How To: Brake Line Tuck Guidelines..
Old 02-01-2014, 05:00 PM
  #1101
dc4teg95's Avatar
Default Re: How To: Brake Line Tuck Guidelines..
Anyone know where I can get new oem brake tube fittings. I have 30 ft roll of 3/16 line for my tuck but want fresh oem fittings. Any links to these. Stainless steel would be even better.
Old 02-04-2014, 10:25 AM
  #1102
stancedef89's Avatar
Is there a new write up someone can point me too?
Old 02-21-2014, 03:08 PM
  #1103
fracas's Avatar
Anyone using a wilwood master Cylinder? ? Looking for ideas to run hard lines to yhe bulk head. Then going to use rywire soft lines in the cabin.
pros and cons please.
Old 03-30-2014, 06:54 AM
  #1104
J_24's Avatar
I'm having only one issue with doing this. I am using the oem 3/16" line and need to "T" off the master cylinder. What fitting's do I need to properly "T" into the factory lines? I am having issues figure this out prob due to this all being new to me?
Old 03-30-2014, 08:58 AM
  #1105
spAdam's Avatar
I don't follow. Are you using a single circuit master cylinder or something?
Old 03-31-2014, 08:51 AM
  #1106
J_24's Avatar
The master cylinder has one port. But I need to "T" into two lines. One for the drivers side and one for the passengers side. No prop valve.
Old 04-01-2014, 06:42 PM
  #1107
spAdam's Avatar
No rear brakes? You just need a pretty standard -3 t fitting. I prefer steel for brake lines.
General question: I'm in the market for a new flare tool. Which o the Ridgid ones do you folks recommend?
https://www.ridgid.com/us/en/flaring-tools
Old 04-03-2014, 06:37 AM
  #1108
J_24's Avatar
Rear brakes will work only off hydraulic assisted staging brake. So I will "t" off that as well to run each line for the rears.
Old 04-03-2014, 06:39 AM
  #1109
J_24's Avatar
I'm just needing to know where I can find them and specs. Because I'm using the oem fitting's on the lines I have a bucket full from cars I've scrapped. So the "t" must allow them to thread into it.
Old 04-03-2014, 08:37 AM
  #1110
spAdam's Avatar
So you just need to dig through your box o' parts, pick your fittings, and then order a t-fitting with the thread of your choosing. The factory flare angle is 45*
Something like this:
which can be found almost anywhere. Summit/Jegs/an-plumbing.com/pegasus/etc...
Old 04-04-2014, 04:29 AM
  #1111
J_24's Avatar
Thanks for the help.
Old 04-04-2014, 04:48 AM
  #1112
J_24's Avatar
The hardlines I will be using are 3/16. The thread for the fitting's are 10X1.0mm and from what I have been reading the flare is 37 double flare?
Old 04-04-2014, 08:37 AM
  #1113
spAdam's Avatar
37* is an -AN flare.
Old 04-16-2014, 08:32 AM
  #1114
mr.bronx75's Avatar
Ok guys here is my noob question after reading thru the pages I couldn't find my answer. I recently did a full disk conversion on my 93 ex coupe, my buddy with a Del sol sold me his whole setup spindles and all, I know I need to change out my current prop valve which I acquired on from a DC2 Integra but I was told that in order for the DC2 prop valve to work I will have to rebend my stock lines is this tru? and are these lines any good http://shop.advanceautoparts.com/p/a...rm=brake+lines.
Old 09-05-2014, 12:26 PM
  #1115
SQ is the SQUAD's Avatar
ttt
Old 09-09-2014, 06:33 AM
  #1116
mr.bronx75's Avatar
is there any way we can get the pic on page to work? I understand that the OG poster is no longer on here longer..
Old 09-09-2014, 08:14 AM
  #1117
spAdam's Avatar
He's still around, just not as much. Maybe you PM him and see if he'd be nice enough to rehost the pics
Old 09-20-2014, 11:44 AM
  #1118
mr.bronx75's Avatar
Thx Adam....
Also I just received my brake-tuck kit and I was wonder what size drill bit are we using to drill the hole for the bulk heads.
Old 10-02-2014, 11:01 AM
  #1119
readyjetsgo's Avatar
I cant see any of the pictures
Old 06-10-2015, 07:29 PM
  #1120
homercan2's Avatar
Does anyone on here have a list of all the fittings for the brake line tuck on a Honda del sol? I've been looking, saw one listed on a for sale. Wanted to tackle on a budgeted DIY... PM me THANKS!!!
Old 10-05-2015, 06:29 AM
  #1121
xero_xero's Avatar
you can reuse all of your oem fittings, with the addition of 4 bulk head fittings.
3/16 steel or stainless line
3an Nut Ends x1pack
3 An bulkhed fittings x4pcs
3an Line sleeves x 2packs
Bender
get a good deburr tool as well as a good bender... brakeline tuck under 60$ with the bender plus however much line you may need.
Old 10-23-2015, 07:48 AM
  #1122
digital sol's Avatar
Originally Posted by teg your it
is full braided brake hose (Earl part no. 600003) a good idea for the braking system?
in other words can it be used to replace the hardline without problems?
This ever get answered? Seems like it would be easier to install & run since you wouldn't need a bender or hardlines period. It wouldn't be as OCD perfect as hardline but would still look clean & be concealed.
Old 10-02-2017, 01:23 PM
  #1123
memphisraines26's Avatar
Anyone know length for banjo bolts for a S2000 brake master cylinder? I need to know which ones to get to convert to banjo fittings.
justinball1717
Honda Civic (2001 - 2005)
10-24-2016 06:43 PM
Tootsie7944
02-06-2015 03:20 PM
Corksil
46
01-21-2012 07:44 PM
civic_66
10-26-2008 11:20 AM
Soda Popinski
12-31-2005 12:28 PM
Quick Reply: How To: Brake Line Tuck Guidelines..
