SoHonda Garage EG Hatch Build up pt. 2!! New for 08'
1 Post
Considering how long my last buildup thread became, it is far past the point of indexing the whole thing, so I decided to make a new thread, keep it indexed, and keep it to the point.
You can also check out the original thread which will have the same updates as well as whatever is new with the rest of the crew and friends
I'll also keep any build related parts for sale posted here on the first page with links to the thread...
Master Index
Page 1
-Intro, updated pictures of the hatch
-New parts!
-Installing Splash hub and Spoon wheel
Page 2
-Chrome VC nuts Installed
Page 3
-New tools
-Pics of toolbox and the hatch
-Mock up of JDM accessory trash box
Page 5
-Found another set of my OZ's!!! (thanks crxcess!!!)
-New Spoon N1
-New Cusco hangers
-Sleeve and shrink tube for the engine harness
Page 8
-New CL7 shiftknob installed
-Stripped door panels to prepare for new upholstery
Page 9
-Took the Mugen catback off the car
-Cleaned and polished Mugen axelback
Page 10
-Dyed JDM trash box black
Page 11
-Installed JDM trash box
Page 12
-Fabricated mount for custom fabbed dead pedal, not quite finished.
Page 13
-Completed dead pedal setup, finished pics
-Some pictures of the hatch from this past summer
-New Spoon Sports oil cap!
Page 14
-Picked up some more wiring supplies and new griptape for pedals
-Engraved 'SoHonda Garage' plaquette for carbon shift bezel
Page 17
-Applied fresh Grip Tape to my clutch and brake pedals
-Mocked up test pipe with new 2.5 flange
-Pictures of the hatch in the air to get started on pulling the motor
Page 19
-Removed front bumper
-Re-loomed driver headlight harness with flexo sleeve
Page 21
-Re-loomed passenger headlight harness with flexo sleeve
-Removed shift linkage, drained engine oil and tranny fluid
Page 22
-OEM Honda airbox snorkel
-Removed intake, radiator, hoses, resivoir etc.
Page 24
-New OEM Honda bearings for the tranny
-JDM ITR Final Drive
-Organized my stuff
Page 25
-Removed engine harness, clutch line, and strut bar
-Did some more organizing, cleared a spot for the motor stand
Page 26
-Installed Dynamat and New carpeting
-Pulled the motor
-Brand new OEM front bumper cover
Page 27
-Started work on the engine harness
Page 28
-Cleaned motor mounts, tranny brackets, flywheel, halfshaft, etc.
-OEM Honda clutch about 30k For Sale
Page 29
-Started separating engine harness
Page 30
-Removed front subframe/suspension unit
-Mocked up engine harness to the motor, basic layout complete
Page 31
-Extended/shortened wires so the base of the harness is all one length
-Harness pretty much ready for sleeving
Page 33
-Started sleeving the harness, 2 of 3 top sections complete
Page 34
-Top portion of the engine harness completely sleeved
-Refreshed the Throttle body, FICV, and IACV inside and out
Page 36
-Picked up and Thoroughly cleaned new gauge cluster surround
Page 38
-New SiR cluster
-Polished lens on cluster
-New Spoon Sports DC2R motor mounts
-Installed cluster and new cluster surround
Page 39
-New OEM Honda seat rail garnishes installed
Page 40
-Intake Manifold refinished
-Throttle body, IAC, etc assembled onto the manifold
Page 42
-VTEC Solenoid refinished
-Solenoid cap painted satin black
Page 43
-Refinished Distributor
-Loomed wires on distributor
Page 47
-Stripped, polished, and installed B16 fuel rail
Page 50
-Removed cold start coolant hose necks on thermo housing and coolant neck.
