How many AMPS does a stock civic radiator fan pull?
Old 11-16-2007, 06:37 PM
1baddturbosi's Avatar
Default How many AMPS does a stock civic radiator fan pull?
I have a perma-cool radiator fan, think its pulling alot more amps than the stock fan is. causing my rad. fan relay to burn-up frequently!
Old 11-16-2007, 07:01 PM
TurboSI56's Avatar
Default Re: How many AMPS does a stock civic radiator fan pull? (1baddturbosi)
If you know anyone with a multimeter you can figure that out pretty easily.
Old 11-16-2007, 07:09 PM
Default Re: How many AMPS does a stock civic radiator fan pull? (TurboSI56)
sorry, but i said i have an aftermarket fan installed on the car, sooooo i dont have a stock fan to see how many its pulling.
i have a fluke multimeter & a amp clamp, im going to the garage to see the difference between what the stock fan pulls, compared to my permacool rad. fan
Old 11-16-2007, 07:13 PM
* B A N N E D *
Teknoshaman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1baddturbosi &raquo;</TD></TR><TR><TD CLASS="quote">I have a perma-cool radiator fan, think its pulling alot more amps than the stock fan is. causing my rad. fan relay to burn-up frequently!</TD></TR></TABLE>
I can check for you tomorrow,
Old 11-16-2007, 07:22 PM
Default Re: How many AMPS does a stock civic radiator fan pull? (Teknoshaman)
that would be a huge help
Old 11-17-2007, 09:46 AM
I can confirm that my amp draw from my perma-cool fan is 9.5amps
Old 11-18-2007, 11:39 AM
blessedrican's Avatar
dunno
Old 11-18-2007, 11:47 AM
95dxsir2's Avatar
yes, the radiator or condensor fan should only pull approx. 8-12 amps. some motors vary. it's been a year since i tested the last one, but thats a ballpark figure
Old 11-18-2007, 12:30 PM
gezzuzz's Avatar
the stock relay should hold that.. but you can always put your own relay
Old 11-18-2007, 01:35 PM
Default Re: How many AMPS does a stock civic radiator fan pull? (gezzuzz)
the relay sometimes "buzz's" & vibrates. & i dunno whats exactly going on
Old 11-18-2007, 04:19 PM
* B A N N E D *
Mine pulls 8.1 amps. Check to be sure the ground on the fan and the ground on the relay is good.
DC4_MADMAN
10
11-26-2012 08:09 AM
EGed up from the seat up
18
06-01-2011 02:16 AM
kyle h.
Welding / Fabrication
06-22-2005 07:18 PM
Halo
06-15-2001 12:04 PM
Quick Reply: How many AMPS does a stock civic radiator fan pull?
