Old 04-01-2015, 09:31 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
how do you unclog windshield washer nozzles?
Old 01-14-2008, 03:52 PM
sickofitall1113's Avatar
Default how do you unclog windshield washer nozzles?
i just bought brand new ones from the dealer and one of the sprayers on the drivers side is already starting to sputter and just plain not work. it sucks, i drove like 30 miles to pick them up cuz neither of them worked. anything i can add to the fluid to get it clean or flowing right?
Old 01-14-2008, 04:09 PM
Keno20's Avatar
Default Re: how do you unclog windshield washer nozzles? (sickofitall1113)
I just do it manually with a fine tipped needle. Works good as.
Old 01-14-2008, 04:13 PM
Keno20's Avatar
A high pressure hose or an air compressor would also do the trick i'd say...
Old 01-14-2008, 06:05 PM
9t4fodo's Avatar
There is prob something in the line that is making them clog up. First you need to take the hose off the actual squirter and run it...make sure the washer bottle is clean and you have clean fluit in it. Once you know the lines are clean then you can use high pressure air to clean out the squirter or use a needel, i used a thumb tack.
Old 01-14-2008, 07:32 PM
They let me pick
mrdeadman's Avatar
When my back one started to do that, it hardly squirted at all. So I just kept running it and eventually, presto! It worked again. I'm lazy I'd probably take the squirter off and use some lime away maybe or something. Lime away might eat the plastic so try it on something else first.
Old 01-14-2008, 08:48 PM
yea i was thinking something that will corrode and disintegrate whatever is blocking it. but the idea about emptying the resevoir and cleaning it out is a good idea. im gonna do that first.
Old 01-14-2008, 08:55 PM
SuckMyDOHC's Avatar
as posted above, check to make sure nothing is clogging your lines. If theres nothing there, I just cleared up a customers nozzles earlier today with a pick. I'm sure you could just as easily use a needle or something similar
Old 01-15-2008, 06:44 AM
* B A N N E D *
GRAF-FITI's Avatar
Default Re: how do you unclog windshield washer nozzles? (Keno20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keno20 &raquo;</TD></TR><TR><TD CLASS="quote">I just do it manually with a fine tipped needle. Works good as.</TD></TR></TABLE>
true
Old 01-15-2008, 07:41 AM
Reject Papi
jhammond_82's Avatar
Default Re: how do you unclog windshield washer nozzles? (GRAF-FITI)
are you sure that there is fluid in the bottle? just asking.
Old 01-15-2008, 07:47 AM
Daisy... Daisy...
Dogginator's Avatar
Could you be blocking the nozzles with ice crystals?
Old 01-15-2008, 07:56 AM
98PAITR's Avatar
The tip of an old guitar string works good too.
tr0n9h
07-11-2006 11:43 AM
TURBODC4TEG
01-12-2005 03:16 PM
ahh sanga
08-09-2004 12:14 AM
turbocivic2k1
03-26-2003 12:31 AM
keithv
06-14-2001 06:44 PM
Quick Reply: how do you unclog windshield washer nozzles?
