Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 11-16-2007, 09:12 PM   #1
__oversea
__oversea's Avatar
Default prestone antifreeze, do you use it?
__oversea is offline   Reply With Quote
Old 11-16-2007, 09:13 PM   #2
Lan
Lan's Avatar
Send a message via AIM to Lan
Default Re: prestone antifreeze, do you use it? (Seungho.K)
Honestly dude, to me, coolant is coolant.
MA
Lan is offline   Reply With Quote
Old 11-16-2007, 09:13 PM   #3
Guiding my way back.
* B A N N E D *
Default Re: prestone antifreeze, do you use it? (Lan)
if you live were there temp dont get below freezing use WATER.
Guiding my way back. is offline   Reply With Quote
Old 11-16-2007, 09:14 PM   #4
Lan
Lan's Avatar
Default Re: prestone antifreeze, do you use it? (Guiding my way back.)
And water wetter Click the image to open in full size.
MA
Old 11-16-2007, 09:15 PM   #5
* B A N N E D *
TRUE TRUE !!!!! this guy is like jesus's or something.... Click the image to open in full size. Click the image to open in full size.
Old 11-16-2007, 09:16 PM   #6
Lan
Lan's Avatar
LOL Click the image to open in full size.
MA
Old 11-16-2007, 09:19 PM   #7
Frozen E
H-T White Ops
2008 Honda Element
Frozen E's Avatar
Prestone has been around forever. I think they know what they're doing. So I use their stuff all the time.
Frozen E is offline   Reply With Quote
Old 11-16-2007, 09:25 PM   #8
someone else
It Wasn't Me!
someone else's Avatar
Default Re: (IslandSi)
I use Factory coolant it makes me feel like I'm running Powerade Mountain Blast in my cooling system. And that cools me down on a hot day.
Scars are a reminder of how not to do it next time.
someone else is offline   Reply With Quote
Old 11-16-2007, 10:27 PM   #9
Desired_Speeds
Desired_Speeds's Avatar
Send a message via AIM to Desired_Speeds
prestone, its cheap at walmart, whatever
If you drive a green/tan DC4 with a license plate something along that lines of 3---614 that was originally from San Francisco,CA, please contact me because I may have your original window sticker in hand.
Desired_Speeds is offline   Reply With Quote
Old 11-17-2007, 01:29 AM   #10
JohnD1079
JohnD1079's Avatar
Default Re: (Desired_Speeds)
wat about peak?
JohnD1079 is offline   Reply With Quote
Old 11-17-2007, 01:32 AM   #11
Twixle
ate my pixel
Twixle's Avatar
Default Re: (JohnD1079)
Why use 50/50? It's like half as much if you just buy antifreeze and dilute it yourself. however, it's better for your cooling system if you use distilled water, this prevents corrosion from minerals in regular tap water. Lord knows what prestone mixes in their 50/50, but I'd bet it's not distilled water.
08 FA Si Mugen
Originally Posted by George Knighton View Post
Well, how about **** YOU, you conceited bitch.
Twixle is offline   Reply With Quote
Old 11-17-2007, 05:06 AM   #12
EG2Driver
EG2Driver's Avatar
Send a message via AIM to EG2Driver
Unless you drive a dumb VW and have to buy THEIR G12 coolant @ 30 bucks a gallon. GRRRRRRr
OP, prestone is fine, its what these cars all run on.
EG2Driver is offline   Reply With Quote
Old 11-17-2007, 08:27 AM   #13
BigMoose
BigMoose's Avatar
...coolant is not coolant...
I have posted on this numerous times, here is a start:
http://honda-tech.com/zerothread?id=1794754
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." ...all the best BigMoose
BigMoose is offline   Reply With Quote
Old 11-17-2007, 09:58 AM   #14
hayabusa160
1992 Honda Civic
hayabusa160's Avatar
Send a message via AIM to hayabusa160
Default Re: prestone antifreeze, do you use it? (BigMoose)
just dont mix the dex cool red **** with regular coolent lol.
happen to my friend wasnt fun.
