> Honda Prelude
Closed Thread
Old 11-01-2007, 06:00 PM   #1
98vtec
98vtec's Avatar
Default 98vtec's h23vtec - 215whp/178tq - 13.43@103
Since the links were messed up, i'm changing up the outline. I'll post links via post when new updates are ready
Oct 9th - New dyno with eCtune
http://honda-tech.com/showpost.php?p...postcount=1359
DEC 6th - 1/4 mile results
http://honda-tech.com/showpost.php?p...postcount=1434
__________________________________________________ ________
Ok before i get into this, i'm going to be adding tech to this thread as i go so be forewarned that you will likely need to read the whole thread in order to retain everything that is done.
I purchased this setup with the machine work already done. I do not have a bore gauge to determine how well everything was done but after talking to a wiseco rep, the piston to wall and the ring gap are dead on for what i am trying to achieve. I'm assembling this motor in hopes that everything was done correctly prior to me buying it.
Here is what the motor is going to consist of:
f22 crank = 50mm mains
BS kit plugs for the oil pump
Pistons installed:
sidenote......the autozone ring compressor sucks donkey balls!!!
Block:
h23 block with 89mm darton liners
89mm Wiseco pistons
Crower h23 rods
F22 crank (micropolished)
-- crank, rods and pistons have been balanced
ACL bearings
-- align honed mains
kaizenspeed balancer shaft delete
h23 tensioner
Head:
stock unported, stock cams
EuroR Intake manifold - prepared by Rosko
s2000 throttle body
RMF narrow
misc:
12lbs fidanza flywheel
Action 2ks clutch
no ac, ps, cc, evap, egr
New OEM oil pump
New OEM water pump
Converting to OBDI distributor
Fueling:
RDX 410cc injector setup prepared by Rosko
P28 / Crome Pro
Here is the output of the motor with all the same mods minus the block:
I have since fixed my fueling issues which was in turn killing my power considering these cams did not make much more power in general with the tune i had on there.
188whp = stock cams and EuroR manifold
193whp = crower cams and EuroR
The 176whp pass is what put me to 14.0 at 96.6 mph in the quarter mile. I have yet to track the car at its current power level, but its pretty safe to say that im well into the 13 sec barrier.
This build is scheduled to be completed and tuned the week after i get out of school for christmas break. The day after completion, the car is going to the body shop to get its exterior makeover after being hit by a drunk driver...
The car is getting repainted to a darker metallic red. Roof is getting painted a color to match CF and im hoping to have money left over to get a CF trunk.
My goals for this setup is low 13's and eventually break into the 12's when i run a stock thickness headgasket to bump the compression to 13.2:1, running pump and methanol and throw a hefty cam to it.
We'll see what happens
Modified by 98vtec at 11:46 PM 6/10/2008
Modified by 98vtec at 1:26 AM 8/15/2008
Modified by 98vtec at 1:33 PM 8/17/2008
Modified by 98vtec at 10:13 AM 10/13/2008
98vtec is offline
Old 11-01-2007, 06:15 PM   #2
russlan44
russlan44's Avatar
Default Re: 98vtec's h23vtec / 89x95 / 12.2:1 comp build AND Exterior makeover (98vtec)
nice build i wanna see ur dyno so as the track time with new set up
russlan44 is offline
Old 11-01-2007, 06:18 PM   #3
md23vtec
md23vtec's Avatar
Default Re: 98vtec's h23vtec / 89x95 / 12.2:1 comp build AND Exterior makeover (russlan44)
Uhh where is the turbo? This thing is going to be slow unless you add some N20
T/S, Fis, SFWD Prelude--- Mobtown Racing
www.ExplicitSpeedPerformance.net www.mandhtires.com www.bullheadgears.com
Liked by few hated by many respected by ALL
md23vtec is offline
Old 11-01-2007, 06:22 PM   #4
98vtec
98vtec's Avatar
Default Re: 98vtec's h23vtec / 89x95 / 12.2:1 comp build AND Exterior makeover (md23vtec)
smartass
98vtec is offline
Old 11-01-2007, 06:43 PM   #5
Rosko
Rosko's Avatar
Send a message via AIM to Rosko
hell yeah bout time!
-Shawn 12.74@111 All Motor 92 Honda Prelude
http://www.roskoracing.com // rosko@roskoracing.com
Authorized Skunk2 dealer
Rosko is online now
Old 11-01-2007, 06:46 PM   #6
ProjectBB6
ProjectBB6's Avatar
Default Re: 98vtec's h23vtec / 89x95 / 12.2:1 comp build AND Exterior makeover (Rosko)
Nice... get er done
98' BB6-T
450whp 361trq / eCtune / 17psi / 93oct / Dynocom
ProjectBB6 is offline
Old 11-01-2007, 06:47 PM   #7
98vtec
98vtec's Avatar
when are you going e85?
98vtec is offline
Old 11-01-2007, 06:55 PM   #8
Rosko
Rosko's Avatar
allready did a few weeks ago.. gonna get the thinner gasket on this weekend though.
Rosko is online now
Old 11-01-2007, 06:59 PM   #9
Acidcrakker
Acidcrakker's Avatar
Impressive
Modified by Acidcrakker at 10:59 PM 11/1/2007
Jim- 13.9 @ 103 mph
Don't crimp bitch
Acidcrakker is offline
Old 11-01-2007, 07:05 PM   #10
md23vtec
md23vtec's Avatar
Originally Posted by 98vtec
smartass
Just trying to help
md23vtec is offline
Old 11-01-2007, 07:06 PM   #11
98vtec
98vtec's Avatar
Default Re: 98vtec's h23vtec / 89x95 / 12.2:1 comp build AND Exterior makeover (Acidcrakker)
Originally Posted by Acidcrakker
Impressive, I dont know what half that sh*t means
what do you not understand?
