s2k s2000 gauge cluster fully functional in an eg or ek?
Old 12-11-2010, 02:17 AM
  #2326
thegatekeeper14's Avatar
Default Re: s2k s2000 gauge cluster fully functional in an eg or ek?
hold on to ur seat belt because we will be selling pig tails soon.
Old 12-11-2010, 07:32 AM
  #2327
bigdawgky's Avatar
Love this cluster...
Old 12-12-2010, 12:54 PM
  #2328
habib's Avatar
I just put the ap2 cluster in my ek and everything is working except for the speed, i have the speedohealer hooked up, red to 12v+, black to ground, white to blue/white from harness, and green to b7 on the cluster, i have used numerous calibrations to get my speed to work but nothing is working. I have also switched the green and white around and no luck. Can anyone help?
Old 12-12-2010, 06:08 PM
  #2329
bigdawgky's Avatar
initiate the test mode of the speedohealer, if nothing displays on the cluster, you did someting wrong.
Old 12-12-2010, 06:17 PM
  #2330
habib's Avatar
I did the test mode it works but when i drive there is nothing
Old 12-12-2010, 06:34 PM
  #2331
bigdawgky's Avatar
calibration is off then.
Old 12-12-2010, 06:46 PM
  #2332
habib's Avatar
ive been trying different calibrations and i still dont get any mph on the cluster, found a calibration in this thread but it didnt work for me either
Old 12-17-2010, 12:19 PM
  #2333
SL0WEGG's Avatar
selling my cluster w/ pigtails or dash harness for 92-95 civic. PM me if interested
Old 12-20-2010, 03:14 PM
  #2334
The G2 Racer's Avatar
Anyone ever have the mileage on there cluster matched to the mileage on the car?
Old 12-30-2010, 08:51 AM
  #2335
Redline_inboost's Avatar
Can anyone pm me websites to either get the ECT chip and speedo healer for a ap1 cluster into my b powered EG? Or if anyone is making custom harnesses can you pm me with price..? Thanks in advance
Old 01-25-2011, 07:57 AM
  #2336
Glove's Avatar
I did the conversion in my integra, and everything works great except the Hazard lights button doesnt work,the blinkers do,
what am I missing?
Old 01-26-2011, 10:19 AM
  #2337
Phat4Door's Avatar
update on this?
Old 01-26-2011, 10:36 AM
  #2338
SL0WEGG's Avatar
what am I missing?
Your hazard switch plugged in? This shouldn't have affected anything.
Old 01-30-2011, 05:32 PM
  #2339
Glove's Avatar
is it ok to use the orange wire on stock cluster for vss input into the converter?
integra
Old 02-13-2011, 08:45 AM
  #2340
Cole D's Avatar
Any updates on this
Old 03-11-2011, 04:51 PM
  #2341
Snate21's Avatar
What happened to Mark releasing the black box supposedly years ago?
Old 03-11-2011, 06:14 PM
  #2342
SL0WEGG's Avatar
Any of you guys know which wire is the one for the dimmer? everytime I turn on my car my **** is dim and I want it to be bright. I'm guessing I may have one wire mixed up.
Old 03-23-2011, 07:08 AM
  #2343
buddyclubctr's Avatar
i have been going throught all thsi 94 pages and didnt get one this!!!
CANT SOME ONE WHO DID THIS POST HERE A PAGE TO BUY THE VSS SENSOR A PAGE TO BUY THE ECT SENSOR AND EXPLAIN STEP BY STEP HOW TO HOOK IT UP AND WORK?? JESUS
  #2344
i have been going through all this 94 pages and didnt get one this!!!
Old 03-23-2011, 05:03 PM
  #2345
habib's Avatar
just google speedohealer v4 universal for the speedometer, and modifry for the ect gauge
Old 03-24-2011, 05:23 PM
  #2346
jdm_redneck's Avatar
It's funny how things work...I created this thread almost back in 2003 and was astounded to see how many replys and views this thread has recieved over the years.( I got outta the Honda scene for a few years, and am now back with an S2000) Thanks to everyone who submitted to or aided this thread. I am back on Honda Tech now and hope I can start another monster thread like this. Thanks again-Sam
Old 03-24-2011, 06:10 PM
  #2347
digital sol's Avatar
yup, i found this thread back when it first started and did my s2k cluster conversion in my del sol over 4 years ago, everything is still 100% functional and working perfect'
ive got the old VSS convertor, not the speedo healer people are using now a day's
btw^ if your dimmer isnt working you dont have it wired properly, re-check your wiring and take your time
^^hazard lights should not be affected if im not mistaken, been a long time sense i wired mine but double check your wiring and make sure you didnt disconnect the hazard switch, remove it and re-insert it, maybe its not making solid contact
^^honestly a wiring harness is not needed, just buy an s2k cluster that comes with the plugs and wiring and you can just cut the plugs/wiring from your cluster and solder/heat shrink the wires, get a wiring diagram and go to town, its very simple as long as your not color blind, i did mine 1 wire at a time and it still took hardly any time at all and everything worked perfectly the first time around besides the mph because the first time i didn run shielded wiring to the vss how-ever after doing that i was 100% done
Old 03-24-2011, 06:15 PM
  #2348
old pic but you get the idea
wideband on left air vent, fuel pressure on left, boost guage on right, coolant guage in center council where the plastic tab is at
Old 03-25-2011, 05:19 AM
  #2349
Wow, very nice install on the del sol, it looks oem.
Old 03-25-2011, 05:16 PM
  #2350
bustah49's Avatar
help.....
did this conversion and everything works! then went for the ride with my gps to do my final cal. on the speedo healer stopped got gas,reset trip a and trip b, pulled out and speedo was on 0. stopped checked wiring and my big feet pulled power wire out of fuse panel. got back in car started it..drove home. figured out my settings. programmed and now the odometer wont work. WOULD ME DRIVING THIS FOR 6-9 MILES WITHOUT THE SPEEDOMETER WORKING DO THIS? anyway for me to reset this? wen i turn keey on i see 000000 then just goes dar on odometer.
Quick Reply: s2k s2000 gauge cluster fully functional in an eg or ek?