1992 honda civic hatch(sold)
2000 honda accord v6(sold)
2009 pontiac g8 gt
hayabusa160 is offline   Reply With Quote
Old 11-17-2007, 10:07 AM   #15
Desired_Speeds
Default Re: prestone antifreeze, do you use it? (hayabusa160)
shiet what happened
Old 11-17-2007, 01:41 PM   #16
blah13
blah13's Avatar
Send a message via AIM to blah13
Default Re: (Twixle)
Dont run just water in your system. You need some sort of lubricator/rust inhibitor. If your temps don't get down very low run around a 20/80 or 30-70 mix. Or the water wetter as mentioned. Anti-freeze doesnt just prevent teh freeze. And fyi I run prestone in all my vehicles except my bike.
90 Civic EX DOHC ZC
90 Civic DX Auto SOHC ZC
03 SE-R Spec V
05 CBR 1000RR
blah13 is offline   Reply With Quote
Old 11-17-2007, 01:47 PM   #17
inh
inh's Avatar
if you run just water, your **** will corrode. i've seen one too many generators (albeit with iron blocks) that rust and then clog the radiator. no amount of flushign will fix it)
inh is offline   Reply With Quote
Old 11-18-2007, 11:50 AM   #18
hayabusa160
1992 Honda Civic
Default Re: prestone antifreeze, do you use it? (Desired_Speeds)
Originally Posted by Desired_Speeds
shiet what happened
it coagulates clump up.
it also smells horrible.
2009 pontiac g8 gt
Old 11-18-2007, 12:01 PM   #19
Lan
Lan's Avatar
Default Re: (inh)
Water + water wetter will not rust your internals and it runs a lot cooler than antifreeze. If you live in a cold *** area use antifreeze.
MA
Old 11-18-2007, 12:34 PM   #20
Righteous Fire
Righteous Fire's Avatar
Send a message via AIM to Righteous Fire
Default Re: (Lan)
Its not just antifreeze, its COOLANT.
The 50/50 mixture raises the boiling point of the entire mixture to a safer level than water alone.
If honda intended for us to use water in a honda, they would say so.
Just use green coolant, or the honda type 2 (blue stuff). I use the blue personally because I like to stick with OEM.
True story.
Its also horrible for you car unless you drive a GM product.
-Vinnie
Righteous Fire is offline   Reply With Quote
Old 11-18-2007, 12:39 PM   #21
Lan
Lan's Avatar
Default Re: (Righteous Fire)
Water + water wetter runs cooler than COOLANT and it's safe. Ask me how I know.
MA
Old 11-18-2007, 02:43 PM   #22
bmoua
bmoua's Avatar
i use honda coolant...
bmoua is offline   Reply With Quote
Old 11-18-2007, 02:52 PM   #23
outofstock
outofstock's Avatar
Default Re: (bmoua)
I used whichever tastes better....
Excuse me while i get you another glass of bitch....
TriStateTuners.com....the only site needed for PA,NY,NJ,DE and CT car meets and get togethers....
outofstock is offline   Reply With Quote
Old 11-18-2007, 02:59 PM   #24
GoodClothes
GoodClothes's Avatar
Default Re: (Lan)
how do you know? Click the image to open in full size.
i use prestone cause it's cheap and at walmart so fug it.
hehehe [img]http://is.rely.net/1-92-30009-l-tEzPh7Ge6PgBTGi0jOCgA.gif[/img]
GoodClothes is offline   Reply With Quote
Old 11-18-2007, 03:16 PM   #25
Tizight
Tizight's Avatar
I just put some in my car a hour ago.
Tizight is offline   Reply With Quote
1000rr, 2003, 2007, 2008, 2080, 5050, accord, anti, antifreeze, cbr, coolant, dexcool, freezeand, honda, odessey, peak, point, prestone
