2005 Handa Civic 70,000 miles overheating
Old 11-19-2007, 11:12 AM
jccrib1958's Avatar
Default 2005 Handa Civic 70,000 miles overheating
I have had radiator checked and tested ok, checked compression ok, changed Thermastat changed ok tested for Head Leaks ok, Flora Carbons tested ok, only heats up when I turn on heater, Help? has anyone come across this before
Old 11-19-2007, 01:32 PM
JimmyM86's Avatar
Default Re: 2005 Handa Civic 70,000 miles overheating (jccrib1958)
Just a wild *** guess....but it could be a sensor somewhere. When you turn the heater on, the temp of the engine SHOULD go down (b/c you are pulling heat away from the engine).
If you can drive it all night and day without it overheating, but the second you crank the heat on the gauge spikes...it makes me think it is some kinda of sensor that's not working properly.
(You may also want to get the car to normal operating temperature, and (with it idling in your driveway) crank the heat up. Look under/around your engine for leaks. If you have a leak in one of your heater hoses it may cause the engine to overheat b/c you are leaking coolant whil the heat is on. But there's a good chance it is not this b/c if you have a leak in a heater hose, it'll probably leak all the time.
Just some ideas...hope this helps!
Old 11-19-2007, 01:36 PM
oddmut's Avatar
my gf's ride (95) had this problem. We done basically almost everything you did. Even turning on the heater didn't do ****. Found out the head was cracked cuz of the heat. We replaced the engine.
Old 11-19-2007, 06:16 PM
rushbuster70's Avatar
Sounds like you have the d17 curse....
blown head gasket like all the other d17 problems
Old 11-19-2007, 06:17 PM
Curiouz_G's Avatar
its a honda, not a handa btw.
as for your problem, i know you said you checked for leaks but did you check your head gasket?
Old 11-19-2007, 06:24 PM
Boilermaker1's Avatar
The more and more of these headgaskets I see on non-turbo cars, the more and more I think that something is wrong.
Old 11-19-2007, 06:31 PM
Curiouz_G's Avatar
lets all roll up to a HANDA dealership and demand our money back for our cars
Old 11-19-2007, 06:39 PM
katzenjammer84's Avatar
I hope this isn't something I have to look forward to.
Old 11-19-2007, 06:43 PM
Curiouz_G's Avatar
im sure mine will go at some point too
eli_said
10-01-2012 05:20 AM
SlowPokeEg
11-02-2007 08:22 AM
Sohc Driver
03-03-2003 08:17 AM
Sohc Driver
03-01-2003 01:01 PM
Quick Reply: 2005 Handa Civic 70,000 miles overheating
