Go Back   Honda-Tech > Honda and Acura Technical Forums > Paint and Body
Old 09-20-2007, 02:08 AM   #1
NOFX
H-T White Ops
NOFX's Avatar
Default How to Remove Paint from Rubber?
I'm looking to remove some automotive paint from some rubber trim on a lip I have. The rubber is similar in finish to the rubber seal that goes along the bottom of a moonroof visor.
Does anyone know how I might be able to remove this paint on the rubber trim without damaging the rubber?
*SCROLL DOWN FOR PICS.*
Modified by NOFX at 5:40 PM 9/20/2007
I AM NOT YOUR FRIEND (unless I am). DO NOT PM ME. _
If you make a thread then (1) more people will be able to answer and (2) the information can help others!
NOFX is offline   Reply With Quote
Old 09-20-2007, 02:36 PM   #2
Pockets
Pockets's Avatar
Send a message via AIM to Pockets
2 ways: if it's flexible rubber you could try to bend it enough to break the paint off, or if it's black just trim black over it.
Pockets is offline   Reply With Quote
Old 09-20-2007, 04:16 PM   #3
NOFX
H-T White Ops
NOFX's Avatar
Default Re: (Pockets)
It is a part of the lip and cannot move enough to make it crack off of the rubber.
And perhaps you misunderstood. I do not want to paint over it. I want it in it's stock finish, without paint on it.
This is on a '98 OEM coupe rear lip.
Old 09-20-2007, 04:20 PM   #4
E-Rok
EPIC TUNING
E-Rok's Avatar
Default Re: (NOFX)
you can try paint thinner I guess. is it fully painted or it it overspray?
acetone wont really "damage" it or discolor it either.
edit: I reread it and saw its just the trim on the lip. id either remove the lip and wipe the trim down with acetone, or tape the lip off. removing it to do it woul dbe best.
worst comes to worst you can do what you gotta do to get it off, then paint the trim black.
E-Rok is offline   Reply With Quote
Old 09-20-2007, 04:39 PM   #5
NOFX
H-T White Ops
NOFX's Avatar
Default Re: (E-Rok)
I don't mind if it damaged the current paint on the lip. It's getting ready to go in to be repainted.
It's not overspray. It's completely painted. A previous over didn't treat this lip very well.
I want to try to remove the paint on the trim and tape it off so the lip can be repainted.
Here's how the rear lip looks. The trim is at the top, but has been painted over.
This is how it should look stock.
Here is a photo of the back to give you an idea. This rubber cannot easily be peeled off or bent unless I want to damage it.
Old 09-20-2007, 04:50 PM   #6
E-Rok
EPIC TUNING
E-Rok's Avatar
Default Re: (NOFX)
hmm have you looked into buying new rubber trim?
it cant be but a $30 item, and then the lip will be off the car for painting
Old 09-20-2007, 07:22 PM   #7
NOFX
H-T White Ops
NOFX's Avatar
Default Re: (E-Rok)
It's a rare lip. I can't figure out where I could ever find OEM trim and I'm not willing to mess it up in an experiment.
The rubber would have to be cut off to replace it and then there is a good chance that it'd be very difficult to remove the remnants so that I could put new rubber on.
I am incredibly particular and it would bother me even just not being OEM. I would rather just get another rear lip than cut this trim off. The brackets have already been broken off by a previous owner. I'm looking to restore this lip. It's bad enough that I have to get non-OEM brackets since they're sold as part of the lip (another owner CUT / DRILLED them off).
This is the piece that rests on the top of the lip where it will rest against the rear bumper. If I put other trim on there's a good chance it will not fit correctly and might flare out. Too much trouble. I'd rather try to remove the paint.
Old 09-20-2007, 07:32 PM   #8
Libertariat
Ek Forever y0!
2000 Honda Civic
Libertariat's Avatar
Send a message via AIM to Libertariat
Default Re: (NOFX)
I would try reading the cans of various paint strippers. I'm sure a very select few are safe for rubber.
It will take it longer to eat the rubber.
I think you'll be fine, just get the paint and the stripper off before it eats very far into the rubber.
OMG LIBERTARIAT FINALLY HAS A BUILD
Need help choosing suspension? Click here!!
Finally for sale! Progress CS-II Coilovers (350/350) setup. Great for daily and entry/mid level autocross. Landed a 1st place win with these on 3/24
H23A w/ MFactory ITR trans 211whp 169ft/lb Stock block.
Libertariat is offline   Reply With Quote
Old 09-20-2007, 07:37 PM   #9
NOFX
H-T White Ops
NOFX's Avatar
Default Re: (ek forever guy)
I'm just really worried that I'll damage the rubber. I might call up a paint shop tomorrow and see what they recommend. Keep meaning to do that, but been busy or sleeping.
If I figure it out, I'll be sure to post.
automotive, black, bumper, car, clean, cleaning, gaskets, how, lip, paint, remove, removing, rubber, seal, trim
