Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 11-22-2007, 05:27 PM   #1
banginryder16
banginryder16's Avatar
Default Damn Spark plug wire keeps popping ouT!?
so heres the story...everytime i drive normal it drives fine, once and a while when i tend to give it full throttle and go through my gears one of the spark plug wires of the dizzy side pops out and makes it run on 3 cyl.
For example the other day at the track i took off and went from 1st to second and in between my shift the spark plug wire popped off Click the image to open in full size.
Any advise why this is happening? funny thing is its ALWAYS the same wire that comes out
Wires are MSD 8.5
banginryder16 is offline   Reply With Quote
Old 11-22-2007, 05:54 PM   #2
Ludster
Ludster's Avatar
Send a message via AIM to Ludster
Default Re: Damn Spark plug wire keeps popping ouT!? (banginryder16)
Check your spark plugs. It happened in my old daily and slightly tightening the spark plugs stopped the wires from popping out
Also what spark plugs are you runnning?
-Darker Images-
Sold To: chiLLaxin, TodaCivic, rice a roni, gofastcrx, Obsidianice, gc8dc95, tommiboy, painterbob, srmofo
Ludster is offline   Reply With Quote
Old 11-22-2007, 06:00 PM   #3
banginryder16
Default Re: Damn Spark plug wire keeps popping ouT!? (Ludster)
not 100% sure of the brand of the spark plugs but explain how tightening them down more will stop the plugs from coming out
Old 11-22-2007, 06:03 PM   #4
Ludster
Ludster's Avatar
If your spark plug is lose, compression from the piston will leak through pushing the spark plug wire up.
If you would like a visual representation, pull your plugs and wires and then turn the crank counter-clockwise by hand. You will see what I mean Click the image to open in full size.
-Darker Images-
Old 11-22-2007, 06:12 PM   #5
banginryder16
yea i understand that but the plug that pops out is the wire that plugs into the distributor so there is no compression coming out from there
Old 11-22-2007, 07:04 PM   #6
SikB
SikB's Avatar
When you plug it back in how tight is it compared to the other three? Some wires let you slide the boot up and down the wire. If yours are like that then slide it up the wire to make sure that the contacts are as far in to the cap as they can go.
SikB is offline   Reply With Quote
Old 11-22-2007, 07:55 PM   #7
98vtec
Gone Fishin'
1998 Honda Prelude
98vtec's Avatar
efi.logistics.by.blake.barr bbmoto
Default Re: Damn Spark plug wire keeps popping ouT!? (SikB)
i have had this problem before with MSD wires and i know that mgags7 has had the same problem before. His fix was to use cable ties on the boots of the wires. My fix was to get NGK wires, lol.
Pescador Perception Sport 12.0 w/ 30# Minn Kota
2004 TL 6spd - daily
1992 H22 Turbo Civic - weekend beater *FOR SALE*
1998 H2B Turbo Prelude - project
98vtec is offline   Reply With Quote
Old 11-22-2007, 09:00 PM   #8
banginryder16
Default Re: Damn Spark plug wire keeps popping ouT!? (98vtec)
yea i think i might just get rid of these plugs...and yes the one that pops out slides right in and out
Old 11-22-2007, 09:14 PM   #9
ECX
* B A N N E D *
Send a message via AIM to ECX
Originally Posted by 98vtec
NGK wires
The man has spoken, close this one down.
ECX is offline   Reply With Quote
Old 11-23-2007, 06:20 AM   #10
mgags7
mgags7's Avatar
Yeah, I eventually converted to your fix. NGK wires are the best out there hands down.
mgags7 is offline   Reply With Quote
Old 11-23-2007, 06:32 AM   #11
vlang29
vlang29's Avatar
pull the wire off, and use a lg. screwdriver to expand the connector where it goes into the dist. It will make the connection fit tighter. I had to do this on my ol mazda pickup, and haven't had it come off since
vlang29 is offline   Reply With Quote
1990, accord, boot, cables, civic, honda, plug, plugs, popping, pops, problems, pushing, spark, wire, wires