98vtec is offline
Old 11-01-2007, 07:14 PM   #12
xxmastermindxx
xxmastermindxx's Avatar
why ACL bearings? the vast majority of talk on here is OEM bearings. most of it, anyway.
Ivan
92 Si, 4th motor http://images.honda-tech.com/set1/smile/emsmilep.gif
H23/F22B2 build in progress. fresh rebuild on bottom end. nothing major, just something different. and cheap http://images.honda-tech.com/set1/smile/emthup.gif
xxmastermindxx is offline
Old 11-01-2007, 07:21 PM   #13
Rosko
Rosko's Avatar
Default Re: 98vtec's h23vtec / 89x95 / 12.2:1 comp build AND Exterior makeover (xxmastermindxx)
Nothing wrong with ACL, Blake's done his homework. Its the people who just throw them in and don't check any clearances that have the problems.
Rosko is online now
Old 11-01-2007, 07:23 PM   #14
xxmastermindxx
ahh, ok. i just remember quite a few threads here and in other forums, basically trashing ACL. then on the other hand, i see high comp and/or hp builds using ACL. just a little confusing, but if they're good as long as you get your clearances right,
Ivan
Old 11-01-2007, 07:24 PM   #15
md23vtec
md23vtec's Avatar
I persoanlly use OEM. At the same time there are plenty of 700 whp plus motors with acl's it's all preference. IMO as long as everything is checked out and comes in spec you should be fine
md23vtec is offline
Old 11-01-2007, 07:24 PM   #16
98vtec
98vtec's Avatar
whats wrong with them if they meet bearing clearance specifications?
OEM bearings are roughly 200 dollars for main, rod and thrust washers
i picked up these ACL's for 50 shipped. ACL bearings are made to meet the "green" clearance of Honda spec which is in the middle.
I plastigaged the mains after getting them aligned honed and each main was near the middle of honda spec.
98vtec is offline
Old 11-01-2007, 07:26 PM   #17
xxmastermindxx
cool
i need a new set of main and rod bearings and washers soon, i was just mentioning that i've seen threads here trashing ACL, "OEM all the way!!!" kinda crap.
Ivan
Old 11-01-2007, 07:29 PM   #18
98vtec
98vtec's Avatar
there is a lot of personal preference in bearing choice. I would imagine that some of the stories with ACL are due to people not measuring the mains because they bought them as "one size fits all" kind of deal.
one thing i have read about ACL's is one side of the bearing being thicker than the other and thus creating a wear problem.
98vtec is offline
Old 11-01-2007, 07:35 PM   #19
xxmastermindxx
that rang a bell, sounds familiar. that should be something you can check with a micrometer though.
i'll be getting bearings soon for my F22/H23 build, and if i can get ACL's for a decent price over OEM, i'll go that route.
Ivan
Old 11-01-2007, 07:36 PM   #20
98vtec
98vtec's Avatar
check ebay for seller "CNSautoparts"
98vtec is offline
Old 11-01-2007, 07:43 PM   #21
xxmastermindxx
wow $45 shipped for mains, rods, and thrusts. sounds like a great deal, and that seller is 100% positive with 11k+ sales. nice
Ivan
Old 11-01-2007, 07:48 PM   #22
Rosko
Rosko's Avatar
actually doesnt hurt to check them with both. I checked all mine with an mic and a bore guage, and then plastiguaged everything assembled to be sure. just because you can mic the clearance on a bearing doesnt mean it will still be the same when the crank is installed. plastiguage is kind of a way to double check the align hone and straightness of the crankshaft too. you can't be too careful when building a motor.
Rosko is online now
Old 11-01-2007, 08:13 PM   #23
PirateMcFred
1995 Honda Prelude
PirateMcFred's Avatar
I thought you sold a bunch of it due to some financial issues... Anyway. Any particular power goal in mind? Looks pretty nice. What do those pistons weigh? What's the compression height?
Chris Bolis is a douchebag. He capitalizes on a community's work without giving due credit. ..........Fact: Hondata eBay Paypal Tilton = Wankers
My K24 Hybrid Alive as of 18:11 5/26/08, 260whp 210wtq 91 oct tuned
PirateMcFred is offline
Old 11-01-2007, 08:22 PM   #24
98vtec
98vtec's Avatar
Default Re: 98vtec's h23vtec / 89x95 / 12.2:1 comp build AND Exterior makeover (PirateMcFred)
i sold the cams (JUN) unfortunately and the money i got from them supported me in my time of need without a job.
compression height is 1.218 IIRC with a 6cc dome
the weights of the pistons are written on the bottom of them and i want to say they were at 354g
98vtec is offline
Old 11-01-2007, 08:26 PM   #25
mgags7
mgags7's Avatar
Send a message via AIM to mgags7
Blake had a little change of plans through that whole thing Pirate. Turned out for the better
Matt
mgags7 is offline
Closed Thread
Bookmarks
98vtec, distributor, euror, exhaust, h22a4, h23vtec, honda, hondatech, job, mykizism, polish, port, prelude, remove, successful, thrust, valve, washers
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