-Picture of the interior
Page 51
-New T1R rear upper control arms installed
Page 52
-New Bride seatrail arrived
-Installed Bride seat and seatrails
-Polished OEM shift lever
-POR15'ed misc parts for shift linkage and started assembly
-Removed Brake Booster and MC, and Clutch MC from engine bay
Page 53
-Finished shift linkage
-Removed cowl, wiper motor, and plugs from engine bay
Page 54
-New OEM floormats
-worked on shaving the bay
-Spoon banner installed
Page 59
-Custom 3rd brake light
-Masked off Carbon inserts in engine bay
Page 60
-Carbon plate arrived for more interior blockoffs
Page 61
-De-pinned and pulled the chassis harness out of the engine bay
-Removed bumper support and horn
Page 62
-New OEM Honda optional console
-New OEM Honda windshield moldings
-Fabbed up c/f blockoff for ashtray
Page 63
-Began prepping engine bay for paint (120grit passenger side)
-Test fit optional console
Page 64
-More prep work on the engine bay (passenger side 320grit, rad support 120grit)
Page 65
-Finished driver side and rad support with 120grit
Page 68
-Taurus cupholder installed in the optional console
Page 70
-Removed oil pan and mocked up Fastline oil pan baffles
-Finished audio console install
-Installed rear ARP wheel studs
-Cleaned rear suspension and painted brake pads black
Page 71
-Welded in oil pan baffles
-Welded new flange on test pipe
-finished up coolant neck and thermo housing
-New fender roller came in
Page 72
-Started disassembling head
-Bay fully prepped for paint
Page 73
-Painted engine bay
-New Exedy stage 1 clutch
-New Honda Access rain gaurds
Page 75
-Finished dissasembling head
-Head sent out to the machine shop
-Engine bay unmasked with painted bumper support on
Page 76
-Hand polished Intake valves
-Another new shot of the car how it sits as of 4.20.08
Page 77
-All valves fully polished
-New ITR valvesprings
-Mocked up oil cooler
-Installed all brake lines, MC, clutch MC, hood latch
-Installed Honda Access rain guards installed
Page 78
-Cleaned and installed subframe assembly
-More random parts bolted into the engine bay
Page 81
-Pistons and ports cleaned
-Pictures of valve job
Page 82
-Head finished and re-assembled
-Driver door panel almost complete
Page 84
-Spoon tourqe mounts and rear mount installed
-New BC ITR spec coilovers and ITR lca's
-Front suspension installed with new OEM upper control arm mounts
Page 86
-Pressed in ARP front wheel studs
-Cleaned caliper mating surfaces on knuckles to bare metal
-Cleaned bushing mating surfaced on LCA's to bare metal
-Test fitted Spoon N1
Page 87
-Painted and mounted driver side front caliper
Page 88
-Sneak peak of new wheels
Page 89
-Wheels bead blasted
-Passenger caliper painted and semi assembled
Page 92
-Rear suspension completed
-Brakes bled
-Fuel setup completed
-New Dunlop Z1's arrived
-Front calipers and lines installed
-Installed OEM plug for slim fan
Page 93
-Completed engine harness
-Secured front brake lines
-Vti rear bumper diffuser
-Wheels are finished!
Page 94
-Re-did driver side underdash harness to accomodate new engine harness
-More new OEM parts
-More pictures of the wheels
Page 95
-Head bolted on, cams and camholders installed
-Tore down GSR and ITR trans, shimmed and installed LSD in GSR case
-Started cleaning the case
Page 96
-Dunlops mounted on the wheels
-Test fitting rear wheels
Page 97
-Test fitting front wheels
-Finished cleaning trans case
-Carbon fiber inserts on inner mirror peices
Page 99
-Front wheel fitment with spacer and at simulated ride height
Page 100
-Both front fenders rolled
-Began fabbing bumper to fender gap filler peice
-Cleaned engine block
-Tranny Re assembled and complete
-Loomed reverse switch subharness
Modified by SHG_EasyE at 4:33 AM 6/9/2008
Master Index
Page 1
-New parts!
