Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 10-18-2007, 09:22 PM   #1
MIXINinthe805
MIXINinthe805's Avatar
Send a message via AIM to MIXINinthe805
Default good place to hide a kill switch...
what do you guys think?
so cal's finest
were you at
all of cali behind us
MIXINinthe805 is offline   Reply With Quote
Old 10-18-2007, 09:32 PM   #2
denraweb
denraweb's Avatar
Default Re: good place to hide a kill switch... (MIXINinthe805)
Rather not say? lol
Use your imagination...
denraweb is offline   Reply With Quote
Old 10-18-2007, 10:12 PM   #3
gourley
Right on the steering wheel, make sure you put a sticker under it that says " Kill Switch" so you and others dont forget Click the image to open in full size. Click the image to open in full size.
j/p, put it somewhere you think no one will notice and thieves wont think it will be there.
AKA under a seat or behind your Cd player. Its your call
gourley is offline   Reply With Quote
Old 10-18-2007, 11:09 PM   #4
Foxcow
Foxcow's Avatar
Send a message via AIM to Foxcow
Default Re: good place to hide a kill switch... (gourley)
what would you put the kill switch on? Power for the fuel pump or battery power? Ignition? I really don't know.
90 Civic Ex MT
Foxcow is offline   Reply With Quote
Old 10-18-2007, 11:21 PM   #5
ef dino
ef dino's Avatar
Send a message via AIM to ef dino
Default Re: good place to hide a kill switch... (Foxcow)
Its all up to you man. No ones gonna give out there hiding spots. Be creative, make a fuel cut switch somewhere and an ignition cut somewhere else. And if you wanna go all out make switches for every damn thing in the car. You can make a switch to control your mothers ******* just be creative with where your putting these switches. Your car, your switches. Hide em good! Click the image to open in full size.
My buddys got a setup where you have to hold the cigarette lighter down then push the ac button.. You can do WHATEVER you want. If you have an idea and want directions on how to wire it pm me ill give you a very detailed way of how to wire anything you want. Click the image to open in full size. hope that helps a bit
tial bov's ftw
ef dino is offline   Reply With Quote
Old 10-18-2007, 11:47 PM   #6
JKGONZALEZ3
JKGONZALEZ3's Avatar
Default Re: good place to hide a kill switch... (ef dino)
ill tell you mine cause you never get mine started even though i told you were its at. for one of them you have to press the defroster button and wait a certain amount of time before you crank the motor or else it wont crank.
EFSS*Super Scrapers*Never Fallin'*ROT Garage*
RIP CHRISTIAN "FLACO" DELGADIO
06/15/88 - 07/15/07
JKGONZALEZ3 is offline   Reply With Quote
Old 10-19-2007, 05:47 AM   #7
onenonly009
onenonly009's Avatar
Default Re: good place to hide a kill switch... (JKGONZALEZ3)
you should make it so u need 2 people to turn a special key at the same time Click the image to open in full size.
onenonly009 is offline   Reply With Quote
Old 10-19-2007, 07:45 AM   #8
p nut
p nut's Avatar
Go Transporter style and get an ignition code keypad system.
p nut is offline   Reply With Quote
Old 10-19-2007, 08:02 AM   #9
KickStart2323
KickStart2323's Avatar
can i ask how you did that?...so dose the defroster still work or is it a fake button for the killswitch?
KickStart2323 is offline   Reply With Quote
Old 10-19-2007, 08:47 AM   #10
jdm Ef-9
jdm Ef-9's Avatar
Default Re: good place to hide a kill switch... (KickStart2323)
got mine @ the ac button...sleeeeeeeper
old skool rhd honda nut, ef's and da's......
better B Honda werks, southeastern PA.
jdm Ef-9 is offline   Reply With Quote
Old 10-19-2007, 09:04 AM   #11
ef9robert
ef9robert's Avatar
i like this :-)
I <FONT COLOR="red">♥</FONT> My EF "Keep it Kleen"
ef9robert is offline   Reply With Quote
Old 10-19-2007, 09:05 AM   #12
EL Vap133
EL Vap133's Avatar
Send a message via AIM to EL Vap133
Default Re: good place to hide a kill switch... (jdm Ef-9)
Unless the thief breaks in on a hot/warm day. Click the image to open in full size.
WTB: 96-00 Civic EX/Si, catalytic converter.
EL Vap133 is offline   Reply With Quote
Old 10-19-2007, 09:16 AM   #13
traxxasx
traxxasx's Avatar
Send a message via AIM to traxxasx
Mines the ciggerette lighter..BAHAHA you cant start it without the ciggerette lighter pushed in....
Im sure noone has this or even knows..well now they do owell..
AHha better have a ecu with you 2.
traxxasx is offline   Reply With Quote
Old 10-19-2007, 09:21 AM   #14
JG90CRX-Si
JG90CRX-Si's Avatar
Default Re: good place to hide a kill switch... (EL Vap133)
I did mine a while back and although I won't give the location, I have to turn into a pretzel to turn it off/on. Sometimes I forget it's on and crank the ignition and in a second or two the car turns off.
