need rocker arm assembly torque specs (searched)
Old 01-10-2008, 04:04 PM
oem_certified_accord's Avatar
Default need rocker arm assembly torque specs (searched)
https://honda-tech.com/zerothread?id=933519
^ that's all i found
i've looked over and over in the haynes manual (yea i know that's the reason why) . but yet i still can't find the specs for the rocker arm assembly bolts.
any links or knowledge dropped will be appreciated.
94 LX f22b sohc non vtec. thanks in advance
Old 01-10-2008, 06:07 PM
hondadude's Avatar
Default Re: need rocker arm assembly torque specs (oem_certified_accord)
The 12mm head bolts torque to 15 ftlbs.
the 10mm head bolts torque to 9 ftlbs.
Old 01-10-2008, 06:26 PM
Default Re: need rocker arm assembly torque specs (hondadude)
thanks mayne
Old 01-11-2008, 05:14 AM
H-T Order of Merit
TouringAccord's Avatar
uh, isn't there a specific sequence those are supposed to be torque in? I don't have my manual in front of me otherwise I would look it up. Just making sure, wouldn't want something to go wrong thats all.
Old 01-11-2008, 07:10 AM
Default Re: need rocker arm assembly torque specs (TouringAccord)
there is, it's a cross hatch type of pattern in a sequence of 1-18. i have that memorized i just shot my brain nerves trying to find torque specs. had to switch heads over an over-torqued 10mm rocker assy. bolt.
thanks though peoples
Old 01-11-2008, 12:05 PM
NeKe1point0's Avatar
still battling those damn rocker arms huh ? did that pic ever end up helping ?
Old 01-11-2008, 04:06 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">uh, isn't there a specific sequence those are supposed to be torque in? I don't have my manual in front of me otherwise I would look it up. Just making sure, wouldn't want something to go wrong thats all.</TD></TR></TABLE>
getting to be a picky old fart ain't ya? LMAO Guess thats why you are 101%
Here's a link.
http://img212.imageshack.us/my...1.gif
Old 01-11-2008, 09:26 PM
thats not the tightening sequence for the f22b2 engine
edit: i think the rocker arm battle is over since i did a headswap. will find out tomorrow because after i put it all back together i found out the batt was dead so no crank dat today.
Old 01-14-2008, 04:04 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">getting to be a picky old fart ain't ya? LMAO Guess thats why you are 101%</TD></TR></TABLE>
LOL
Old 11-23-2012, 07:56 AM
prelude92395's Avatar
Default Re: need rocker arm assembly torque specs (searched)
I have a 95 prelude with f22b motor and im changing the lower spark plug seals and just checking the torque spec on the 10mm heads and the 12 mm heads on rocker arm assembly and is there a sequenceto tighten the bolts in
Hunter
02-17-2011 06:31 PM
civic46
04-28-2010 05:43 AM
ef-it90
03-07-2009 04:26 PM
crxss outhe eyes
01-24-2007 04:31 PM
Quick Reply: need rocker arm assembly torque specs (searched)
