> Forced Induction
Old 06-25-2002, 09:48 AM   #1
cinq
cinq's Avatar
Send a message via AIM to cinq
Default HELP: Turbonectic Delta II Wastegate Installation Diagram.
Could someone help with a turbonectic delta 2 wastegate installation diagram. I just bought a used one..and didnt come with the diagram. Thanks in advance.
Not sure where the vacuum hoses to go...There one on the side...and two on top.
the top...one is blocked..and the middle one is open. Help is appreciated.
[Modified by cinq, 6:57 PM 6/25/2002]
"Je pense, donc je suis" - Descartes
cinq is offline   Reply With Quote
Old 06-25-2002, 11:27 PM   #2
quickspoolin
Default Re: HELP: Turbonectic Delta II Wastegate Installation Diagram. (cinq)
The side port connects to a vacuum source . The top one is left open . There is only one opening at the top the other one up there is the adjustment screw with a nut to keep it inplace after adjusting it.
quickspoolin is offline   Reply With Quote
Old 06-27-2002, 08:24 AM   #3
cinq
cinq's Avatar
Default Re: HELP: Turbonectic Delta II Wastegate Installation Diagram. (quickspoolin)
Thanks for your reply. I wonder how to set it to "stock" setting for 7lbs? or 6lbs?
Old 06-27-2002, 09:25 AM   #4
X2BOARD
1994 Acura Integra
X2BOARD's Avatar
Send a message via AIM to X2BOARD
Kinda sounds like you are missing the boost level set screw at the TOP CENTER of the WG.. it should be a threaded, headless screw with a bolt tightened onto it. Do not run the WG w/o that set screw in place.
The other open port on the TOP (left of center) is for vaccum (if you have a boost controller) and the SIDE port is for boost.
As far as setting it for a 7-9 psi boost level, it depends on the spring that sets the WG minimum boost pressure. Typically, the deltagates come with the 7-9 psi spring and you should get 7psi with the set screw ALL THE WAY OUT (not removed tho) (screwing it in will up the boost)
If, by chance, the spring is a higher boost spring... it won't stop at 7psi. *Kaboom* and you'd need a lower boost spring.
X2
[Modified by X2BOARD, 1:26 PM 6/27/2002]
The Past: 97 DB8- Built LSVT@12Psi - The MAGIC SHOW * R.I.P. 09-16-02*
The Present 1993 DX GSR Hatch - The Clone
I'd rather be turbo
X2BOARD is offline   Reply With Quote
boost, delta, diagram, gate, ii, instalation, install, mark, screw, set, top, turbonectic, waste, wastegate, wastgate
