Accord Timing Belt
Old 09-30-2007, 06:27 AM
hkreplica's Avatar
Default Accord Timing Belt
I have a 1992 Accord LX. bought it from a buddy who had the first timing belt done at 120K. it now has 233K. im getting it done soon, i have heard there are other things that should be replaced while getting this done. i want to get as many miles as i can out of this car.
What sort of timing belt will be the best.
What else should be replaced?
Thanks!
Old 09-30-2007, 07:10 AM
He knows where you live!
TheMuffinMan's Avatar
Timing Belt
Water Pump
Oil / Oil Filter
Probably wouldn't hurt to do Fuel Filter
Spark Plugs/Wires
General tune up stuff along with the timing belt/water pump
Old 09-30-2007, 09:39 AM
Duane_in_Japan's Avatar
Default Re: (TheMuffinMan)
https://honda-tech.com/zerothread?id=2108186
Here you go.
Old 11-28-2007, 07:09 PM
hkreplica's Avatar
Default Re: (Duane_in_Japan)
picked up a kit on Ebay for about 80 bucks, both belts, tensioners, water pump, and pump gasket. a co-workers husband owns a shop called Speed Factory, so i had them install everything.
Did the regular belts myself, spark plugs, wires, cap, and rotor.
got some new tires too. after looking at them, i grabbed the front wheel at the top of the tire and was able to shake it side to side...... it moved about 1/8th of an inch and made a sort of clunking noise, the same kinda noise when i his a washboard-like section of road. i just had the wheel bearings replaced too, any ideas of what it could be?
Old 11-28-2007, 07:51 PM
radiuslight's Avatar
Default Re: (hkreplica)
damn
stuff like The Water Pump and Timing Belt should be from Honda OEM
cheap ones from Ebay tend to not last as long or may even break!
if ur at 233,xxx all that should last till 300,000
I think The GMB water pump from ebay goes for a good 50,000 miles
Old 11-28-2007, 08:01 PM
Secret Chimp's Avatar
side.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hkreplica &raquo;</TD></TR><TR><TD CLASS="quote">picked up a kit on Ebay for about 80 bucks, both belts, tensioners, water pump, and pump gasket. a co-workers husband owns a shop called Speed Factory, so i had them install everything.
got some new tires too. after looking at them, i grabbed the front wheel at the top of the tire and was able to shake it side to side...... it moved about 1/8th of an inch and made a sort of clunking noise, the same kinda noise when i his a washboard-like section of road. i just had the wheel bearings replaced too, any ideas of what it could be? </TD></TR></TABLE>
Inner tie rod is probably worn out. Get a new boot too if yours is worn out or gone on that
Old 11-29-2007, 02:17 PM
hkreplica's Avatar
Default Re: (Secret Chimp)
turned out the flopping was the A-arm bushings.
ek02
17
09-23-2018 09:08 PM
car5car
07-09-2017 05:41 AM
kc2mrg
11-10-2010 09:05 AM
projectx2005
05-16-2008 04:52 AM
Runner4
10-30-2003 09:04 AM
Quick Reply: Accord Timing Belt
