> Paint and Body
Old 12-31-2007, 09:26 PM   #1
jasoncrashtech
jasoncrashtech's Avatar
Default valve cover how too..
alright, so i misplaced the early ongoing picture's with paint stripping and prep.
sorry i'll haft to explain. i didn't use aircraft remover ( but there is nothing wrong with using it ) i used a spray on brand that i got from a kc paint supply store. i had to apply it about three times and it goes as follows
-spray the face of the valve cover for your first coat
-make sure you have water in a bucket near by in case it gets on your skin, paint stripper neutralizes with water and DO NOT GET IT IN YOUR EYES OR NEAR YOUR EYES !
-don't apply in the sun, find a shaped area with some concrete on your feet, that should be a good .
-the first coat will start to bubble after a minute of so, after ten min. you might as well neutralize with water and clean with some old paint brushes you don't care about or a thick and fine bristled brush that won't scare the metal.
-repeat this process try to get all nooks and cranny's stripped of old paint. i also used compressed air after the paint stripper was neut. to get in some area's.
finally after i repeated this three times the paint was off. i then prepped with my mini pistol grip DA ( dual action sander ) but in you don't have one, sanding with 120, 150, will do fine. a wet scotch bright and compressed air followed.
and now prime ( i used ppg k36 primer surfacer ) 2 coats.
the mixture is 4:1:1 , k36, i can't remember the catalyst a ppg store should be able to tell you, and dt solvent 885 ( depending on room temp, it was around 70 degrees when i shot the paint. )
and boom it's boring grey !
at my shop we had a brand new element come in for a front end hit, the color was kiwi pearl. it looked sweet so i went with that color. i wet sanded with 320, then 400 in all area's i could reach and again i used a wet scotch bright.
the paint came out good, i was loving the color ! now for the letters
-get some tape, and a piece of a paint stick with some sticky 120 grit paper and sand.
note : i went sideways because i wanted to leave the sandscratches on the metal to leave a machined look.
now for the H, on the jdm cover.
it's important to be careful and patient, you could scratch your perfect new paint job.
and there it is !
and it's ready. this isn't a high heat paint but it's more of show purpose. however i have two other covers i did the same way and they are holding up just fine.
ej8 squad member #346
valve cover how to http://honda-tech.com/zerothread/2188046
my daily http://honda-tech.com/showthread.php?t=2603420
Last edited by jasoncrashtech; 03-25-2009 at 03:30 AM. Reason: crappy spelling (blah)
jasoncrashtech is offline Report Post   Reply With Quote
Old 01-01-2008, 01:26 AM   #2
kelviiv
kelviiv's Avatar
Good Write up
kelviiv is offline Report Post   Reply With Quote
Old 01-01-2008, 12:23 PM   #3
Acidcrakker
Acidcrakker's Avatar
Default Re: (kelviiv)
Wow those came out real nice.
Does anyone know where I can get paint to come out like that, but not with a spray gun. Like a rattle can.
Jim- 14.85 @ 97 mph
Acidcrakker is offline Report Post   Reply With Quote
Old 01-01-2008, 01:04 PM   #4
jasoncrashtech
Default Re: (Acidcrakker)
what up acid ! howz the h22 going !
and to answer your question, just call up a local bodyshot around where you live and ask where they get there supplies. get an address and phone number. if you buy from them ask for " p pages" this will tell you all the info about the product you need. you will need catalyst, reducer ( or solvent ), and primer surfacer.
pm me if you have anymore questions !
Old 01-01-2008, 01:04 PM   #5
jasoncrashtech
Originally Posted by kelviiv
Good Write up
thanks
Old 01-01-2008, 01:42 PM   #6
Acidcrakker
Default Re: (jasoncrashtech)
Whaha. Thanks Jason that sparkle paint is great looking.
As for my H22. Its running so much better, than originally. I just got my Vtak cracking and its great. Whoa who.
Now all thats left is a Tuning system, and a tranny swap, then its off to body work and what not.
Jim- 14.85 @ 97 mph
Old 01-02-2008, 02:15 PM   #7
Eibach95Civic
Eibach95Civic's Avatar
damn. very impressive
Eibach95Civic is offline Report Post   Reply With Quote
Old 01-02-2008, 04:28 PM   #8
downsincedayone
downsincedayone's Avatar
Send a message via AIM to downsincedayone
Default Re: valve cover how too.. (jasoncrashtech)
keep up thegood work
downsincedayone is offline Report Post   Reply With Quote
Old 01-02-2008, 06:50 PM   #9
jasoncrashtech
Default Re: valve cover how too.. (downsincedayone)
thanks guys.
i've rattle canned valve cover like this and it still came out clean like. good prep makes a big difference
Old 01-04-2008, 08:22 PM   #10
JRZ88DX
1991 Nissan 240SX
My Garage
JRZ88DX's Avatar
Send a message via AIM to JRZ88DX
that green is sick!
do my valve cover!!!