Page 2
Page 3
-New tools
Page 5
-New Spoon N1
-New Cusco hangers
Page 8
Page 9
Page 10
Page 11
Page 12
Page 13
Page 14
Page 17
Page 19
Page 21
Page 22
Page 24
-Organized my stuff
Page 25
Page 26
-Pulled the motor
Page 27
Page 28
Page 29
Page 30
Page 31
Page 33
Page 34
Page 36
Page 38
-New SiR cluster
Page 39
Page 40
Page 42
Page 43
Page 47
Page 50
Page 51
Page 52
Page 53
Page 54
-New OEM floormats
Page 59
Page 60
Page 61
Page 62
Page 63
Page 64
Page 65
Page 68
Page 70
Page 71
Page 72
Page 73
-Painted engine bay
Page 75
Page 76
Page 77
Page 78
Page 81
Page 82
Page 84
Page 86
Page 87
Page 88
Page 89
Page 92
-Brakes bled
Page 93
Page 94
-More new OEM parts
Page 95
Page 96
Page 97
Page 99
Page 100
1 Post
Re: SoHonda Garage EG Hatch Build up pt. 2!! New for 08' (SHG_EasyE)
So Heres how the hatch sits now... since last spring pretty much everything has changed, im sure alot of you have caught some pics here and there on the forum...
And a slew of new parts i have collected over the last month or so....
Oem front upper control arm mounts/bushings, to replace my noisy polyurethanes
Bride Zeta3 with optional head pad
LTB steering wheel spacer, hand polished by me (was black powdercoat)
Yellow valve cover, Motul sticker, spoon hoses, spoon filter, socks etc.
Spoon steering wheel, signed banner, type one stickers, Splash hub
1 Post
And here was my little project for tonight....
I finally got my much anticipated package from Greg @ JDMSpeedworx, including the wheel, hub, stickers etc.
Since the Splash hub is somewhat small, i opted to get a 1" spacer. Unfortunatly the spacer's inner diameter was too big for the horn button to press against and ground out, so i had to do a little fanagaling...
First, i notched out a little section where the horn would usually ground
Then i drilled and tapped a hole to connect a male connector to the hub, once installed a ran some solder over it to guarantee good conductivity. (the screw is out of the back of an NES controller )
Next, i dug around in my box of wire and got some 14g green wire for the ground, and soldered it onto the ground band of the horn button.
I then attached the female end of the connector.
I connected my power and ground, and bolted everything up . (look at how close i got the finish of the spacer to the finsih of the hub, this was done before i got the hub by looking at a picture online for reference )
1 Post
Re: (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">[img]
Pictures like that remind me why its worth spending the money on real deal good stuff like Spoon.
PS-Sweet shiftknob. </TD></TR></TABLE>
Yeah dude, i used to have a personal grinta and it was a nice wheel and all, but man when i bolted this thing up and looked at it, something about it just seems so right lol
Oh and the shiftknob lol - I'm waiting for my Honda Optional **** to come in from ICB, it should be here by the end of next week
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hardEH2 »</TD></TR><TR><TD CLASS="quote">damn man, clean work. I like how the push start is integrated with the console. </TD></TR></TABLE>
Thanks
Thanks
your car build up is the shizz.
how much was that hub>
but dag, your last thread hurted my head
1 Post
Re: (Chris.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. »</TD></TR><TR><TD CLASS="quote">shortest build-up thread ever </TD></TR></TABLE>
lol waiting on parts and some warm weather
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nashville »</TD></TR><TR><TD CLASS="quote">what cluster is that with the yellow needles?? And where do you buy that splash hub </TD></TR></TABLE>
Its a stock base model JDM cluster and i painted the needles yellow... it will be for sale at some point when i get an SIR cluster
I got the hub through a connect of mine, but search google, youll come across one
1 Post
Re: (HBKFanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBKFanatic »</TD></TR><TR><TD CLASS="quote">How come your other thread had line 600 pages?Noah's Arc Build wouldnt even have that many!</TD></TR></TABLE>
lol its about 200 pages of good build material than it kind of veers off to everyone in the crew posting up whatever... now hopefully i can get it somewhat back on track for this winter's build up.... but its also gonna have a bunch of bs inbetween so thats why i made this new thread (the old thread has moved 3 pages since i made this one lol)
