> All Motor
Old 09-25-2007, 03:51 PM   #1
CW96
CW96's Avatar
Default "Official" All Motor LS B18a, B18b - DOHC NONvtec
This setup is questioned about with no real answers. Please post accurate information so it can compiled into one write up for each topic. Thanks
Topics:
1. OEM piston use (ITR, CTR)
-ITR pistons in LS B18a motor
http://www.honda-tech.com/zerothread?id=2068971
-all motor LS
http://www.honda-tech.com/zerothread?id=2103632
2. Interchangeable internals (with little to no modification)-Discussion on making P8R head work with an LS block
http://www.honda-tech.com/zerothread?id=1466416
3. Most reliable setups (after market, sleeves, etc.)
-"Built" streetable B20 (RS Machines pistons, Crower 404s, etc.), piston and CR discussion
http://www.honda-tech.com/zerothread?id=1707713
4. ITB
5. Tuning
6. Dyno
7. Power vs. RPM
Approved by Nick M
Hybrids non-vtec 404's idle
Modified by CW96 at 5:21 PM 2/17/2008
FarinaMotorsports, tracebuztam, TiredToyotaDriver, ebpem1, veilsides2000, turbohondask, LowSlow93Sol, GSR_GIRL123, RC000E, THMotorsports, Kteller, camp1320.com, JLB Motorsports = (:
CW96 is offline Report Post   Reply With Quote
Old 09-25-2007, 04:02 PM   #2
Stinkycheezmonky
Suspetise...
Stinkycheezmonky's Avatar
Send a message via AIM to Stinkycheezmonky
Default Re: "Official" All Motor LS B18a, B18b - DOHC NONvtec (CW96)
Huh, cool idea. How about P8R information as well? I'll dig up some of the more pertinent threads later on and link them, if that's how we're going to be doing it.
B20 non-VTEC FAQ with P8R information
http://www.honda-tech.com/zerothread?id=1467903
Nonvtec.com...just because, I guess? The people there are at least dedicated to the non-VTEC cause
http://www.nonvtec.com/board
If any or all of these are out of line, PM me and I'll remove whichever ones.
Modified by Stinkycheezmonky at 4:15 PM 9/25/2007
ShifterKart Mafia Member 005
Originally Posted by .one lane View Post
spec miatas are killers of everything on the track. if you're lucky to pass one, it's most likely on the straights.
Stinkycheezmonky is offline Report Post   Reply With Quote
Old 09-25-2007, 05:56 PM   #3
CW96
CW96's Avatar
Default Re: "Official" All Motor LS B18a, B18b - DOHC NONvtec (Stinkycheezmonky)
All of those are great! Lets try to get as much info possible on LS 1.8L block and head. Hmm maybe a budget builders NONvtec (OEM, to whatever extent) build?
Old 09-26-2007, 12:59 AM   #4
661rex89si
661rex89si's Avatar
Send a message via AIM to 661rex89si
sweet more ls all motor info . keep it coming
"ALL THROTTLE NO BOTTLE WELL JUST MAYBE"
EXOSPEED FTW!!!!!!!
661rex89si is offline Report Post   Reply With Quote
Old 09-26-2007, 07:48 AM   #5
CW96
CW96's Avatar
Default Re: (661rex89si)
Indeed. Someone post about their ITR/CTR to LS rod findings
Old 09-26-2007, 01:21 PM   #6
CW96
CW96's Avatar
Old 09-26-2007, 05:14 PM   #7
CW96
CW96's Avatar
How about the use of Individual Throttle Bodies?
Old 09-26-2007, 08:24 PM   #8
661rex89si
661rex89si's Avatar
im with you
EXOSPEED FTW!!!!!!!
Old 09-27-2007, 10:46 AM   #9
00b18b
Send a message via AIM to 00b18b
how about a dyno results section?
00b18b is offline Report Post   Reply With Quote
Old 09-27-2007, 04:33 PM   #10
CW96
CW96's Avatar
Default Re: (00b18b)
Good idea, now lets just get some dyno results
Old 09-27-2007, 05:02 PM   #11
CapnToll
CapnToll's Avatar
Default Re: (CW96)
How bout RPM limits for LS Rods? RPM limits for LS Rods w/ ARP Bolts? etc etc.
How high (Power and RPM) will our Non-VTEC heads keep flowing as compared to superior VTEC head flow characteristics?
96 All Motor B18B Teg SE
I/E/H/IM, BC Stg 2 Cams w/ VT, Cam Gears, FPR, Uberdata
175whp @ 7500rpm :: 135wtq @ 7000rpm
CapnToll is offline Report Post   Reply With Quote
Old 09-27-2007, 06:21 PM   #12
CW96
CW96's Avatar
Default Re: (CapnToll)
Added
Added
All these ideas are golden, but lets get a steam of valid info to do the write up
Old 09-28-2007, 07:17 AM   #13
strict 9 ef
strict 9 ef's Avatar
Default Re: (CW96)
crower at one time had an all motor drag dc teg that was making power close to 10 000 rpm but this was a while back they had a ton of great info.
i'll try and find it.
strict 9 ef is offline Report Post   Reply With Quote
Old 09-28-2007, 08:05 AM   #14
b19coupe
b19coupe's Avatar
B18B motor Benson sleeved to 85mm. Wiseco 11.5:1 pistons-IB rods. LS crank knife edged and balanced by Castillo's Crankshaft, teflon coated by IB. IB ported LS head (P75). Stock valves, JG springs and retainers. Crower 405A cams. JDM ITR header, no cat, stock ITR cat back, GSR muffler. Blox intake manifold, custom velocity stack intake. Precision 440 cc injectors. Hondata S300.
