Old 11-23-2007, 01:00 PM   #1
ButterBall
ButterBall's Avatar
Default Lubricating Caliper Slide Pins
I was just wondering what, specifically, people are using to lubricate the brake caliper slide pins on their front calipers with?
I tried using some permatex brake specific lube, and it kept gumming up.
This one:
The service rep at my local honda dealer told me that they used Wurth silicone grease.
This one:
Parts wouldn't sell me a tube of this grease, but gave me a half finished tube to take. The parts guy told me the Wurth silicone lube would work, but they usually use Molyslip AS/40 for lubing caliper slide pins.
This one:
This was all after I went into the Honda dealership to buy some Polyurea grease (honda P/N 08798-9002) for lubing the pins. I've read on this forum that it's good for this purpose.
ButterBall is offline   Reply With Quote
Old 11-23-2007, 01:02 PM   #2
BryanM.
Resident Gearhead
2007 Honda Civic
BryanM.'s Avatar
iTrader Rating: (1)
Default Re: Lubricating Caliper Slide Pins (ButterBall)
I use Lucas hi-temp grease (green in color Click the image to open in full size. ). Has never gummed up on me.
PICS: '07 FG1 - DD
......... '96 EJ6 - SOLD
......... '92 EH2 - SOLD
BryanM. is offline   Reply With Quote
Old 11-23-2007, 01:59 PM   #3
Archidictus
Unceasing Measure
2011 Chevrolet Cruze
Archidictus's Avatar
https://www.facebook.com/michael.gould.355
Send a message via AIM to Archidictus
Default Re: Lubricating Caliper Slide Pins (mcvtec)
Silicone gel is what I use.
But now the summer's dreams are bent like grain against the scythe, and memories of blissful days, they fall like leaves.
Archidictus is offline   Reply With Quote
Old 11-23-2007, 03:05 PM   #4
Vindicator9000
318 Curves, 11 miles
2000 Honda Civic
Vindicator9000's Avatar
Default Re: Lubricating Caliper Slide Pins (Archidictus)
A little offtopic, but has anyone had a slide pin completely seize up? One of mine is frozen, and I can't get it in or out to clean/relube it.
Originally Posted by Arcitekt View Post
here comes vindicator with his 30 line posts.
Vindicator9000 is offline   Reply With Quote
Old 11-23-2007, 04:44 PM   #5
Echo7847
Echo7847's Avatar
Send a message via AIM to Echo7847
Default Re: Lubricating Caliper Slide Pins (Vindicator9000)
I personally use a product called Sil-Glide @ work on slide pins. Its just a silicone lubricant in a gel form and comes in a tube the size of toothpaste.
After they become seized you can usually break the pins loose but they will seize again no matter how well you are able to clean it. Once this happens we usually recommend replacement.
ASE Certified Honda Service Technician
94' Civic Ex
Echo7847 is offline   Reply With Quote
Old 11-23-2007, 04:49 PM   #6
Chiovnidca
Chiovnidca's Avatar
Default Re: Lubricating Caliper Slide Pins (Echo7847)
We use the sil glide too. Works great and doesn't swell up the rubber boots like petroleum based lube does.
http://www.honda-tech.com/zerothread?id=1010778
400+hp d16z6 11.0@137
Chiovnidca is offline   Reply With Quote
Old 11-23-2007, 04:58 PM   #7
Froth
Froth's Avatar
Send a message via AIM to Froth
Default Re: Lubricating Caliper Slide Pins (Chiovnidca)
I've always used Permatex Ultra High-Temp(Red label) and I've yet to see a single problem with it.
-Froth
'02 NFR AP1, Totaled 9/10/11.
'05 GPW AP2, Current DD.
Froth is offline   Reply With Quote
Old 11-23-2007, 07:46 PM   #8
Vindicator9000
2000 Honda Civic
Replacement of the pin, or the whole caliper mounting bracket?
Old 11-23-2007, 08:11 PM   #9
Tarmac Junkie
Tarmac Junkie's Avatar
Send a message via AIM to Tarmac Junkie
To lube the pins I use permatex anti-seize (silver bottle)...
Redline Time Attack # 475 DA Integra: Sponsors: Toyo Tires, Vaughn Performance, Sepulveda Muffler and Brake, Gear X, Special Project Motorsports
My Video's: http://www.youtube.com/user/tarmacjunkie
Tarmac Junkie is offline   Reply With Quote
Old 11-23-2007, 08:52 PM   #10
timmybilt
timmybilt's Avatar
i have had this happen on nearly every honda i have ever bought Click the image to open in full size. so im pretty familiar with fixing it. i usually end up taking the caliper bracket off and clamping the pin in a table vise and working it back and forth until i can get it out (some are more stubborn than others) then use pb blaster to lube the pin and hole and work it until it moves freely then pack it with urea grease and re-assemble. replacement parts such as caliper brackets are not usually stocked so this method is a quick solution so you can get back on the road Click the image to open in full size.
92 si hatch k24/k20 5 luggin = paper weight... 92 cx = project... 05 ep3 = toy... 00 xterra = daily
timmybilt is offline   Reply With Quote
Old 11-24-2007, 03:37 PM   #11
Froth
Froth's Avatar
Default Re: Lubricating Caliper Slide Pins (timmybilt)
That's how I've always done it, works good and if you're adamant enough about cleaning all the rust/gunk off the slide you can usually save the caliper bracket/slide this way. Did this for my friend on his S13 240sx and to this day he's had no problems.
-Froth
Old 11-24-2007, 04:23 PM   #12
t0p_sh0tta
2012 Volkswagen GTI
My Garage
t0p_sh0tta's Avatar
Default Re: Lubricating Caliper Slide Pins (Tarmac Junkie)
t0p_sh0tta is offline   Reply With Quote
Old 07-03-2009, 11:08 AM   #13
ButterBall
ButterBall's Avatar
I came across the part #'s for all of the Honda brand lubricants. Including Honda brand silicone grease for brakes. I figured I would post up the list in case anyone else was interested.
http://img268.imageshack.us/i/hondalubricants.jpg/
antiseize, brake, break, caliper, calipers, frozen, grease, honda, loose, lubricant, lubricating, pin, pins, slide, slider, slides
