b20 VTEC torque specs???
Old 11-06-2007, 09:09 AM
MyHotsh's Avatar
Default b20 VTEC torque specs???
My cousin is doing a b20VTEC . He has a B20z with a B16 head.
What specs should he torque the headbolts? (b16 head specs or b20 block?)
also where do the dowel pins go?
thanks in advance for any useful info!!!
Old 11-06-2007, 09:10 AM
Luserkid's Avatar
Default Re: b20 VTEC torque specs??? (MyHotsh)
What bolts is he using? Dowel pins go at the end bolts, just put them in the holes that fit the head and go from there.
Old 11-06-2007, 09:25 AM
MyHotsh's Avatar
Default Re: b20 VTEC torque specs??? (Luserkid)
stock b16 headbolts
Old 11-06-2007, 10:22 AM
Luserkid's Avatar
62ft lbs (i normally do 65)
Old 11-06-2007, 10:23 AM
HAMOTORSPORTS's Avatar
DONT USE B16 HEAD BOLTS!! THEY ARE SHORT. USE GSR.
Old 11-06-2007, 10:34 AM
MyHotsh's Avatar
Default Re: b20 VTEC torque specs??? (HAMOTORSPORTSUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAMOTORSPORTSUSA &raquo;</TD></TR><TR><TD CLASS="quote">DONT USE B16 HEAD BOLTS!! THEY ARE SHORT. USE GSR.</TD></TR></TABLE>
thank you..i dont think he is aware of that!
Old 11-06-2007, 02:30 PM
BILLY_BLING's Avatar
I have a set of arp heads studs for 20block and a b 16 head for $100
Old 07-10-2013, 09:42 PM
roger_ruizz's Avatar
Does anyone know the right head tourque spects for a b20 vtec? I searched it up and different patters and different tourques came out? Thanks..
Old 07-10-2013, 11:42 PM
NZ-DB8R's Avatar
Headgaskets normally come with what torque settings you need, or at least all the ones Ive bought did
Old 07-11-2013, 08:25 AM
dogbiscuit's Avatar
should prolly put ARP studs on there.
Old 02-19-2021, 11:01 AM
Leshwan's Avatar
arp head studs torque setting?? b20 block b16 head
NorCalHB
02-01-2012 07:01 PM
clayton bigsby
10-19-2006 11:34 PM
MAUCH3
02-26-2005 05:26 PM
igy
11-03-2004 05:12 PM
Quick Reply: b20 VTEC torque specs???
