> Honda Prelude
Closed Thread
Old 12-05-2007, 08:01 AM   #1
PrecisionH23a
Moderator
PrecisionH23a's Avatar
Send a message via AIM to PrecisionH23a
Default .::| FAQ FAQ FAQ - Essential Prelude Links |::.
All you need to know. If you have any FAQ worthy links please notify a moderator.
Helpful Links and Commonly Discussed Topics:
Classifieds
For Sale or Wanted to Buy
Intake
Short Ram intake dyno testing
Official EuroR Intake Manifold Thread
Official Skunk2 Intake Manifold Thread
Tech: Euro-R Intake Manifold Install by 2point6
Measurements/Info on OEM H22a Plenum
Exhaust
Review: Apex'i N1 Catback
NA H22 - 3" exhaust comparison
Cylinder Head
DIY Valve Adjustment by gay shakes
The Official H Series Camshaft Thread
Skunk2 Cam Information
H22a Vacuum Routing Diagram by twistedbydezign
H22 Valvetrain Tech & Measurements by Rosko
How To: Cam Install
Head Work: Deshrouding the valve area by satan_srv
Skunk2 Pro Series Camshaft Tech
Cylinder Block
How to have FRM honed
MAHLE gold series pistons with IRON sleeved cylinder walls
Tech: H23 Manual Tensioner Conversion by 2point6
FRM Sleeves and Forged Pistons
Balance Shaft Removal Kit by hondaddict
$20 H/F Balance shaft removal- highly detailed by 2poin2
Official H/F Piston/Rod/Crank/Block specs and CR thread by Rick Solis
Official offset frind thread (offset grinding H/F crankshafts explained) by Rick Solis
The Official compression height and center to center calculations thread by Rick Solis
Base H22A4 Block vs. SH H22A4 Block by shakes
A and B piston guide
H22a Balancer Shaft Dyno Test by satan_srv
General
5th gen: How-to: Retrieve CEL, ATTS and ABS DTC's (codes)
4th gen: How-to: Retrieve CEL DTC's (codes)
Decoding Honda superceded p/n's
Fuel injectors, duty cycle and how not to look like an idiot. **please read** by PirateMcfred
What kind of gas mileage do you get?
Everything you could want to know about your Prelude - HONDA Press Release
Shops By Region
Honda Engine Specs
Prelude Specs and Stats
5th Gens - Base vs. SH
Natural Aspiration
Blue and Red Top H22a Catalog: F20B, Type-S, Sir S-spec, H23A VTEC, Euro-R, Type-R by satan_srv
A realistic look at heavily modifying a Prelude By Lone Luder
2nd Gen Prelude Performance Site
Fuel Mileage, Octane ratings, ignition, and performance
The 'What can I do for more power?' Thread
4th gen Security
How To: Remove Cruise Control by Behan
Troubleshooting
H22a Swaps: Why isn't my engine working?
DIAGNOSE YOUR IDLE ISSUES.....surging...bounce....etc by mgags7
Detailed F20B Build info
How to wreck an H23 VTEC by satan_srv
DIY O2 Simulator Install by Shakes
Tech: Why Doesn't My VTEC Engage? by Prelittlelude
Electrical
4gen Interior/Exterior Bulb Sizes
5gen Interior/Exterior Bulb Sizes
Function of Igniter and Ignition coil
Putting an OBDI h22a motor in an OBDII car and keeping it OBDII by ur mom
How To: Wire VTEC by SKDRCR
Wiring in VTEC
H22A ECU PINOUTS for OBDI and OBDII by satan_srv
Honda Spark plug/wires FIRING ORDER
OBD2A ECU pinouts
OBD2A Sub-harness to Engine harness Pinouts (shocktower connectors)
OBDI H23 Engine harness Pinouts (shocktower connectors)
OBDI engine harness and distributor into OBDII Prelude
HOW TO: Convert OBD2 H22a4 to OBD1 H22a1/H23a1 Distributor
Hybrid/Swaps
All H/F Series Hybrids and CR Thread
F23A Block/H22A1 Head (Accord SOHC VTEC/Prelude DOHC VTEC) by SamIam26
Additional F23/H23 Info by prelittlelude
H23A Block/H22A Head (Prelude DOHC Non-VTEC/Prelude DOHC VTEC)
F20B Destroking Hybrid by satan_srv
F22B2 Block/H22A Head (Accord SOHC VTEC/Prelude DOHC VTEC) by prelittlelude
F23A Block/H23a Head (Accord SOHC VTEC/Prelude DOHC non-VTEC) by PirateMcFred
Official OBDI H22a into OBDII 5th Gen Thread - by 98vtec
H22a4 head onto H22a1 block
F23 Crank Hybrid Engines Thread
Advanced Projects/Builds
Rosko's H23VTEC - S2Pro2 / 12:1 comp / Alaniz head
98vtec's h23vtec
ECU/Engine Management/Tuning
The definitive Prelude ECU choice / Hondata Info Post by FireDrake
V-AFCs and Preludes
How-to: Auto to Manual ECU conversion
OFFICIAL PRELUDE DYNO PAGE
Boost
TIPS: Basic's for building your motor for FI... and having it LAST by Lone Luder
Turbo Prelude Info
JRSC Info
Drivetrain/Handling/Suspension/Braking
M2B4 LSD Discussion
S2000/RSX OEM Brake Upgrade by MLBZ521
DIY Lower Ball Joint replacement
How to change power steering fluid
NSX Brake Calipers/Legend Rotor Swap Discussion
Acura Legend Twin Piston Caliper Swap
Euro R and ATR Tranny Info
Prelude/H-series Transmission Codes and Ratios master-list by Kronn 98SH
5-bolt conversion by satan_srv
4 wheel steering error codes
HOW TO: Change your clutch by Behan
ANOTHER How To: Clutch and Flywheel Install by 98vtec
How To: Lighten that lude! by Paul H22a4
A definitive guide to prelude brake swaps by racerx
HOW TO : 4th gen shifter into 5th gen by 98vtec
How to: Removing Powersteering and looping the lines by 98vtec
How to: 4th gen Manual Steering Rack Conversion by mgags7
How to: determine tranny gear ratios without counting teeth by PirateMcFred
Interior
How to take apart 5th gen dash
4th gen JDM climate control how to
4th gen Steering wheel Removal
Exterior and Appearance
How to take apart and fix condensation in JDM Headlights by OTT
JDM folding Mirror FAQ install
Pic request: 06-07 Civic SI wheels on 5th Gen
THE OFFICIAL Prelude Chassis Codes Thread
Prelude 1/4 Mile Times
NA 13sec Preludes
Media
1st-3rd Gen Picture Thread
4th Gen Prelude Pictures Thread
5th Gen 97-01 Prelude Pictures Thread
Old Prelude Pictures Thread
Prelude Video's
Prelude Exhaust Pictures
http://www.av-engineered.com
PrecisionH23a is offline Report Post
Closed Thread
Bookmarks
3rd, 99, clutch, codes, conversion, diy, gen, h22, h22a, h22a4, prelude, removing, replacement, shooting, steering, trouble, vtec, wheel
