Fuel pump and main relay kill-switch questions
Hey guys, new to the Honda scene just had a couple questions about kill switches.
I currently have a 2000 em1 b16 that has a car alarm with auto-start and was thinking of installing a couple of kill switches since these cars are pretty heaty around where I live, and I'd like to keep this one for the long run.
I've looked at the FAQ and saw one thread mentioning a fuel pump kill-switch https://honda-tech.com/honda-civic-d...witch-2076997/
I've also watched videos on youtube on how to install them etc, but I still had a few more questions since those videos seemed a little old to answer them.
1. In that thread someone mentions installing a relay as close to the load as possible in order to protect the wiring and to stop a fire, is this true? Should I also install a fuse in line with the switch and the kill switch/relay?
2. Is installing a main relay kill switch (ground cut off) risky? I've read on a few forums that it can cause problems if done incorrectly, are there any wiring schematics I can see?
3. Is there any other layer of security that I can add that would deter/stop thieves? I've heard of something to do with the clutch safety wiring, but I'm kind of scared to deal with that kind of thing...
4. Would there be an issue with using thicker gauged wiring? Fire hazard? Can I use anything to protect the switch/wiring/relay/fuse from heat due to the current?
Sorry if I missed anything, thanks!
Stancetard Hate Monger
Re: Fuel pump and main relay kill-switch questions
there isnt any issue with adding a fuse or using heavier wire. the amount of current you're playing with is minimal. instead of a main relay kill, why not choose one of many ecu wires that would prevent it from starting? unless you can make your car tow truck proof, it isn't theft proof. if they want it bad enough, they'll get it.
thanks for the response eghatch, what type of fuse would you recommend for the kill switches? 25amp good enough?
I know I can't make it theft proof, but at least I can say I tried at the end of the day, this is my first car and I want to take as much care of it as I can since this will probably be given to my brother as well later on.
As for the wiring off of the ECU, I looked up the schematics of the ECU, which would you recommend the best to kill off?
.:FFS TechNet : OBD2b ECU Connector Schematics :.
thanks!
thanks!
I like the tuna here
Yes 25amp switch should be perfect. That's what I used for mine. No need for an inline fuse as well.
One issue I see happening is that your remote start obviously won't work if the physical kill switch is engaged.
Yeah I've accounted for that, but I don't even use it, this system was installed by the previous owner of the vehicle. I always park my car gear in which doesn't allow the auto-start to be initiated in the first place
Fish Twig
So just for clarification, if I run a fuel line kill, the only thing I would need at most is a 15amp rocker? I want to run the wire possibly around 5ft to give it a run around just cause I can, there won't be any problems?
I've read that by using a relay along with the alarm system negates the use of a physical switch, does this mean while the alarm is armed effectively whatever is connected to the kill is dead?
http://www.civic-eg.com/causeforalarm/fuel_kill/NC_fuel_kill_relay.gif
I tried using this circuit for the relay with my compustar cm3000 brain but for some reason the fuel pump wouldn't prime in the on position.
For the ground I used violet comming from the brain which is to my knowledge seems like the negative when armed since I can't seen to see a ground when armed, this seems to be the only other viable option...
I checked if I blew anything by removing the relay altogether and testing by putting a straight rocker, which worked like a charm.
Any ideas?
Any ideas?
LeftLaneB*tch
Audio / Security / Video
12
07-04-2009 06:37 AM
g2tegsown
13
08-21-2008 10:30 AM
