> Honda Accord (1990 - 2002)
Old 01-09-2008, 07:59 AM   #1
redovermind
redovermind's Avatar
Default blower motor removel
easy or hard
going to try it today any tips
redovermind is offline Report Post   Reply With Quote
Old 01-09-2008, 08:17 AM   #2
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: blower motor removel (redovermind)
maybe... care to elaborate on what year your Accord is?
TouringAccord is offline Report Post   Reply With Quote
Old 01-09-2008, 09:27 AM   #3
redovermind
Default Re: blower motor removel (TouringAccord)
91 ex-r 4 door with ac
Old 01-09-2008, 03:30 PM   #4
hondadude
hondadude's Avatar
Not too tough to do; 8mm, 10mm deepwell small screwdriver for blower case clips.
drop out the glove box, loosen up the bolts that hold in the Evap core. Evap core DOES NOT have to be removed, unbolt the blower motor case.
I also peel back the carpet and get the TCU/ECU out of the way.
Just remember the exact angle and position of the unit when it comes down out of the dash.
Then you can split open the case to replace the motor unit.
Year and model Helps get better info
My crystal ball is out of service,and
I failed Clairvoyance 101 class
hondadude is offline Report Post   Reply With Quote
Old 01-10-2008, 05:26 AM   #5
kjmoy
kjmoy's Avatar
Just want to add couple points to Hondadude's detail explanation.
Be careful not to damage the blades (the round thing connected to the motor). It would be tight getting it in and out of the position. You will need a small alen wrench to detach the blade from the old motor and attach it to the new motor.
If the new motor is not OEM, then make sure you have the positive and negative terminals correct. Because the OEM motor is a plug in. Non-OEM motor just has two seperate connectors.
kjmoy is offline Report Post   Reply With Quote
Bookmarks
1990, 2000, 2003, 2006, 91, accord, blower, canada, civic, honda, hybrid, location, motor, replace, replacing
