smoke coming from engine and blowing through ac vents as well...aaahhh
Old 12-22-2007, 07:58 PM
mark2583's Avatar
Default smoke coming from engine and also blowing through ac vents after flying over train tracks
ok guys this started yesterday, i see smoke coming through my ac vents and when i pop the hood i see it protruding from the firewall down below the intake mani. also around the same time i noticed a lot of oil spots where i parked i'm thinking that there is oil leaking from somewhere onto the exhaust pipe and therefore causing smoke to come from the engine bay.....am i right or any idea what has happened
Modified by mark2583 at 9:46 PM 12/25/2007
Old 12-23-2007, 12:29 AM
SkimN's Avatar
Default Re: smoke coming from engine and blowing through ac vents as well...aaahhh (mark2583)
check your heater hoses, one runs from the transaxle side of the block just under the distributor and goes to the firewall and back out
Old 12-23-2007, 07:27 PM
hondadude's Avatar
Check the oil pressure sending unit above the oil filter, and the base of the oil filter as well
Old 12-25-2007, 05:44 PM
mark2583's Avatar
Default Re: smoke coming from engine and blowing through ac vents as well...aaahhh (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Check the oil pressure sending unit above the oil filter, and the base of the oil filter as well</TD></TR></TABLE>
ok tomorrow i'm due a timing belt job and i'm also replacing water pump, cam seal, front crank seal, valve cover gasket, balance shaft belt and seal due to the fact that i have an older leak coming fom the timing belt compartment. i should add that the smoke and extra oil leak came after i went too fast over a hidden train track and my car did a mini jump. i have'nt had a chance to look underneath there yet but i'm hoping its something as simple as the oil pan gasket.
Old 12-25-2007, 07:32 PM
Panda Eg6's Avatar
good luck brother
Old 12-28-2007, 04:23 PM
mark2583's Avatar
Default Re: smoke coming from engine and blowing through ac vents as well...aaahhh (Panda Eg6)
i just changed the above mentioned or better yet i had them changed and luckily that solved my oil leak and engine smoke problem but suddenly i'm no longer able to accelerate the way i used to right before the change. its not abnormally slow but i dont get the same throttle response as i'm used to. also my intake is definately sucking alot more than before to the point that its almost annoying. is all this normal if he just replaced those belts and seals. could the timing be off?
yoffer
13
03-27-2007 08:29 PM
asleepz
01-12-2006 02:46 PM
Mike banX
10-09-2004 09:24 PM
People_Mover
05-19-2003 01:05 PM
creechrr
05-06-2003 06:43 AM
Quick Reply: smoke coming from engine and blowing through ac vents as well...aaahhh
