Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Fit
Old 12-23-2007, 01:12 PM   #1
kwichang
kwichang's Avatar
Default Jack Point for raising the Fit?
Changing the oil for the first time in my new Fit. I don't see any lift point (i.e. front crossmember) for my floor jack. Rear tow hook is present though Click the image to open in full size.
Where have you guys lifted up the front with a floor jack?...or am I just limited to lifting behind each front wheel (PITA).
I like to raise all four wheels off the ground and rotate tires when changing oil.
Thanks
kwichang is offline   Reply With Quote
Old 12-23-2007, 03:10 PM   #2
n1_egsex
* B A N N E D *
Send a message via AIM to n1_egsex
Default Re: Jack Point for raising the Fit? (kwichang)
i jack it up from the side
n1_egsex is offline   Reply With Quote
Old 12-23-2007, 03:49 PM   #3
kwichang
kwichang's Avatar
Default Re: Jack Point for raising the Fit? (n1_egsex)
Thanks! I thought that was the case, but didnt remove any of the plastic splashguards under the bumper/radiator to take a super close inspection.
Old 12-23-2007, 04:46 PM   #4
07ssmfit916
07ssmfit916's Avatar
Send a message via AIM to 07ssmfit916
me too..
but i have seen this before.. http://www.hondafitjazz.com/ma....HTML
GD Squad Member #02
flickr
07ssmfit916 is offline   Reply With Quote
Old 12-23-2007, 05:56 PM   #5
kwichang
kwichang's Avatar
Default Re: Jack Point for raising the Fit? (07ssmfit916)
Very cool 07ssmfit96! - bonus points for the Helm's manual diagram Click the image to open in full size.
Guess I should have taken off the splashguards and taken a closer look!
Old 12-24-2007, 04:01 AM   #6
SuzukaBlueAP2
1993 Acura NSX
My Garage
SuzukaBlueAP2's Avatar
wildtouch83 wildtouch83
I've used the rear tow hook to jack mine up before (not for an oil change obviously) and it worked well.
Maybe it's just my jack, but I can't comfortable get to that front point on the lower rad. support.
When doing an oil change I always raise the vehicle on the driver's side. Be sure to use jack stands while you are under the car.
F/S:S2000 windscreen decals
S-Pods!
SuzukaBlueAP2 is offline   Reply With Quote
Old 12-24-2007, 08:32 AM   #7
$amGD3
$amGD3's Avatar
Originally Posted by 07ssmfit916
me too..
actually on the usdms theres that bowl behind the tow hook and that's the jacking point for the back,for the front?who knows..lol...i cant even slide a jack that far under anymore
$amGD3 is offline   Reply With Quote
Old 12-24-2007, 08:34 AM   #8
E-AT_me
E-AT_me's Avatar
Send a message via AIM to E-AT_me
Default Re: Jack Point for raising the Fit? ($amGD3)
ramps.. atleast, that's what i use for my current cars. i haven't changed the oil in the fit yet. only 900 miles so far. Click the image to open in full size.
1986 civic Si.. B16a is in.. now to finish it..
Daily driver: 1991 Civic Si. 100 miles a day, 35mpg.
E-AT_me is offline   Reply With Quote
Old 12-24-2007, 05:49 PM   #9
eL
eL's Avatar
Default Re: Jack Point for raising the Fit? (E-AT_me)
My Sport wouldnt clear my ramps Click the image to open in full size.
eL is offline   Reply With Quote
Old 12-25-2007, 12:05 AM   #10
$amGD3
$amGD3's Avatar
Default Re: Jack Point for raising the Fit? (eL)
srsly,i never owned a car that could go on those ramps my dad got me
Old 12-26-2007, 03:30 AM   #11
E-AT_me
E-AT_me's Avatar
i've got the small plastic rhino ramps, and even my lowered 86 fits on them. but i don't know about the fit. the front over-hang is a lot. if i set it up right, it should be able to go on them. (slightly sloped driveway. i can play with approach angles)
Old 12-27-2007, 11:28 AM   #12
BMan88
BMan88's Avatar
I use my Rhino ramps with my sport but, I have 4 2x4's that are stair-stepped to raise it high enough to clear the lip.
BMan88 is offline   Reply With Quote
Old 12-30-2007, 04:06 PM   #13
teh cure
* B A N N E D *
teh cure is offline   Reply With Quote
Old 12-31-2007, 02:37 AM   #14
NW Classic Honda
1987 Honda Civic
My Garage
NW Classic Honda's Avatar
www.facebook.com/dannynwch @nwclassichonda http://instagram.com/nwclassichonda
Send a message via MSN to NW Classic Honda
Default Re: Jack Point for raising the Fit? (teh cure)
Takata LDS wheel ramps for lowered cars. The wheel ramps are made by out dated and recycled Takata harnesses, no joke! I need to buy me a set of these before they are all gone... Click the image to open in full size.
http://www.jhpusa.com/catalog/...d=733
"Your one stop shop for pre-1988 Honda/Acura parts. 72-87 Civic, 84-87 CRX, 86-89 Integra, 79-87 Prelude, 76-89 Accord. Cars, parts, collectibles and more!"
NW Classic Honda is offline   Reply With Quote
2004, 2007, car, civic, find, fit, honda, jack, jacking, lifting, locations, point, points, position, ramps