It's in a great place that's not visible and still easily missed with a flash light.
Thanks H-T for the great write up.
JG Click the image to open in full size.
JG90CRX-Si is offline   Reply With Quote
Old 10-19-2007, 03:39 PM   #15
MIXINinthe805
its gonna be on the fuel pump. i had a friend rig it up to the ignition, than it fried his harness, so i figured i'll call that one skip.
someone else i met had a magnet switch in his dash. you just put it next to the panel to get it started, but i haven't been able to find anything like that, or even a specail key switch for that matter
so cal's finest
were you at
Old 10-19-2007, 03:51 PM   #16
ITR640
ITR640's Avatar
Send a message via AIM to ITR640
I dont have one but....
I like the idea of using a preexistinf switch or button. YOu could even get a foglight switch or cruise switch and use it to be your kill switch.
Or maybe that button that makes that little JDM parking pole thing work and use it as a kill switch.
2001 PY ITR #640
1988 CRX (sold)
2004 Honda Civic Si
ITR640 is offline   Reply With Quote
Old 10-19-2007, 04:12 PM   #17
tougetuned_ef
tougetuned_ef's Avatar
Default Re: (ITR640)
i heard one time of a guy rigged up a click pen in his ceter console so you have to click the pen once to start the car. i know that if was to try to steal a car i wouldnt think to click the pen once to start it. jsut think like a car thief and you will come up with something creative. i met a guy at a meet who put on of those key pads in and he said not even 3 days after he put it in someone tried to steal his car and couldnt do it. it was set up so if you try to take the keypad off it would never start.
92' da rs - sold
01 5spd crv ex- moms dd now
99 jeep tj - current dd
tougetuned_ef is offline   Reply With Quote
Old 10-19-2007, 04:51 PM   #18
grog
grog's Avatar
Default Re: (tougetuned_ef)
some
I've heard of using "home security" switches like for a window, its 2 magnets that when placed together complete the switch. so you hide one of the magnets behind something, dash,carpet, or anywhere . to "flip the switch" you stick the other magnet there. when you park take the magnet with you
I believe there are some security write ups if you search, much more detailed than the above
Originally Posted by xerowatts
I HAVE A 1990 CRX HF AND THE ENGINE BLOWED UP.
Originally Posted by mackadocious
its prolly piece of rust that fell inside the rotor causing it to be cricket and make the car shake ..when stoping or ...or prolly motor over flooded with oil leaks
grog is offline   Reply With Quote
Old 10-19-2007, 05:16 PM   #19
KrenzyRyan
KrenzyRyan's Avatar
Send a message via AIM to KrenzyRyan
Thats just weird Click the image to open in full size.
KrenzyRyan is offline   Reply With Quote
Old 10-19-2007, 05:24 PM   #20
Trakhor
Torque Junkie
Trakhor's Avatar
Send a message via AIM to Trakhor
If I told you I'd have to "kill" you.
General rule of thumb is put it in plain sight but not obvious.
I knew a guy who rigged up a relay to his "power antenna" feed on his radio. He turned the key on then the radio, then he could start.
Press F1 for help
Hondaworks [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
Some people say I'm not right in the head, but I know I'm not left in the head, what does that make me?
I think your a poser, don't like it send me a PM
Trakhor is offline   Reply With Quote
Old 10-24-2007, 03:51 PM   #21
MIXINinthe805
Default Re: (grog)
the home security peice souunds like it makes more sense. would something like that wire up with a 12 volt system though?
so cal's finest
were you at
Old 10-24-2007, 04:33 PM   #22
Tippyman
Tippyman's Avatar
Default Re: (MIXINinthe805)
If it can handle house voltage, it can certainly handle 12v.
-05 Jeep / Wheeler
-91 Civic / Turbo'd destroyer of low flying animals
Tippyman is offline   Reply With Quote
Old 10-24-2007, 04:50 PM   #23
Fuzzy Rhubarb
Fuzzy Rhubarb's Avatar
Send a message via AIM to Fuzzy Rhubarb
Sounds like a job for some Microchip PICS. Click the image to open in full size.
Fuzzy Rhubarb is offline   Reply With Quote
Old 10-24-2007, 05:20 PM   #24
Wes V
Wes V's Avatar
Default Re: (Fuzzy Rhubarb)
Here is a link to a page that shows hiding a magnetic reed switch;
http://www.performanceforum.com/bob/bob6/bob6.html
Wes
Wes V is offline   Reply With Quote
Old 10-24-2007, 05:22 PM   #25
Fuzzy Rhubarb
Default Re: (Wes V)
Wire up a fingerprint reader. Click the image to open in full size.
92, air, car, civic, conditioner, good, hide, honda, jdm, keypad, kill, killswitch, making, place, places, switch
