Old 12-28-2007, 07:51 AM   #1
Tuner Eddy
Tuner Eddy's Avatar
Send a message via AIM to Tuner Eddy
Default trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
Alright fella's, I ordered my ASR 24mm sway bar from weaksauce a few weeks back and decided to put it on tonight. I noticed while trying to line the holes up with the "D" brackets that the holes for the bolts were covered by the bracket when one bolt would go in.
To try and make better sense of it, only one bolt on each side of the D bracket would line up, and the other hole would be covered by the bracket.
This frustrates me, because i remember asking Weaksauce on the phone if the ASR sway bar would work with my Carbing rear lower tie bar, and they were firm with their assurance that it would work.
So I am asking, do I need to have the ASR subframe brace in order to run the sway bar?
Next Episode Garage (Find us and like us on Facebook!!!)
1999 Honda Civic Si (2465 lbs. with driver)/H2B -- Weekend Warrior
H2B/GO-Autoworks/Turbonetics/Grams/Golden Eagle/QSD/Skunk2
Tuner Eddy is offline   Reply With Quote
Old 12-28-2007, 07:58 AM   #2
feeldabazzgsr
feeldabazzgsr's Avatar
Default Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (Tuner Eddy)
I am pretty sure you might need ASR brace...are you sure you wanna install that gigantic bar without brace?...i think it would tear apart your subframe if you install it without brace
feeldabazzgsr is offline   Reply With Quote
Old 12-28-2007, 11:35 AM   #3
Tuner Eddy
Tuner Eddy's Avatar
you have to have the subframe brace to run the bar. bout to order it.
Old 12-28-2007, 11:45 AM   #4
BlueIntegraBoy
1998 Acura Integra
BlueIntegraBoy's Avatar
iTrader Rating: (5)
Definitely need one. If you were to somehow mount it, subframe tearout would occur the first time you try to test out the sway bar.
インテグラ タイプR 98-0425
07 Pilot EX-L w/Navi & 4x4
BlueIntegraBoy is offline   Reply With Quote
Old 12-28-2007, 12:42 PM   #5
C-West Civic
C-West Civic's Avatar
Send a message via ICQ to C-West Civic Send a message via AIM to C-West Civic
Pics??? I just did the ASR brace with a Cusco 24mm rear sway and it went on fine.
C-West Civic is offline   Reply With Quote
Old 12-28-2007, 12:52 PM   #6
Tuner Eddy
Tuner Eddy's Avatar
Default Re: (C-West Civic)
you got pics of your setup? i dont have any.
Old 12-28-2007, 02:40 PM   #7
C-West Civic
Default Re: (Tuner Eddy)
Lemme know where your having your problem at based off my photo.
Old 12-28-2007, 02:43 PM   #8
KBG Indey
KBG Indey's Avatar
Send a message via AIM to KBG Indey
I think the problem he's having is that he has a cusco TIE BAR
and ASR SWAY BAR
Not the other way around, like you have =P
dSoc #94
Don't Shift Miss!
[Anti-Citizen One]
KBG Indey is offline   Reply With Quote
Old 12-28-2007, 02:48 PM   #9
C-West Civic
Na cuz he is sayin that his D bracket is covering th other hole that it should mount up to.
Do you have the right size D brackets? You need the bushings and brackets from the ITR
Old 12-28-2007, 04:59 PM   #10
KBG Indey
KBG Indey's Avatar
Sorry about that was thinking about endlinks, not d brackets. Click the image to open in full size.
dSoc #94
Don't Shift Miss!
[Anti-Citizen One]
00, 2000, 24mm, 98, aem, asr, bar, civic, cusco, install, installing, mount, rear, si, subframe, sway
