Avatar
you could do an engine flush that would help. nd a three step would help a lot. cleaning ur injectors, throtle body nd ur intake.
Old 01-15-2008, 06:16 AM
* B A N N E D *
GRAF-FITI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">full tuneup: spark plugs, wires, cap, rotor, pcv, fuel/air filters
also, you can get injector cleaner, and intake/tb cleaners, BG makes them, and they work well.</TD></TR></TABLE>
QFTMFT
Old 01-15-2008, 07:59 AM
mach0's Avatar
Thanks..For the record I cruise around 65 mph...My career requires a clean license
Red-Rag-B18
05-28-2010 02:59 AM
EvenStar
05-02-2007 05:25 PM
AGENT 99
36
04-20-2006 12:06 AM
nexus da9
05-08-2004 11:17 PM
SpeedMonkeyRacing
07-10-2003 11:51 PM
Quick Reply: ls gas mileage