Took out the 405A's, installed a set of Brian Crower stage 2 cams, installed a GSR intake manifold custom fabricated to work on an LS head, motor makes 160/192 with a nice flat torque curve and my daughter drives the car everyday
b19coupe is offline Report Post   Reply With Quote
Old 09-28-2007, 04:42 PM   #15
CW96
CW96's Avatar
Default Re: (strict 9 ef)
PLEASE find that
Old 09-28-2007, 04:53 PM   #16
SIC_jdm_da9
SIC_jdm_da9's Avatar
Send a message via AIM to SIC_jdm_da9
thanx for all of this NA b20 LS non vtec stuff... need it this type of info
you see me in a gold integra all day!
SIC_jdm_da9 is offline Report Post   Reply With Quote
Old 09-28-2007, 06:56 PM   #17
CW96
CW96's Avatar
Default Re: (SIC_jdm_da9)
Old 09-28-2007, 11:59 PM   #18
143MYVTECEF
143MYVTECEF's Avatar
Default Re: (CW96)
So whats the verdict on the p8r and the ls 81mm block?
"Money talks bullshit walks"
'89 STD Hatchback b16- sold
'89 SI Hatchback Sohc ZC/ b16- sold
'88 LX auto "goldfinger" - Donated http://images.honda-tech.com/set1/smile/emsmile.gif
'89 DX Hatchback B18b BAR-ed- Current love http://images.honda-tech.com/set1/smile/embeer.gif
143MYVTECEF is offline Report Post   Reply With Quote
Old 09-29-2007, 07:12 AM   #19
JCushing
JCushing's Avatar
Send a message via AIM to JCushing
Default Re: (143MYVTECEF)
the combustion chamber on a p8r head is more like a b16 head as far as the chamber height and since it has a rather large volume (47cc) milling it isnt a bad idea. by this i mean the depth from the head surface to the quenchpad. i milled mine .024" and there was still room to go. in one of the other threads they suggested milling it down to the quench pads so you can run it on a 81mm block. this essentially would eliminate the pockets that would form if you installed this head on a smaller than 84mm block. i dont know one way or the other since i run a b20 block.
heres my chamber after milling .024, i suppose going .03-.04 would get you completely flat (i think i remember measureing the depth at .03" before it was milled)
84.5mm b20, 11.5:1 cr, non-vtec P8R head with crower 404's going to go bigger FOR MORE POWER! http://images.honda-tech.com/set1/smile/emsmileo.gif
JCushing is offline Report Post   Reply With Quote
Old 09-29-2007, 07:24 AM   #20
JCushing
JCushing's Avatar
the limmiting factor on a LS build will almost always be the head. LS rods with ARP rod bolts are used pretty commonly on alot of motors here vtec and non vtec.. quite simply that combo will outrev your head.
the main thing that holds back our builds is camshaft size. take a loot at the vtec lobe size on some of the hotter vtec cams, skunk2 stage 2 or pro 1/2 BC spec 5 thes eall make good power up top. they also have alot more lift/duration than any cam we can run in a LS head. the crower 405a's are as big as you can go without having to modify the head and will support ~ 200whp.
Old 09-29-2007, 03:34 PM   #21
LS AzZkIkr
LS AzZkIkr's Avatar
i have ran my car only a few times this year and it has been really confusing. in the beginning of the year i ran a 14.77 @93 best pass. me and a old friend played with the ecu on his laptop(i didnt ask any questions about the tuning program he just wanted to try it out so i voluteered!) after the tune it ran a 14.26 @96 !! well that ecu burned up a resistor and started running like garbage! it started run 14.7's again. just thought i would share my experience on the non-vtec thread!!!!
N/A stands for NOT ACCEPTABLE.
LS AzZkIkr is offline Report Post   Reply With Quote
Old 09-30-2007, 10:03 AM   #22
g0tgot
g0tgot's Avatar
Send a message via AIM to g0tgot
how much do cams usually go for, i got a b20B stock with the factory PHK pistons, just curious at what the cams will do for me if im going to keep stock internals on the bottom end...
DC Squad Member #0751
g0tgot is offline Report Post   Reply With Quote
Old 09-30-2007, 07:38 PM   #23
CW96
CW96's Avatar
Default Re: (g0tgot)
So far on this thread, members have mentions Crower 405A cams as well as B. Crower stage II
Old 10-02-2007, 11:44 AM   #24
AMLS4dr200whp
AMLS4dr200whp's Avatar
Send a message via AIM to AMLS4dr200whp
Default Re: (CW96)
about time some started this thread, check my signature on the all motor part
http://is.rely.net/1-92-30001-l-dYfk...lBsMT31QMA.gif
dyno 160whp and 127ft/lbs tq neptune tuned (retired all motor)
Now: Turbo LS on stock bottom end
dyno: 325whp and 265ft/lbs tq neptune tuned
DB squad #88
Check Bio for Vouches http://www.honda-tech.com/zeroavatar/192549
AMLS4dr200whp is offline Report Post   Reply With Quote
Old 10-02-2007, 11:51 AM   #25
Stinkycheezmonky
Suspetise...
Default Re: (CW96)
Incorrect. 405s need more compression than what the PHK pistons will provide. 403s will be nice, 404s will be ok. The BC0022s will be somewhat in the middle of those two, I'd expect.
Edit: For prices, figure ~$300 for cams (little less or a little more), and ~$300-350 for valvesprings and retainers, if you choose to use them.
Bookmarks
404s, adjusting, b18b, b20, cam, cams, crowere, ctr, gears, ls, motor, p30, pistons, prelude, pulley, vtec
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or iPad advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
