a/c condensor fan fuse keeps blowing
Old 10-09-2007, 06:43 AM
FLCivic's Avatar
Default a/c condensor fan fuse keeps blowing
I have a '97 Civic which the a/c compressor doesn't come on. I have found the problem to be a blown condensor fan fuse. The relays seems to be OK but the fuse keeps blowing whenever I turn the a/c on. Any other suggestions where to check?
It's still hot out here in FL.
thanks
Old 10-09-2007, 12:37 PM
vrrodri's Avatar
check the condensor fan motor, if you apply voltage to it, does it run? Does it run slow? When they start to die, they run slower than the radiator fan.
Maybe the motor is stuck and it blows the fuse, or you have a shorted wire by the consenser assembly. There should also be a groun going to the compressor.
Old 10-09-2007, 12:58 PM
Duane_in_Japan's Avatar
Default Re: (vrrodri)
Turn on the AC, have a friend do it, watch both fans, turn off the AC and the condensor fan should stop much quicker, if its going bad. You could have a burned relay, burned relay socket, burned wire in the fan circuit, loose or corroded ground connection, burned or corroded connector in the fan wiring, bad fan motor / brushes. Carefully touch both motors to see how hot they get, the hotter one should be bad.
Motors and relay sockets are at the top of the list.
Old 10-09-2007, 12:59 PM
circuitEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri &raquo;</TD></TR><TR><TD CLASS="quote">check the condensor fan motor, if you apply voltage to it, does it run? Does it run slow? When they start to die, they run slower than the radiator fan.
Maybe the motor is stuck and it blows the fuse, or you have a shorted wire by the consenser assembly. There should also be a groun going to the compressor.</TD></TR></TABLE>
X2!!
Old 10-09-2007, 04:15 PM
FLCivic's Avatar
Default Re: (Duane_in_Japan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">Turn on the AC, have a friend do it, watch both fans, turn off the AC and the condensor fan should stop much quicker, if its going bad. You could have a burned relay, burned relay socket, burned wire in the fan circuit, loose or corroded ground connection, burned or corroded connector in the fan wiring, bad fan motor / brushes. Carefully touch both motors to see how hot they get, the hotter one should be bad.
Motors and relay sockets are at the top of the list.</TD></TR></TABLE>
When you say both fans do you mean the radiator fan and condensor fan?? Also I disconnected the condensor fan and the fuse still blew when I turned the a/c on. I guess I can rule out the fan. Also anyone have the schematics for the electrical part of the a/c?
thanks for the replies
Old 10-09-2007, 04:31 PM
impr323's Avatar
Default Re: (FLCivic)
Gimme your email and ill send you a 96-00 helms manual w/ schematics
Old 10-09-2007, 04:34 PM
-JSpecEk*9-'s Avatar
Default Re: (impr323)
you have a short so look at your wiring.
Old 10-09-2007, 04:55 PM
FLCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by impr323 &raquo;</TD></TR><TR><TD CLASS="quote">Gimme your email and ill send you a 96-00 helms manual w/ schematics</TD></TR></TABLE>
thanks but I just got it thanks to google
Old 10-10-2007, 07:09 PM
vrrodri's Avatar
shorted wire or bad ground...
Old 12-18-2007, 04:37 PM
FLCivic's Avatar
Still have this problem. I have replaced the condenser fuse, condenser fan, a/c unit and even swapped out the fuse box without success. I have found that the short occurs only when I turn on the a/c.
Any suggestions??
napa2u
11-24-2015 06:24 PM
Justinmnhall
06-04-2013 11:07 AM
Taikonaut
11-04-2005 11:26 AM
90Accord-R
10-17-2003 07:30 AM
Nos4R2
01-26-2003 09:40 PM
Quick Reply: a/c condensor fan fuse keeps blowing
