I WANT TO PAINT MY CAR. WHAT DO I NEED??
ok well ive been wanting to paint my EK hatch. i wanted to know what supplies i need to get the job done. <U>example:</U> how much paint i need, primer, clear coat, hardner, how to mix, sanding paper, what kind of gun and air compressor to use. im pretty sure there is a lot of people out there that would want to know what would they need to do a paint project. if there is another thread like this ill take this one down any help would be appreciated. thanks.
Re: I WANT TO PAINT MY CAR. WHAT DO I NEED?? (IOSUA)
i found this good site. it tells you everything that you need to know how to paint a car
http://www.thebugshop.org/bsfqpnt.htm
if you want to paint you car you need paint.
pick a paint, and the tech sheet will advise what sandpaper to use, hardener, activator, everything.
a gallon should be enough to paint most vehicles
go to http://www.autobody101.com and search up on what kind of guns to use. the compressor you use must be able to support the minimum CFM of your gun.
oh and check out https://honda-tech.com/zerothread/1962364
Re: (IOSUA)
have you decided what paint you want to use yet?
for instance, i decided to use Omni paint. so i went to Omni's website, looked up the type of paint i wanted to use (MAE) and clicked the "tech sheet" link.
http://corporateportal.ppg.com...i.htm
