Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 06-21-2002, 08:36 AM   #1
dingusjt
dingusjt's Avatar
Default How do i depressurize the air conditioner compressor?
Is there a way to do this in my garage or do i need a mechanic, or is there a way that i don't even have to do this when i am taking the engine out of my car
TKE
dingusjt is offline   Reply With Quote
Old 06-21-2002, 08:59 AM   #2
CHEETAH
1994 Honda Civic
CHEETAH's Avatar
Greg Samaroo GBRTuning
Send a message via AIM to CHEETAH
Default Re: How do i depressurize the air conditioner compressor? (dingusjt)
yeah just rest it on the side without disconnecting after removing radiator and condenser from the car ... if you're swappign motors to different series. i.e. d series to b-series, then you'll have to swap a/c compressors ... in which case jsut uncrew the nut a few threads and RUN Click the image to open in full size. hahhaha ... well just let it all out, dont need a mechanic is what I mean.
Greg
www.GBRTuning.com K and B-series Engines; Built b-series and k-series engines[/url] email GBRTuning@aol.com
CHEETAH is offline   Reply With Quote
Old 06-21-2002, 09:06 AM   #3
2point6
2point6's Avatar
Default Re: How do i depressurize the air conditioner compressor? (CHEETAH)
The envrironmentalists are SCREAMING at you now. LOL!
Greg
1st K24 Powered and now boosted 1990 Accord 458whp @ 15lbs.
325.6 WHP 227.3 WTQ ALL MOTOR H22 Powered EG
2point6 is offline   Reply With Quote
Old 06-21-2002, 10:01 AM   #4
spettinger
spettinger's Avatar
Send a message via AIM to spettinger
Default Re: How do i depressurize the air conditioner compressor? (2point6)
if you are swapping motor series i would definitely suggest having a mechanic drain your AC setup the proper way. i think a jiffy lube would do it for you, i don't think they would charge you much. i would let a jiffy lube do this because it is hard to screw up something that is being taken out.
spettinger is offline   Reply With Quote
Old 06-21-2002, 10:07 AM   #5
jetdriven
Default Re: How do i depressurize the air conditioner compressor? (hondaslut #042)
its a 10,000$ EPA fine if you get caught. but in your garage you wont get caught. just unscrew the cap from the ac system . the valve looks like a tire valve. push in the "tit" in the center and the refrigerant will escape. just like a tire
91 teg gs automatic
houston
jetdriven is offline   Reply With Quote
Old 06-21-2002, 10:14 AM   #6
sackdz
1997 Acura Integra
My Garage
sackdz's Avatar
sackdz
Send a message via ICQ to sackdz Send a message via AIM to sackdz
Default Re: How do i depressurize the air conditioner compressor? (jetdriven)
I pushed my tit and it juiced on me Click the image to open in full size.
sackdz is offline   Reply With Quote
Old 06-21-2002, 10:50 AM   #7
mph6563
mph6563's Avatar
I've gotten a little headache just from the R-134 that escapes when I'm pushing a hose onto the fittings. I don't want to think about how I'd feel after discharging the whole system in my face.
[b][url="http://www.coneslayer.org"]Coneslayer Racing: Autocrossing badly since 2002[/url][/b]
mph6563 is offline   Reply With Quote
Old 06-23-2002, 10:14 AM   #8
jetdriven
Default Re: How do i depressurize the air conditioner compressor? (mph6563)
depress it very slowly, just to where you hear refrigerant escape. if you dont want a headacke then buy a charging hose, dont put a can on it, and snap it on the low side valve and get out of the garage!
91 teg gs automatic
houston
Old 06-23-2002, 11:03 AM   #9
YeuEmMaiMai
ehehehehe getting high on R134a ehehhehehe whoa what was that a spark? Click the image to open in full size.
YeuEmMaiMai is offline   Reply With Quote
Old 06-23-2002, 11:48 AM   #10
bryant
bryant's Avatar
Funny you say that, because that is exactly what happen to my friends and I when we did mine. We didn't want to let it out slowly throught the valve thingy, so we just slowly unscrewed the bolt on the line to the compresser. We think we got it, its almost out and Bam! the line pop off and the Freon stuff goes up all in our faces. Click the image to open in full size. We ran to restroom and cleaned up, good thing we had protected eye gear on. I dont want to know what that would have done. Well i know for next time to just use the valve thing and play it on the safe side. Or, "Get it Profesionly done" Click the image to open in full size.
[Modified by CR-X, 2:49 PM 6/23/2002]
mugen無限power
bryant is offline   Reply With Quote
Old 06-23-2002, 01:31 PM   #11
ALF
ALF's Avatar
Default Re: How do i depressurize the air conditioner compressor? (CR-X)
I accidentally breathed in and sprayed R-134 and side effect included dry mouth, swollen throat, and loss of feeling on my hand. Be careful Click the image to open in full size. .
1994 Integra GS-R
1995 Integra LS
2005 Forester 2.5XT
ALF is offline   Reply With Quote
Old 06-23-2002, 06:34 PM   #12
dmotoguy
1993 Honda Civic
My Garage
dmotoguy's Avatar
Send a message via AIM to dmotoguy
Default Re: How do i depressurize the air conditioner compressor? (ALF)
i just took mine to the dealership and they did it for $10
dmotoguy is offline   Reply With Quote
Old 06-23-2002, 11:13 PM   #13
jetdriven
Default Re: How do i depressurize the air conditioner compressor? (YeuEmMaiMai)
r-134a is not flammable. also, why did they charge someone 10$ to recover the refrigerant?? They resell that **** to someone else for 10$ a pound dont you know. why should you pay them to recover it?? just screw the charging hose on the low side valve and getout of the garage. R-134a causes testicular cancer so dont breathe it!!
91 teg gs automatic
houston
ac, air, car, civic, con, condenser, conditioner, conditioning, condtioner, de, depressure, depressurize, depressurizing, honda, pressurize, system