1991 CRX dX
1991 240SX
JRZ88DX is offline Report Post   Reply With Quote
Old 01-05-2008, 06:47 PM   #11
vsmhatched
2003 Suzuki XL-7
My Garage
vsmhatched's Avatar
awesome color
NWI originator
Track.One
vsmhatched is offline Report Post   Reply With Quote
Old 01-05-2008, 11:45 PM   #12
JdmShwiggEG
JdmShwiggEG's Avatar
Send a message via AIM to JdmShwiggEG
R.I.P. Brandon J. Mueller Aka "GSRHB7" http://is.rely.net/1-92-65076-l-NREc...mLFY3DaZnA.gif
JdmShwiggEG is offline Report Post   Reply With Quote
Old 01-06-2008, 10:55 PM   #13
boostedjdmdc2
boostedjdmdc2's Avatar
niiiiice!
I ♥ My Honda
Currently Driving: 95 Milano Red DC
t3/t4 gsr
boostedjdmdc2 is offline Report Post   Reply With Quote
Old 01-07-2008, 01:27 PM   #14
White Smoke
i my honda
MoDeRaToR
White Smoke's Avatar
That turned out great! Nice write up
White Smoke is offline Report Post   Reply With Quote
Old 01-08-2008, 12:02 PM   #15
inspector01
inspector01's Avatar
Looks great. I don't assume that you clearcoated it did you??
DC Squad Member #0679
1998 Acura Integra
383 whp/288 ft lbs on Mustang Dyno
Crome Tuned on E85 http://images.honda-tech.com/set1/smile/emthup.gif
inspector01 is offline Report Post   Reply With Quote
Old 01-09-2008, 06:43 PM   #16
jasoncrashtech
Default Re: (inspector01)
yes, base coat , clear.
ppg
Modified by jasoncrashtech at 9:57 PM 1/14/2008
Old 01-09-2008, 07:11 PM   #17
inspector01
I thought it looked clear for sure, but my friend was told not to use clear when doing his engine bay cuz of heat, so i thought definately not on valve cover. I would love to see how it holds up cuz i want to do mine like that but i don't know if it will last.
1998 Acura Integra
Old 01-10-2008, 11:31 PM   #18
capster15
capster15's Avatar
Thanks for the info will come in handy
capster15 is offline Report Post   Reply With Quote
Old 01-11-2008, 01:40 PM   #19
k20utah
k20utah's Avatar
great job on the write up
k20utah is offline Report Post   Reply With Quote
Old 01-14-2008, 10:01 PM   #20
jasoncrashtech
for the most part, engine bays are always in single stage. the heat will be hard on the clear, and my motor is boosted. i will keep posting on how it is holding up
Old 01-15-2008, 07:47 AM   #21
-NA-aLL-thE-wAy-
EFSS153
2007 Acura RDX
My Garage
-NA-aLL-thE-wAy-'s Avatar
Nice work. That's a great color, too.
"I went to the theatre with the author of a successful play. He insisted on explaining everything. He told me what to watch, the details of the direction, the errors of the property man, the foibles of the star. He anticipated all of my surprises and ruined the evening. Never again! And mark you, the greatest author of all made no such mistake."
— Christopher Morley
Imago Dei
Part Out: 1991 Civic Wagon
FS: Black BDL Industries K Series Fuel Rail
-NA-aLL-thE-wAy- is offline Report Post   Reply With Quote
Old 01-15-2008, 08:16 AM   #22
I'mStock
I'mStock's Avatar
Send a message via AIM to I'mStock
Looks sick man, loving the attention to detail with the sanding marks!
-Stock
2.3 EVO | 1.6 RT4WD
CrucesStreets.com
I'mStock is offline Report Post   Reply With Quote
Old 01-16-2008, 12:19 AM   #23
alltech.magoo
alltech.magoo's Avatar
Send a message via AIM to alltech.magoo
Default Re: (I'mStock)
nice work
SwangnBang.com / Cavenman Stance
Originally Posted by starve
Caveman Stance: the barbaric and savage nature of how we roll
alltech.magoo is offline Report Post   Reply With Quote
Old 01-16-2008, 08:24 AM   #24
Genuine Rolla
Genuine Rolla's Avatar
Send a message via AIM to Genuine Rolla
wow....that color looks great...!
96-00 Civic sedan squad #11 | Team EJ6 | PROJECT JayDeM | HID retrofit club member #35 | Petey Photography | Flickr
Genuine Rolla is offline Report Post   Reply With Quote
Old 01-16-2008, 08:39 PM   #25
SneezinCD5
SneezinCD5's Avatar
ppg
I can spot PPG from a mile away. Nothing can beat the shine of PPG.
SneezinCD5 is offline Report Post   Reply With Quote
Bookmarks
covers, honda, mustang, paint, ppg, r120, striping, valve
