adjust my idle?
Old 01-02-2008, 08:13 PM
  #26
freeagent's Avatar
Default Re: (boostedjdmdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedjdmdc2 &raquo;</TD></TR><TR><TD CLASS="quote">fast idle thermo valve, search and you will find ways to tell if its your FITV or IACV</TD></TR></TABLE>
cool thanks
Old 01-02-2008, 08:28 PM
  #27
spotscivic's Avatar
Default Re: adjust my idle? (d[sick]sTeena)
never seen a cold air setup like that be4...what ever works i guess
Old 01-03-2008, 04:40 PM
  #28
Neptronix's Avatar
Default Re: (freeagent)
or you can do it all at once like me.
but what i found is:
fitv: when dirty, makes idle bounce around and all sorts of crazy
iacv: seems to control idling after warmup. i adjusted my idle down to 750rpm.. but it would jump back up to 1000rpm until i cleaned this bad boy. BTW, it is much easier to clean than the fitv, at least on my 94 del sol. Like i said.. throttle body/carbeurator cleaner + canned air FTW. also, make sure you take off the little rubber dealy before spraying it with throttle body cleaner!!!
No problems with idle since i did the above. and my idle was MESSED UP.
new_climber
12-06-2009 05:44 AM
631 Teggy
14
11-23-2005 09:11 AM
FlatLineEG8
03-04-2004 04:47 PM
nkato
06-10-2003 11:16 PM
Quick Reply: adjust my idle?
